> How To: Blow off valve
post Mar 31, 2010 - 10:12 AM
BoostedGT
Joined Mar 28, '10
From NY
Can anybody through up pictures (showing vacuum lines, in detail) on how to hook a blow off valve up?
Im just not too sure on where that vacuum line goes to -_-
post Mar 31, 2010 - 10:16 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
QUOTE (BoostedGT @ Mar 31, 2010 - 10:12 AM) *
connect it to any vacuum line that goes from the intake plenum.. there are lots of them! some might even be capped, so there is your chance!
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post Apr 2, 2010 - 12:36 PM
BoostedGT
Joined Mar 28, '10
From NY
Aright man thanks!
I was pretty sure thats where it goes, but i just wanted to double check O_o
post Apr 3, 2010 - 1:55 PM
Nial
Joined Aug 25, '08
From England
QUOTE (BriinumsBo @ Mar 31, 2010 - 11:16 AM) *
Although its advisable not to connect it to the vacuum lines that go to either the FPR, the standard pressure sensor as a fault/split line could be catastrophic.
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Apr 3, 2010 - 2:36 PM
BoostedGT
Joined Mar 28, '10
From NY
QUOTE (Nial @ Apr 3, 2010 - 1:55 PM) *
meaning..
post Apr 3, 2010 - 2:49 PM
BoostedGT
Joined Mar 28, '10
From NY
http://www.6gc.net/forums/index.php?showtopic=48864&st=0
Its the second picture down..that little piece coming off of the intake manifold right next to the black coupler..next to the throttle, its pointing downwards.
Is that where id place the vacuum line from the blowoff valve, if not, can you point out where i should connect it ?
:-? im confuseddddd
post Apr 3, 2010 - 6:09 PM
ravinaziankid
Joined Sep 11, '09
From NYC
It's the blue vacuum line that I showed you. The one I capped off because I didn't hook the BOV up. Look for the only blue line, you will see that is not connected to anything and is capped off.
post Apr 4, 2010 - 6:27 PM
BoostedGT
Joined Mar 28, '10
From NY
Yeah i remembered you showing me it, i just couldnt find it
Do you know what kind of clutch it had in it?
post Apr 4, 2010 - 6:41 PM
QUOTE (BoostedGT @ Apr 4, 2010 - 6:27 PM) *
you can learn a bit about your car by searching thru the posts from the guy who owned it before the last owner. lmao
http://www.6gc.net/forums/index.php?showtopic=31006
post Apr 25, 2010 - 10:44 AM
BoostedGT
Joined Mar 28, '10
From NY
Uhhh, FPR meaning what? Fuel Pressure Regulator? Why would my bov go to that anyway?
post Apr 25, 2010 - 3:43 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (BoostedGT @ Apr 25, 2010 - 11:44 AM) *
you're not following what is being said... there are vacuum lines that run to both the MAP sensor and FPR... you do not want to "T" off of these lines and heres the reason... Putting a "T" and BOV on those lines can weaken the line... now with a weak line, the line may split or break.. losing vacuum to the FPR or MAP sensors could... well... blow up your engine
This post has been edited by pittfirefighter: Apr 25, 2010 - 3:43 PM
Breaking Axles...
post Apr 25, 2010 - 4:07 PM
BoostedGT
Joined Mar 28, '10
From NY
okay so no "t"ing off
Lo-Fi Version Time is now: February 17th, 2025 - 4:35 AM
