Enthusiast Joined Dec 6, '08 From Oregon Currently Offline Reputation: 0 (0%) ![]() |
i found oil in the spark plugs... that cant be good, i put in new ones while cleaning the oil out, and i am still having problems starting it maybe during shipment the engine fell over or tipped upside down leaving oil in the chambers. but as for the not starting i have no idea bc it should still fire. post some pics i wanna see this beast. where did you get your engine i was wanting to get one as well -------------------- "What does All-trac mean?....."
umm.......kicks ass! ST165 1988 Celica All-Trac ST204 1995 Celica GT (undergoing GT-Four conversion may 23rd.) |
yeah, any luck?
Enthusiast ![]() Joined Oct 26, '09 From Florida Currently Offline Reputation: 2 (100%) ![]() |
Yeah, motor is up and running now but I can't get the rpm gauge to work... And I'm trying to get that figured out before I start posting videos
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
the beams enbgines requires a working vvti rpm guage. either in the form of the vvti white guage or
the 3rd gen 3sge rpm guage (would seem sensible since this revs up from 0-7,000rpm and stops at 9,000rpm rather than the USDM one??) with some form of control box to switch the rpms signal over for the BEAMS ecu to understand. trying to find the link regarding that info , which is on this forum somewhere ![]() -------------------- |
you can either use a Beams RPM counter or use the one you already have in your car.
To make yours work you need a tach signal adapter. The beams ECU uses a 5V signal for the rev counter and the non-Beams celicas use a 12V signal. so either get a Beams cluster and swap out the rev counter or get a tach signal adapter. -------------------- |
I swapped in a BEAMS rpm gauge, and it still doesn't work... I swapped in the rpm before I swapped the motor so I would already have it but it ended up not working
thats odd... mine worked flawless.
check the wiring then, maybe somethings not connected??
Well I doubt the wiring is messed up, the cluster was reading accurate before motor swap, does anyone mind sending me there cluster so I can conclude that it's the rpm gauge that doesn't work
Lo-Fi Version | Time is now: April 22nd, 2025 - 1:25 AM |
