> rear power window motor
post Mar 26, 2010 - 7:59 PM
ajmorris1977
Joined Jul 13, '09
does anyone have a guide how to change the rear window motor? mine has been out all winter and i have bought a new one but when i took the rear interior panel off i don't see anything but metel, it would be easier to change if i could at least see it lol, anyway has anyone done this as i could really use the help?
thanks....
You're here for a good time, not a long time. - Colin McRae
When in doubt... Flat out! - Colin McRae
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you....
post Mar 28, 2010 - 10:10 PM
pyeatts
Joined Jun 9, '09
From Saint Louis
As I have a liftback I'm not sure how this looks from the inside, but it looks like the motor, guide and gear is behind the metal bracket.
post Mar 28, 2010 - 10:57 PM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
If you use the search function. I do believe (batman) has made a small DIY.
If you can't find it.. I did one too.. but really bad one... not sure if its still available i'll check for you later.
its pretty easy if you got some skinny arms, aha
post Mar 29, 2010 - 9:59 PM
vile_v
Joined Jun 16, '07
1. remove rear seat and bottom cushion
2. remove scuff plate
3. remove upper inside quarter panel trim ( 3 screws on top)
4. remove lower inside quarter panel trim (2 screws at the bottom, 2 clips on the side attached to the rear seat brace)
5. fully open window ( down position) remove 2 of the window stops. ( 10mm)
6. fully close window ( up position) remove the spring pin. (on the rear window mount, towards the rear of the car) be careful, remember to catch the washer! its sits behinds the pin.
7. remove window (its hard at first but trust me it does come out with a bit of effort
8. remove the 3 nuts holding down the window guide (2 on top 1 on bottom)
9. remove the window guide after
10. disconnect the connector
11. remove for 4 bolts for the motor/regulator
and your done
installation is the reverse of removal.
Lo-Fi Version Time is now: January 11th, 2025 - 4:07 AM
