![]() Enthusiast ![]() ![]() Joined Jun 12, '09 From Hull, England Currently Offline Reputation: 0 (0%) ![]() |
Hi guys,
i've got an SS-II liftback with 17x7 inch wheels (ET38 with 13mm spacers so the offset is 25), 215/45R17 tyres, eibach pro-kit, standard type shocks all round, whiteline anti roll/sway bar at the rear set on medium, i noticed today (when racing round the "track") at about 70mph i took a sharp left bend (90 degree curve) slightly bumpy road surface, the front right tyre rubbed on the arch liner a little, how do you think i can counter the rubbing? barring taking off the spacers do you think setting the rear anti roll/sway bar to hard will counter it or do you suggest getting some stiffer shocks on the front? any advice appreciated Tom -------------------- ![]() |
Well if you're braking and taking a left turn, all of the momentum of the car is shifted to the front right corner, so rubbing is sort of a thing you get to deal with.
Ways to not rub: Less of a drop - be it coilovers or different springs Stiffer shocks Larger sway bars, or switch the adjustment out to the stiffer setting on your current one. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
As the above kindly gentleman stated, it's not an issue. I rub every once in a while (giggity) and the worst that can happen is that parts of your fender liner will wear. No biggie.
'93 MX-5 LE |
Lo-Fi Version | Time is now: February 23rd, 2025 - 1:26 PM |
