> OEM 4 pin rear fog switch fitted, and fully working!
post Mar 26, 2010 - 11:42 AM
Wintersun
Joined Jan 5, '09
From Kent, United Kingdom
Ok guys, I finally gave up on the idea of trying to figure out how the hell the 8 pin switch is supposed to work.
I managed to get a preface lift celica 4 pin rear fog switch from a member on CCUK.
Brown - ground/earth
Yellow - 12v source
Red - rear fog relay
4 pins:
1. Ground
2. 12v
3. Relay
4. illumination + (wired to my driving lights loom)
Fitted
All works as it would from leaving the factory.
The trouble with the 8 pin switch is that its more complicated than the 4 pin one, in regards that the 4 pin is a simple latching type of switch. Where as the 8 pin seems to need a coil/relay for the switch to actually work.
The 4 pin switch works in the same way as the hazard lights switch.
I have changed the green bulb in the switch for a red one.
This post has been edited by Wintersun: Mar 26, 2010 - 12:10 PM
1996 Green JDM GT4
1998 White JDM SSIII
1994 Black JDM Supra Aerotop
1994 Black JDM GT4
1999 Black UKDM SR
1996 Black UKDM ST
post Mar 26, 2010 - 2:56 PM
captb
Joined Sep 23, '08
From Hawaii
does this mean you have an 8 pin fog switch ur selling.. biggrin.gif . let me know i just got my fogs, shipping to 96789?
but good looking mod and nice writeup. why are there 2 different versions of the switch though? is one for preface and one for facelifted?
post Mar 26, 2010 - 2:59 PM
captb
Joined Sep 23, '08
From Hawaii
QUOTE (Wintersun @ Mar 26, 2010 - 6:42 AM) *
hmm... that just gave me an idea. has anyone tried using the hazard switch to control the fogs and swapped out the actual button for the fog button?
post Mar 26, 2010 - 3:09 PM
Wintersun
Joined Jan 5, '09
Unfortunaly I have already sold my 8 pin fog switch to a guy on here a few months ago. I have no idea why Toyota made to switches. Maybe because the 4 pin switch will stay "on" for as long as you have it pushed on, where as the facelift switch will turn off when you turn the head lights off or ignition off.
1996 Green JDM GT4
1994 Black JDM GT4
1999 Black UKDM SR
1996 Black UKDM ST
Lo-Fi Version Time is now: January 11th, 2025 - 2:52 PM
