Where (the heck) does this connector go? |
May 9, 2010 - 1:26 PM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
May 10, 2010 - 5:30 PM |
Enthusiast Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) |
It goes to your cam position sensor on the back side of ur cam gear.
May 10, 2010 - 7:37 PM |
May 11, 2010 - 12:10 AM |
Enthusiast Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) |
^^^Man, why nobody can't help ME?
Let me sum this up: -it is not knock sensor, this connector is two-wire instead of 1 wire (which still leaves issue with my engine throwing codes 52 and 71, my knock sensor might be bad) -it is not side marker wire, both work and it is too short to reach there anyway -it is not a fog light sensor (for the same reason, too short) -it is not O2 sensor because I can see mine plugged in the header I have tried to see how far it reaches in every direction but didn't find a single plug anywhere within its reach (but it is hard to see behind the block) So (again) where the heck does this go? This post has been edited by conus00: May 11, 2010 - 12:14 AM -------------------- '94 ST
May 11, 2010 - 3:35 AM |
^^^Man, why nobody can't help ME? Let me sum this up: -it is not knock sensor, this connector is two-wire instead of 1 wire (which still leaves issue with my engine throwing codes 52 and 71, my knock sensor might be bad) -it is not side marker wire, both work and it is too short to reach there anyway -it is not a fog light sensor (for the same reason, too short) -it is not O2 sensor because I can see mine plugged in the header I have tried to see how far it reaches in every direction but didn't find a single plug anywhere within its reach (but it is hard to see behind the block) So (again) where the heck does this go? i have both codes i cleaned out the egr but not the intake holes gotta get a wire brush small enough for dat what about your second o2 sensor the one after the flexpipe ? |
Lo-Fi Version | Time is now: November 29th, 2024 - 11:46 PM |
