> Gear Selector light
post Mar 22, 2010 - 9:46 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
is there a light or is there or just not because I drove home all the way in 2 so I just need to that its a fuse or something else
JDM Part King
post Mar 23, 2010 - 2:17 AM
CAMAricer
Joined Jul 25, '07
From San Francisco
Wow. Do you mean this?
Is there a light or is there or just not, because I drove home all the way in 2. so I just need to [know] that it's a fuse or something else.
QUOTE (1994Celica @ Mar 22, 2010 - 7:46 PM) *
Answer: There is a light. Is yours off all the time? I have a similar problem, but it seems like a loose connection or a short, because it comes on and off randomly, sometimes after I hit a rough bump in the road. I'll pull my center console part off to check it out.
This post has been edited by CAMAricer: Mar 23, 2010 - 2:20 AM
2002 SC430 (WC) - 19" SSR Comp-H, Daizen swaybars, Sparco Demons, JDM Soarer conversion, carbon fiber spoiler, Injen intake, front strut bar, drilled/slotted Brembo rotors
1997 Celica ST (DD) - 17" ADR, ViS Zyclone CF hood, ViS CF hatch, K&N intake, Invader body kit
post Mar 23, 2010 - 5:31 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
How could you not know that you were in 2nd gear?
I've never seen the [D] light work on any Toyota but every other light should work? is your [2] light out aswell? Do you mean on the dashboard or on the base of the gear lever? From what I can remember those selection lights on the dashboard are tricky to get to, you will have to unscrew that section and carefully desolder the 3mm LEDs out of it.
Mike W
269awhp / 273ft-lbs
post Mar 23, 2010 - 12:41 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
can't see where you're from. but in my st204 (usdm gt) the light was by the shift handle in the center console. and not too difficult to replace. i did a mini howto on it a few years ago.
if the lights are in your dashboard then i have no idea.
edit: found it
http://www.6gc.net/forums/index.php?showto...tic+shift+light
This post has been edited by Zimluura: Mar 23, 2010 - 12:44 PM
Lo-Fi Version Time is now: January 10th, 2025 - 5:37 PM
