> 95/96 engine...
post Mar 18, 2010 - 8:02 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
tried searching but since the search doesn't allow for two character searching....i have a 96 chasis and the 95 motors are cheaper to replace...what i know that i need to switch over= EGR, Dizzy, and i think the coolant housing with the sensors...anything else did i overlook?
thanks guys
post Mar 20, 2010 - 9:50 AM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
94-95 Has OBDI
96-99 Has OBDII
add diagnosis sensors and computers to that list.
post Mar 21, 2010 - 7:50 AM
ZC_6Gen
Joined Sep 6, '09
From California
QUOTE (rjbibeau @ Mar 18, 2010 - 8:02 PM) *
thanks guys
You'll need to reuse your 96 complete intake manifold and exhaust manifold to keep it OBD2. Because all the OBD2 emissions equipment you want to keep.
post Mar 21, 2010 - 9:08 AM
aint there a difference in the block, there is a sensor in the 97 that 95 does not have..
post Mar 21, 2010 - 9:14 AM
samir0189
Joined Mar 8, '08
From Orlando, Florida
QUOTE (njccmd2002 @ Mar 21, 2010 - 10:08 AM) *
i think it is the crank angle sensor.......... or some crankshaft related sensor there that the obdII has that obdI does not.
My F/S Thread!
Ferdi says (11:29)
post Mar 21, 2010 - 9:36 AM
the 96+ have the crank sensor intergrated into the oil pump housing, and the trigger wheel for it is intergrated into the crankshaft t-belt pully.
you will need to swap those over, along with the distributor, ect.
post Mar 21, 2010 - 2:46 PM
ZC_6Gen
Joined Sep 6, '09
From California
QUOTE (presure2 @ Mar 21, 2010 - 10:36 AM) *
Good point. I thought when he said dizzy i thought he knew to swap all obd2 sensors over. Because if those sensor isnt in there he'll be throwing CEL. In a sense putting in an obd1 motor could be a task. I'd recommended just putting in same year motor or newer.
This post has been edited by ZC_6Gen: Mar 21, 2010 - 2:48 PM
post Mar 23, 2010 - 11:01 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
ya i was debating about the crank angle sensor as well. thanks for all the input guys...there is like a 500 dollar difference in motor pricing...that's why. i can get the obd1 motor for 450 bucks where they want over a g for the 96 and up one
Lo-Fi Version Time is now: February 18th, 2025 - 12:45 PM
