> from Auto to Standard, tranny swap
post Nov 10, 2003 - 8:32 PM
AWDcelicaTURBO
Joined Oct 18, '03
From Kaneohe, Hawaii
hey does anybody know the exact parts needed to convert my car to standard. Im planning to go to a junkyard at the end of this week. confused.gif
post Nov 11, 2003 - 1:22 AM
You might wanna hold up until u do ur swap?
post Nov 11, 2003 - 6:38 AM
Stipt
Joined Apr 29, '03
From Davenport, IA
Shifter, master and slave cylinders, shifter cables, flywheel, clutch, brake and clutch pedals....believe thats about it.
post Nov 11, 2003 - 11:59 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
AWDcelicaTURBO - hey I got a couple transmissions you might be interested in if stipt dont get em 1st... pm or email me if you intereset
post Nov 11, 2003 - 8:03 PM
Stipt
Joined Apr 29, '03
From Davenport, IA
I figured that was a dead give away tongue.gif AND A TRANSMISSION! Unless you are a dumba$$......and damnit Matt, hold refrain from selling that 3sgte until I get my email back from Jarco on the parts! LOL! MINE!
post Nov 11, 2003 - 8:15 PM
Mynzeyes
From Franklin/Nashville, TN
QUOTE (Stipt @ Nov 11, 2003 - 5:38 AM)
the slave cylinder *should* be on the tranny, also, for the clutch pedal, you will need the bracket to hold the clutch pedal arm, as it is not in the automatic car. also, with the pedals, be sure you get all the springs and pins and bolts and all. i have an extra set of all the pedals/springs/pins/etc needed EXCEPT for the clutch pedal bracket. frown.gif.
also, you will need a shifter assembly, then the lower console piece with the shift boot, and also a knob. (i also have a stock shifter assembly w/ shift knob, if you need that.)
PM me if you're interested. smile.gif.
-John-
AIM==Mynzeyes
Lo-Fi Version Time is now: February 22nd, 2025 - 5:55 PM
