> Swap 3sgte Wiring harness with 5s, Wiring harness for 3sgte swap info
post Apr 13, 2010 - 12:12 PM
celica95-95
Joined Aug 4, '06
From Toronto
Hey guys need help on swap 3sgte in to my 95 5s
Looking to do wiring for harness both are in great shape
does the harness just need 33" add to it or is there more ?
post Apr 13, 2010 - 1:47 PM
SlvrCelica09
Joined Jan 10, '09
From Burtonsville, Maryland
QUOTE (celica95-95 @ Apr 13, 2010 - 12:12 PM) *
Man just chop and screw that mess.
or buy an extender.. I saw one on ebay.. not sure if its still there.
THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma..
6gc.net's outlaw vigilante because im a LEADER not a follower.
post Apr 13, 2010 - 2:46 PM
celica95-95
Joined Aug 4, '06
From Toronto
Thanks
But is there wire's need to add to harness for it to work ?
This post has been edited by celica95-95: Apr 13, 2010 - 2:47 PM
post Apr 13, 2010 - 3:38 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
this is also covered in the stickies, look under 3S swaps and posts by Dr Tweak
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 13, 2010 - 5:55 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
What gen 3s??
Any other gens besides the gen 3 you will need to take the wiring part of the engine sensors on the 3sgte engine and incorporate that into the chassis wiring from the 5s.
94 Celica gt white (sold)
post Apr 13, 2010 - 8:27 PM
celica95-95
Joined Aug 4, '06
From Toronto
IT'S is 3rd gen 3s, I got 95 5s
So would just add wire to make it long do the job
Thanks
post Apr 13, 2010 - 8:50 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
No, you would still need to some wiring on the clutch start sequence, fuel pump, and intercooler. After that...either cut a new hole, or extend the harness as you had mentioned.
330whp 309ft/lbs @ 21 PSI
post Apr 13, 2010 - 9:00 PM
SlvrCelica09
Joined Jan 10, '09
I think we need a 3rd gen swap sticky so these questions won't be repeated as much..
To do list for a 3rd gen swap after you got the motor (not in any order):
- check the how to on doing and 2nd gen 3sgte swap (defgeph) http://www.6gc.net/forums/index.php?showtopic=28825
- Maintenance. check what sensors, hoses, parts, and etc that needs to be replaced.
- make sure you have the wiring done( clutch start sequence, relays for fuel pump, IC pump, and IC)
- extend the wiring harness or drill a hole in the firewall so it can reach the ECU
- mount heat exchanger, IC pump
- install custom exhaust
- make sure all hoses are plugged in
- check for vacuum leaksl
- make sure map sensor is connected
- check to make sure black ground wire is connected to exhaust manifold
Do these things before you post questions.. it will go a long way thumbsup.gif
post Apr 13, 2010 - 9:15 PM
celica95-95
Joined Aug 4, '06
From Toronto
Thanks for the replies for clutch start sequence, fuel pump intercooler ic pump what wiring is need ?
I have looked and looked for answers can't find only 2 ng gen 3 sgte swaps
Info
Plus in Canada Doing up Toyota are not seen to much so find answers are hard
I have done all other steps I curently hav 3rd gen 3s front clip and just looking for some help on the wiring harness
Thanks
post Apr 14, 2010 - 2:17 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Would be nice if SOMEONE actually made a wiring guide vs Look at the Stickies! or send it to Dr.Tweak!
post Apr 14, 2010 - 2:06 PM
QUOTE (celica95-95 @ Apr 13, 2010 - 10:15 PM) *
Thanks
Thats the stuff you need to rewire to make the car work. You can do those things with the engine in the car and pretty much put it last on the todo list.
However youll notice that the jdm harness enters through the firewall on the opposite side as it should on your usdm car. To fix this you dont have to extend the whole harness. You can do one of 2 things: 1. cut a new hole in the bottom center of your firewall so that the wiring will reach directly to the ecu, or 2: unwrap the entire harness and "flip" the part of the harness so that it reaches to your existing hole. After you flip it, youll only have to extend a few wires to things like the igniter.
If youre good with wiring, then pick option 2 and you'll end up with a cleaner install, but if you want a quick and simple way, then just cut a new hole.
post Apr 14, 2010 - 2:25 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
sorry to threadjack but,
I noticed some engine sets come with uncut harnesses and some are cut. Is the cut harness garbage or if I sent it to Dr. Tweak with my 5sfe harness would he be able to make it work?
post Apr 14, 2010 - 2:57 PM
celica95-95
Joined Aug 4, '06
From Toronto
So when ur talk re-wirin to make thing's work and I can do when the motor is inn what is it that need to be done?
I am not big on cutting holes in car so extending is a good
post Apr 14, 2010 - 5:39 PM
SlvrCelica09
Joined Jan 10, '09
QUOTE (celica95-95 @ Apr 14, 2010 - 2:57 PM) *
I'm not sure what you're asking. What needs to be done when the engine is in the car is the wiring which is the clutch start.. etc.. things we have told you before. If you're wondering how to do these things check other threads.
Clutch start sequence check this thread: http://www.6gc.net/forums/index.php?showtopic=55058
Theres a helpful how to and a picture that shows what needs to be done
Fuel pump, IC and IC pump wiring check my thread: http://www.6gc.net/forums/index.php?showtopic=66773
There fuel pump, IC, and IC pump wiring diagrams are there.
Another thing, get your hands on a 3rd gen ST205 engine manual, as well as body and chassis manual.
post Apr 17, 2010 - 5:46 PM
celica95-95
Joined Aug 4, '06
From Toronto
right on thanks that's help alot
for that relay fuse box with the inter-clr and fuel pump , did u wire your in too the harness or the fuse box of the 5s?
Thanks
post Aug 6, 2010 - 4:04 PM
Iceman22
Joined Dec 16, '08
From Norway
QUOTE (lagos @ Apr 14, 2010 - 3:06 PM) *
Thanks
Hi, about the 2 option with unwraping the harness.
Are you sure it will be long enough after unwraping it ?
- Celica ST202 w/ JDM 3S-GE 180HP (Special LE Subaru Blue steel paint!)
- A video of my car, before & after: Click here
post Aug 6, 2010 - 4:30 PM
QUOTE (Iceman22 @ Aug 6, 2010 - 5:04 PM) *
Thanks
it wont be.
youll have to extend maybe 30 wires.
my swap thread has good info on the wiring.
post Aug 6, 2010 - 6:03 PM
Iceman22
Joined Dec 16, '08
From Norway
Ok, so I guess you confirmed that the wires HAS to be extended in order to get it work.
Thanks, your swap thread really helped me with the wires... to bad it is so such hard and boring work with the wires tongue.gif
post Aug 6, 2010 - 6:19 PM
QUOTE (Iceman22 @ Aug 6, 2010 - 7:03 PM) *
post Aug 6, 2010 - 6:26 PM
Johnnyny
Joined Apr 28, '09
From York pa
didnt batman skip it ?
Lo-Fi Version Time is now: February 20th, 2025 - 3:09 PM
