> insufficient EGR flow, P0401
post Mar 18, 2010 - 8:08 PM
Tsizzles98
Joined Jan 7, '10
From Greenville Ohio
So my 98 celica gt has been throwin me this code for about 2 weeks now and its not staying away.
I have cleaned the port on the throttle body, cleaned the vacumm line ports on the throttle body, replaced egr valve, tested the vacumm modulator (item to the left of the egr with a filter in it), and tested the vsv which is a purge solenoid on the lower part of then engine (ecm tell it when to allow vacumm to open egr
i did all of this and yet i keep getting the code
now my last suspects are either the map sensor or ecm
now with the map sensor im sure it would run funny and all if it went bad, but the car runs fine
and ecms dont go bad often
so can any one help me, im taking any suggestion at this point.
post Mar 18, 2010 - 8:34 PM
Johnnyny
Joined Apr 28, '09
From York pa
did you disconnect the battery after you did all dat to erase the code and drive around
post Mar 18, 2010 - 8:37 PM
Tsizzles98
Joined Jan 7, '10
ive cleared the code after every time i try to fix it, and it comes right back on, now i just got done reading a thread about replacving the modulator, so i think thats my next step.
post Mar 18, 2010 - 10:20 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
im getting both codes at the same time, excessive and insufficient. its very fustrating.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 18, 2010 - 10:26 PM
Tsizzles98
Joined Jan 7, '10
I actaully seen something for both codes at the same time on all data, if you have ever heard of that. Ill read up on it it and post what I find
post Mar 19, 2010 - 8:19 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
please do, its very fustrating!
post Mar 19, 2010 - 9:12 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
the egr is a pain to diagnose. My CEL has been on and off with insufficient egr flow. It doesn't seem to affect anything, so I just let it be.
However, my specific problem seems to relate to the fuel gauge reading.... strange, but true. Oh well. good luck with your hunt for the culprit guys.
My F/S Thread!
Ferdi says (11:29)
Lo-Fi Version Time is now: February 17th, 2025 - 12:45 AM
