> Do autos have differential oil
post Apr 3, 2010 - 10:00 PM
gabyz
Joined Jan 11, '07
From Fort Lauderdale, FL
Do auto trannys have differential oil that needs to be changed in regular intervals? o_0
3 post spoiler for sale: Click here
post Apr 4, 2010 - 3:26 AM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
Yes there is a difference. Automatic transmissions use a fluid called automatic transmission fluid commonly known as ATF. While Manual Transmission use a gear type oil generally around 75w-90.
Our celica take ATF Dexron II or III.
Dry (w/o differential fluid) 5.6L (5.9 quarts)
Drain & Refill (w/o differential fluid) 2.5L (2.6 quarts)
Hope that helps! Cheers!
post Apr 4, 2010 - 8:25 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Easy to drain, a pain to fill. I know there is some info on here about that. I did it about a year ago.
post Apr 4, 2010 - 10:07 AM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Two plugs sorta in the back off the diff. Use ATF for sure. I think I just drained mine and then filled it til it almost poured out which is roughly the amount it calls for. I would do it, the filter and the trany itself all in one deal.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Apr 4, 2010 - 1:17 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (Agent21 @ Apr 4, 2010 - 11:07 AM) *
Two plugs sorta in the back off the diff. Use ATF for sure. I think I just drained mine and then filled it til it almost poured out which is roughly the amount it calls for. I would do it, the filter and the tranny itself all in one deal.
My Old Post
Here is a PIC
Ok, use those two threads and you'll be fine. And yeah, if your doing the diff you might as well do the whole thing in one shot. Trans refill/Diff refill and of course filter.
post Apr 4, 2010 - 9:33 PM
gabyz
Joined Jan 11, '07
QUOTE (Spider77 @ Apr 4, 2010 - 2:17 PM) *
My Old Post
Here is a PIC
good info. I just did the tranny fluid with new filter yesterday. I can do the diff separately?
edit: ok im reading the service manual and how it says "Both transmission and differential plugs must be
removed to drain all fluid from both units."....does this mean I have to drain it again?....good grief.
This post has been edited by gabyz: Apr 4, 2010 - 9:36 PM
Lo-Fi Version Time is now: November 23rd, 2024 - 8:25 AM
