amp installation |
amp installation |
Nov 10, 2003 - 8:59 PM |
Enthusiast Joined Nov 6, '03 From OH Currently Offline Reputation: 0 (0%) |
just wondering....
where is the easyiest and best place to run the amp lead from battery to amp? i looked and didnt see a easy way through the firewall. what have you guys done?? |
Nov 10, 2003 - 10:12 PM |
Where your engine harness comes thru, they're are alot of other holes too.
Nov 10, 2003 - 11:11 PM |
Enthusiast Joined Sep 6, '03 From Fairbanks AK Currently Offline Reputation: 0 (0%) |
i used a uni-bit and drilled a hole behind the center dash on the passenger's side. If you do drill a hole make sure you also use a gromett and seal it up with silicone when your done. if you want pics of where i put it let me know.
Nov 13, 2003 - 8:32 PM |
Alright, I had the same problem, an didnt want to cut through the wall. There is a rubber boot on the upper left side, this just opens up to right behind the glove box. I just cut a little hole and then slide it through and then ran it down behinde my glove box then through my center console. i added 2 pics, so ask if you need too. this was just the easiest way.
Lo-Fi Version | Time is now: December 3rd, 2024 - 4:18 PM |
