60 Pages V  « < 42 43 44 45 46 > »
> Richee3's Progress thread., Wilwood BBK installed.
post Aug 19, 2013 - 5:01 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I have the Speed Source ones too. The shift are a bit more choppy and mechanical but alot more precise
I have heard other alternatives that worked as well.
This post has been edited by Tigawoods: Aug 19, 2013 - 5:02 PM
エキサイティングカーレーシングチーム!
post Aug 19, 2013 - 6:31 PM
navseal345
Joined Aug 17, '09
From Millard, Omaha, Nebraska
If I get a Celica again can you get the parts and send them to me at no charge?
post Aug 19, 2013 - 9:23 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (Tigawoods @ Aug 19, 2013 - 5:01 PM) *
I almost bought a set of brass bushings from eBay, then I noticed people saying that they caused shift cable failure due to the lack of flexibility. Then when I went to swap, I was glad I didn't buy them because my shift cable bushings are two different sizes. I've noticed some members around here say they have the brass bushings, but all the kits I've seen (SW20, ST204, ZZ30) sell two bushings the same size. Did later model Celicas have different shift cables than earlier years? I'll check ToyoDIY in a little while. In the meantime, if I could find a replacement for my other bushing (OEM or not) I'd go ahead and replace it. May go ahead and replace the cables soon, who knows.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 19, 2013 - 9:52 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (richee3 @ Aug 19, 2013 - 10:23 PM) *
Apparently so, my shift cables are both of the same size. When I ordered my bushings they came in staggered sizes. I had to return one and got one of the same size as the other one. One was the size of a quarter and the other was the size of a dollar coin almost. I had to use two of the smaller ones.
I might try roller bearings. I've never heard of any shifter cables broken due to brass bushings but the theory behind the roller bearings allowing the cable some slop is a good one.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Aug 19, 2013 - 10:16 PM
richee3
Joined Jun 29, '08
From Denver
That sounds like the set I need. I just checked and compared part numbers from a '94 Celica to my '98, both use the same shift cables. It's possible the previous owner swapped them out for an aftermarket set or something. Where did you get your set from?
1998 Celica GT-
BEAMS Swapped.
post Aug 31, 2013 - 4:55 PM
richee3
Joined Jun 29, '08
From Denver
1998 Celica GT-
BEAMS Swapped.
post Aug 31, 2013 - 5:00 PM
Zake
Joined Mar 7, '10
From Ft. Lauderdale
^Ummm.. info? 0.O
post Aug 31, 2013 - 5:55 PM
he blew the engine,
because racecar...
post Aug 31, 2013 - 6:17 PM
navseal345
Joined Aug 17, '09
No... because mark.
post Aug 31, 2013 - 9:01 PM
richee3
Joined Jun 29, '08
From Denver
RACEKOR!!
No, kurt95gt and BlueCelicaWife came down from Ohio to help pull the motor. Dustin and Stef suspect my steering rack is the cause of my weird torque steer issue so I picked up a new steering rack, inner tie rod ends to go with the outers I bought last year and never installed, passenger side motor mount, poly motor mount inserts, and plenty of engine degreaser for the engine bay. Turns out the rack we got, although the dimensions are the same, is not for a Celica. So now the engine is out, the bay is clean, and we're at a standstill. We considered replacing the tie rod ends and putting the rack back in and putting the motor back in but we didn't go through all this work to give up and put the same rack back in. So I guess we're shut down, I'll have to buy another rack Tuesday and get back into the car next weekend.
I gotta say, I'm finding it hard to concentrate on the Celica lately. Those in the know know I've got my sights set on a different car. smile.gif
1998 Celica GT-
BEAMS Swapped.
post Aug 31, 2013 - 9:07 PM
navseal345
Joined Aug 17, '09
Please use anti-seize on outer tie rods & jamb nuts. I align to many cars with parts rusted together.
post Aug 31, 2013 - 10:38 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Yes we know you got your heart set on that pick ford pinto but I don't think Bridgette will let it stay in the same parking lot as the beams tongue.gif tongue.gif tongue.gif tongue.gif tongue.gif tongue.gif tongue.gif tongue.gif tongue.gif tongue.gif
94 st hatch my daily driver
n
post Sep 1, 2013 - 10:02 AM
Zake
Joined Mar 7, '10
From Ft. Lauderdale
QUOTE (kurt95gt @ Aug 31, 2013 - 9:38 PM) *
post Sep 1, 2013 - 12:32 PM
Droptop93
Joined Aug 20, '11
From Toledo, OH
I've had no issues at all with the speed source cable bushings, also have the base bushings.
post Sep 1, 2013 - 3:26 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
It was nice getting my hands dirty on the beams tho
An great visiting with you guys like always
Oh tell your awesome dad we said thanks for letting us crash in the spare room!
n
post Sep 1, 2013 - 3:29 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (richee3 @ Aug 31, 2013 - 9:01 PM) *
Let me guess, buying a FR-S/BRZ like everyone and their aunt? tongue.gif
2001 Miata LS 5-speed
post Sep 1, 2013 - 4:53 PM
no, hes getting a toyota mark II from the 70's
post Sep 1, 2013 - 5:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
Going to make it better by shoehorning a LS1 into it, right?
post Sep 1, 2013 - 5:51 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (Box @ Sep 1, 2013 - 3:29 PM) *
Absolutely not. Nothing against them or anyone who has one but those just aren't the car for me.
We didn't get a lot done this weekend. Pulled the motor out just to find out I was given the wrong steering rack, but I at least got the new passenger motor mount and poly rear mount insert in. Picking up a different rack Tuesday. So, pictures of the lack of progress!
The top rack is the replacement rack. Bottom rack is the Celica rack. Similar, but totally different.
This post has been edited by richee3: Sep 1, 2013 - 5:52 PM
1998 Celica GT-
BEAMS Swapped.
post Sep 1, 2013 - 7:37 PM
Box
Joined Feb 23, '12
From Warrior, AL
Not to alarm you, but someone replaced your engine with a woman. redface.gif
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 21st, 2025 - 8:18 AM
