> Diagram Question, Lock Cylinder Set
post Mar 19, 2010 - 11:41 PM
Espo
Joined Aug 11, '09
From Buffalo, NY
Is #2 in this diagram: http://www.toyotapartszone.com/online/Page...ponentsIndex=29
The same item as the white plug hanging from playr158's ignition in this picture? (Lower right of picture, partially covering gas pedal.)
http://i43.photobucket.com/albums/e376/azn...or/9a63dfd2.jpg
As mentioned in the thread I took that from, I severed mine (and, as unmentioned in that thread, disassembled it out of curiosity) and need a replacement, and as such would not like to order the wrong part.
Or does it even have a part number? Like I said, #2 (69062-) seems to be my best bet, but I want to confirm before I get it.
post Mar 20, 2010 - 2:51 PM
D-Man
Joined Jan 18, '08
From Houston
the keyswitch harness is what you severed?
Damn D-Man - most impressive.
post Mar 21, 2010 - 1:32 PM
Espo
Joined Aug 11, '09
From Buffalo, NY
Yes, the white thing that screws into the bottom of the ignition column. It presses in when you put the key in, causing the ding and the doors to unlock themselves when open and your key is in there.
Lo-Fi Version Time is now: February 21st, 2025 - 1:49 PM
