![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) ![]() |
So yeah no where around me will bend above the axle at the stupid angle our cars have. But anyway I found this ►►found here◄◄
When I was at my local auto store, and was wondering, can I just use this stupid universal thing, and route it the way my stock goes? Would only be using it to go above the axle (not the whole 5-6ft section). and then use real stainless 2.25 from the cat and res to this bendable pipe. Will it work? and still make the flow better? thanks anyone ![]() This post has been edited by mgnt232: Apr 12, 2010 - 10:56 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) ![]() |
A bit confused by some of the wording. I am surprised that no one did any crimp bending for your new set up. Ive never heard of any muffler shops not doing that. If your asking about running the pipes "under-axle" vs "over-axle" most people on here probably have under (Im just guessing though)
This post has been edited by Spider77: Apr 10, 2010 - 6:35 PM |
Sorry I knew that would be a little confusing, I put up pics, of where my exhaust currently goes, and where I want it to go, because no where around me will bend the pipe? for whatever reason.
bump
Did you even TRY using the search function? Or look through the exhaust thread?
And don't bump your thread more than once a day. 30 minutes is hardly enough time to justify needing to bump your thread. QUOTE QUOTE Does anyone have pics of the under axle system? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
won't the suspension links hit when the wheel drops all the way, such as on a lift?
thats basically what I was asking, I just want to know can I do this? without worrying about it hitting?
thanks -------------------- |
Enthusiast Joined Feb 5, '10 From ireland Currently Offline Reputation: 0 (0%) ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
I miss that car.....
and LOL "under rear axle" -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) ![]() |
won't the suspension links hit when the wheel drops all the way, such as on a lift? maybe that's why the pipe is dented...? ![]() -------------------- |
No, when the car goes on the lift they unbolt the exhaust. The dents are simply where they bent the piping.
Never bottomed out. Never had the suspension hit. No problems. Just ask the shop to route the piping while the car is on the ground. This post has been edited by 95CelicaST: Apr 11, 2010 - 12:56 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
bump
new question -------------------- |
That first pic looks like an O2 sensor that sits downstream for my GT.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) ![]() |
A bit confused by some of the wording. I am surprised that no one did any crimp bending for your new set up. Ive never heard of any muffler shops not doing that. If your asking about running the pipes "under-axle" vs "over-axle" most people on here probably have under (Im just guessing though) I've got over-axle lol -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
yeah the first pic, is what I could buy to replace the second pic (my downstream o2)
I dont think my stock downstream comes apart, which means I have to spend another $50 on that new o2 ![]() -------------------- |
A bit confused by some of the wording. I am surprised that no one did any crimp bending for your new set up. Ive never heard of any muffler shops not doing that. If your asking about running the pipes "under-axle" vs "over-axle" most people on here probably have under (Im just guessing though) I've got over-axle lol Yeah but you've got the SP2. So um.....yeah. Lucky! OK, by upstream and downstream I mean this. I have a GT (which has 2 O2 sensors), one located before the cat (the one that's part of the manifold) and one that's located after. Hence "up"stream and "down"stream. I'm not too sure how it works on an ST (being that I don't have one, and its been forever since I've been under one). I know somewhere on here is some info about this. But as far as my set up goes. I'm only running my upstream O2 sensor (like what you have in your 2nd pic). I've got a downstream but never installed it as the only time I've popped a code was when I was real low on fuel and gunned it. |
yeah the 2nd pic, is of my 2nd o2 sensor (after the prefcat, manifold)
My first and second are both like this, but mine has been welded together (not sure y, or if this is how all of them are) But anyway I bought the first pic, and now I just have to wait for it to arrive, and do the non-fouler. So yours doesnt throw a code with only 1 o2 sensor? Is your other on plugged in still, and just kinda dangling? thanks for any info, as I want to install the headers tuesday when they arrive, but the o2 sensor wont arrive until fri-sat, and dont want to mess up my car by only running one o2 sensor(not sure if any damage can really be done) -------------------- |
yeah the 2nd pic, is of my 2nd o2 sensor (after the prefcat, manifold) My first and second are both like this, but mine has been welded together (not sure y, or if this is how all of them are) But anyway I bought the first pic, and now I just have to wait for it to arrive, and do the non-fouler. So yours doesnt throw a code with only 1 o2 sensor? Is your other on plugged in still, and just kinda dangling? thanks for any info, as I want to install the headers tuesday when they arrive, but the o2 sensor wont arrive until fri-sat, and dont want to mess up my car by only running one o2 sensor(not sure if any damage can really be done) I disconnected it, but bought another O2 sensor to wire in just in case. |
you don't do the non-fouler trick to the primary, only the one after the cat you're eliminating. the non fouler simply spaces the sensor out of the exhaust stream so it sees smaller sample and smaller changes. you can emulate that with other methods.
I dont need to have the downstream o2 sensor?
Lo-Fi Version | Time is now: February 20th, 2025 - 1:56 PM |
