60 Pages V  « < 57 58 59 60 >
> Richee3's Progress thread., Wilwood BBK installed.
post Jun 27, 2019 - 12:17 PM
navseal345
Joined Aug 17, '09
From Millard, Omaha, Nebraska
How do you peeps keep having rusty gas tanks? My past 6gc & my current one never gave me problems.
post Jun 27, 2019 - 1:14 PM
richee3
Joined Jun 29, '08
From Denver
This one didn’t rust, it was just crappy manufacturing defects. The first one took 20 years to rust.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 27, 2019 - 6:50 PM
navseal345
Joined Aug 17, '09
OIC
post Jun 27, 2019 - 8:22 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (navseal345 @ Jun 27, 2019 - 5:50 PM) *
OIC
Yup. Not happy about having to swap the tank out again but at least it was quick this time.
1998 Celica GT-
BEAMS Swapped.
post Jun 27, 2019 - 8:39 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Where was it leaking from? crack in the bottom of the tank under or near a strap? So this happens to Corolla's too and the issue lies in the EVAP emissions system, it gets blocked up and doesn't vent, causing the tank to balloon and flex at the straps and then crack and leak over time. It's not super common but the cause is always the same, the charcoal canister is blocked. One guy found a bunch of dirt had packed the charcoal up, he cut it open, replaced it with aquarium charcoal, and glued it back together, never a problem again.
post Jul 8, 2019 - 1:59 PM
richee3
Joined Jun 29, '08
From Denver
It had some pinhole leaks in the bottom, toward the front of the tank in the center. There were some bolts that hold what looks like a baffle for the fuel pump and these holes correspond with those spots. There’s something like 18 of those spots in the tank. It gets real old real fast driving the car until it’s completely out of gas so I can cover those spots with some Quicksteel just so my garage (and house since it’s an attached garage) can smell like gas again a month later. kindasad.gif The new tank is good so far but the last one made it about a year before it started leaking.
I ordered window time for the GT4 since summer is finally here. Of course I mistakenly ordered it for a coupe. :imanidiot: The doors would have still worked but the driver door tint came with a crease in it. I tried to work it out but you could still see it from 100 miles away outside the car.
1998 Celica GT-
BEAMS Swapped.
post May 24, 2020 - 1:50 PM
navseal345
Joined Aug 17, '09
Soooo.... Does her car still run?
post May 24, 2020 - 2:17 PM
who knows, maybe or maybe not
post May 24, 2020 - 4:53 PM
richee3
Joined Jun 29, '08
From Denver
Parted it out.
1998 Celica GT-
BEAMS Swapped.
post May 24, 2020 - 5:10 PM
navseal345
Joined Aug 17, '09
Well at least we know he's alive.
post May 24, 2020 - 10:01 PM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (navseal345 @ May 24, 2020 - 5:10 PM) *
Jake and Sam were visiting them but for all we know, Brigette killed him and called them out to buy parts off the BEAMS so that may not even be him responding.
post May 24, 2020 - 11:34 PM
navseal345
Joined Aug 17, '09
QUOTE (cheela @ May 24, 2020 - 10:01 PM) *
F*CK you're right! Damn it.
post May 24, 2020 - 11:38 PM
Bitter
Joined Mar 11, '06
QUOTE (richee3 @ May 24, 2020 - 4:53 PM) *
Ported it out.
Fixed that for you.
post May 25, 2020 - 1:52 PM
QUOTE (Bitter @ May 24, 2020 - 11:38 PM) *
Farted it out.
Fixed that for you.
nope, i fixed it!!!!!
post May 26, 2020 - 12:47 PM
ricochet1490
Joined May 3, '11
From Ohio
Dan,
do you feel like the superstrut "darts" when you get it past a certain point in a corner? Or does it just corner well?
I ask because if I make a right hander in mine it feels ok, almost normal. But if I make a left hander, christ almighty hold on. On a track it would have darted down to the inside on the apron.
Inherently I know that there's a joint issue somewhere in the superstrut, been too lazy to actually diagnose it and change parts, but wondering if the right hander or the left hander is the problem after re reading some of the last years posts.
post May 26, 2020 - 8:13 PM
Bitter
Joined Mar 11, '06
QUOTE (ricochet1490 @ May 26, 2020 - 12:47 PM) *
Dan,
You for sure have one or more worn parts and likely a dynamic alignment problem because of it.
post May 28, 2020 - 7:35 AM
PizzaGuy01
Joined Nov 30, '12
From San Antonio
QUOTE (ricochet1490 @ May 26, 2020 - 1:47 PM) *
Dan,
Could be a loose bushing bolt. When you turn, the outside wheel takes the load and its enough to shift a loose joint. Does the superstrut have crush tubes and are yours installed?
This post has been edited by PizzaGuy01: May 28, 2020 - 7:36 AM
post May 28, 2020 - 5:02 PM
ricochet1490
Joined May 3, '11
From Ohio
QUOTE (PizzaGuy01 @ May 28, 2020 - 7:35 AM) *
Dan,
When I bolted the halfcut subframe in, it is in exactly that same condition with exception to the fact I added the struts that were missing. So its a definite maybe.
Pretty sure all the bolts are tight. I have shop down the road that always has skylines, miatas etc out front. Probably just take it there so he can put it on the lift with all my spare SS parts, see if they can make something work.
post Nov 24, 2020 - 4:30 PM
richee3
Joined Jun 29, '08
From Denver
Let’s see how this works out...
1998 Celica GT-
BEAMS Swapped.
post Nov 24, 2020 - 6:48 PM
Bitter
Joined Mar 11, '06
Y'all 6GC people need to quit stealing my damn 7th gen parts! Wheels, seats, now COMPUTERS!
This post has been edited by Bitter: Nov 24, 2020 - 6:48 PM
Lo-Fi Version Time is now: November 22nd, 2024 - 8:01 AM
