get TWM shifter base bushings Probably going to be a silly question but I had a look on their website and didn't see and bushings listed for our cars. I'm assuming it's because I clicked "bushings" and didn't have time to look anymore after that last night. Besides, here's a picture of my shift cables: ![]() The cables themselves aren't frayed, but the plastic sheath is cracking off. Not the healthiest cables I've ever seen. I'm going to try the Torque Solution bushings out when I finally stop being lazy and install them, but I need to replace my cables before they get any worse. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) ![]() |
I ordered mr2 spherical shifter cable bushings and had a machine shop modify my old brass bushings to fit. The mr2 have different size "lobes" i guess you can call it then The celica shifter cables. The spherical ones shift great and feel real smooth when shifting.
The ones I bought came from Australia iirc, but it seems that twosrus has the same set if not very similar. This post has been edited by Ted95: Jan 18, 2014 - 1:23 AM -------------------- st205 powered ss3 coupe
Things have happened.
![]() ![]() ![]() ![]() ![]() Other things will be happening soon. ![]() ![]() ![]() ![]() -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
like.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Sep 23, '12 From Australia Currently Offline Reputation: 4 (100%) ![]() |
Let me know how hard the conversion for that steering wheel control is, I definitely would do this for mine!
Also, where did the black door latch come from!? This post has been edited by rentaspace: Feb 2, 2014 - 12:28 AM -------------------- ![]() ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Wow that bushing was a martir!
Let me know how hard the conversion for that steering wheel control is, I definitely would do this for mine! Also, where did the black door latch come from!? The conversion will either be very very simple or it won't happen at all. The PAC SWI-RC is an interface that will make OEM steering wheel controls work with an aftermarket radio. You need to solder resistors into the buttons inside the steering wheel then program the interface for each resistor to be a specific signal to the radio. So, in theory, it doesn't matter whether the buttons in the steering wheel are labeled as shift buttons or volume/track buttons because the resistor will send a specific signal to the interface. I'm still waiting on a Celica and IS300 clockspring to show up, otherwise I have no way of getting the signal to leave the steering wheel. Here are the closest things to a how-to I can find for the audio controls: http://my.is/forums/f103/steering-wheel-st...ontrols-482897/ http://my.is/forums/f90/isx50-steering-whe...fit-diy-479993/ One of the wheels I bought is a 7gc wheel and the other is an IS300 steering wheel with a Rav4 airbag. My OEM three post wheel will be for sale soon. The door strikers are from a late 90's Lexus ES300. Toyota put Loctite on the screws so I was only able to remove one yesterday, but I took a second cover and put it over my stock passenger side door latch. I'm going back to the junkyard tomorrow with more than just a screwdriver so I can get a second chrome striker from the ES. I just didn't think to take a picture of my driver side after I replaced it. You can find the strikers and covers for ~$20 on eBay, but it's under $2 for the pair at my local junkyard. There are some small tabs on the back of the plastic cover that I had to cut off to fit to my Celica striker, but it's still a very tight fit and it's not falling off. I'd still rather have the chrome Lexus striker so I have a matching pair. Wow that bushing was a martir! It actually looks a lot better than I thought it was going to. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) ![]() |
Wait what? That door striker, I didn't know that existed
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Wait what? That door striker, I didn't know that existed I'm going back to the junkyard Wednesday to get a matching striker. You interested? If nothing else I can send a pair of covers so you'll have what I do on my passenger side right now. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
![]() ![]() http://www.ebay.com/sch/i.html?_trksid=p20...0&_from=R40 And we did it on the Beams as well. Dan, PM replied. This post has been edited by Batman722: Feb 3, 2014 - 10:59 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) ![]() |
Dan, you don't need that many steering wheels, I'll just take one off your hands. lol.
oh yeah and I got those door strikers too. just never took a pic of mine. -------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
I'll be selling my stock three spoke after I get one of the other two installed.
Is there any particular model Lexus the door strikers come from?
Wanna get me a set -------------------- ![]() ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
They're from a late 90's ES300. I'll go to the junkyard tomorrow and barb the few sets they have if I can get them free.
They're from a late 90's ES300. I'll go to the junkyard tomorrow and barb the few sets they have if I can get them free. I would buy a set off you if you did! -------------------- ![]() ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
I like the perforated wheel.
![]() Enthusiast ![]() ![]() Joined Dec 9, '13 From Melbourne, Australia Currently Offline Reputation: 2 (100%) ![]() |
Quick google search, turns out there 1 ES300 at my local junkyard, so looks like im getting a set
![]() This post has been edited by RoadRage: Feb 5, 2014 - 9:49 PM -------------------- |
I'll be selling my stock three spoke after I get one of the other two installed. ![]() but I wants the other ones. ![]() -------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Pro tip: IS 300 steering wheels and clocksprings are significantly cheaper than the Rav4/Corolla/Matrix/Celica steering wheels at the moment. Plenty of auto steering wheels with the shift buttons but a few without.
Got me a set of door strikers now
![]() Lucky too, the whole Lexus was wrecked and ripped apart, but the strikers were there and unscratched -------------------- |
Lo-Fi Version | Time is now: February 17th, 2025 - 3:39 AM |
