Enthusiast ![]() ![]() ![]() Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) ![]() |
I just tried to install E-bay short shifter (I think 7th gen) in my car and experienced problem - the bottom part of the shifter (from the ball down) is too long:
![]() I'd guess about 1/4 -3/8 inch... The bottom of the shifter is hitting this little bump on the chasis (hard to explain without picture) and won't go to 1st, 3rd and 5th gear. I need approximately 1/4-3/8 inch more clearance. I am already considering buying another shifter (this one was very cheap) but here is a thought: What would happen if I placed 1/4 (3/8) inch spacers under the whole (white plastic) shifter assembly and lifted it up?? Would it negatively affect anything? ![]() This post has been edited by conus00: Apr 10, 2010 - 8:38 PM -------------------- ![]() |
You need aluminum spacers to go between the body and the shifter assembly. Most good shifters come with them - cheap ones do not.
![]() Enthusiast ![]() ![]() ![]() Joined Aug 5, '09 From Oakley, CA Currently Offline Reputation: 15 (100%) ![]() |
^^Yup. Mine did the same thing. I used 2 of the spacers in the back and it works fine, and feels good.
-------------------- 1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver |
You need aluminum spacers to go between the body and the shifter assembly. Most good shifters come with them - cheap ones do not. I saw your post in my other "shifter thread". Do the ones in the link raise the assembly or are they just replacements of the rubber bushings? -------------------- ![]() |
Yep. And if they don't work I'll buy 'em from you.
dude, go cheap,
get some home depot washers and raise as you need it. Thats what i have, 3 washers. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
that ebay shaft should have came with the spacers.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) ![]() |
it could be the spacers, or you could be having the same problem i did with the ball not seating correctly in the cup, when you put the first cup on the bottom was it really snug? see if you can put wood shims under the shifter and put the ball into the cup, this could be your problem
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
ball.... cup... shaft. Heh heh.
The reason why you need the spacer is because the shaft is a bit long, by using the spacer it lifts the shifter assembly higher so that the shaft can sit without rubbing anything, thus makes also the shifter sit lower.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
ball.... cup... shaft. Heh heh. ![]() LOLOLOL!!!! yea if need to have spacers, or some how lift the whole assembly up. -------------------- |
Lo-Fi Version | Time is now: February 22nd, 2025 - 10:02 AM |
