516 Pages V  « < 80 81 82 83 84 > »
post Mar 19, 2011 - 8:44 PM
block
Joined Jul 27, '06
From Soda
5zigen fn01rc hv's went on my is300. fronts are flushed as hell, rear were very close to flush also. megan springs and tokiko struts going on next week. 2" drop around should finish the look smile.gif
asa ar1's went on my celica, i loved it. just wished it was lower kindasad.gif
This post has been edited by block: Mar 19, 2011 - 9:09 PM
post Mar 19, 2011 - 10:11 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Remember to roll your fenders!!!!!! im still working on rolling mine, baseball bat ftw!
2001 Solar yellow Lexus IS300
post Mar 19, 2011 - 10:43 PM
block
Joined Jul 27, '06
From Soda
i might have to if i feel the need to, but a lot of is300 guys didn't have to roll their fenders with this kind of setup.
post Mar 19, 2011 - 11:19 PM
DGolden32
Joined Apr 28, '09
From Auburn, AL
QUOTE (block @ Mar 19, 2011 - 8:44 PM) *
Pictures of ar1's on the celi!
post Mar 20, 2011 - 12:35 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Fixed crossmember mounting, and installed new cv halfshaft! Best 6 hours ever!
post Mar 20, 2011 - 2:20 PM
chacha
Joined Dec 29, '05
From So-Cal
what was wrong with the crossmember...put in wrong?
post Mar 20, 2011 - 2:30 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Nah, the bolts stripped, and the nut thats hardwelded in well, obviously stripped as well. Buts its cool, I removed radiator, moved the condenser out of the way, drilled up (thank god for air drills), made a plate, ran some grade 8 bolts though with locknuts. Problem solved.
post Mar 20, 2011 - 8:01 PM
mkernz22
Joined May 10, '10
From MA
hit 221k and found this when I was rotating my tires: (No, I'm not concerned about the PS fluid everywhere).
This post has been edited by mkernz22: Mar 20, 2011 - 8:02 PM
post Mar 20, 2011 - 9:12 PM
chacha
Joined Dec 29, '05
From So-Cal
nightmare...what happened?
post Mar 20, 2011 - 9:18 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (chacha @ Mar 20, 2011 - 10:12 PM) *
I'm hoping that the one out of my parts car is still good, if not then I'm getting one made and welded in! (on both sides)
post Mar 20, 2011 - 9:21 PM
chacha
Joined Dec 29, '05
From So-Cal
replaced trunk weatherstrip, door panel weatherstrip, jet nozzles, clutch master, clutch cylinder, new motor mounts and insert the kirk inserts placed in, replace old carpets, starter, pcv hose since it was harden, pcv valves, pcv grommet, new axles for both DS/PS, lights changed to led, changed the washer water pump for the windshield reservoir, did an alignment and still can't get it right accordingly to the mechanic said at least it won't wear the tread as much but it still will...damn...
Im exhausted and money broke because of these small replacement for an OLD beautiful 1994 celi...bushings and front end links next with a new front window replaced because there's a giant crack from one side to another...
any idea why our REAR nozzle doesn't work as well...i replaced with the volvo jet washer nozzle, but it seems to be weak at spraying...the fronts worked great but the rear sucks....i thought if i replaced the washer pump, it should work...clean out the lines as best as i can and I still got nothing. any help of suggestion?
QUOTE (mkernz22 @ Mar 20, 2011 - 9:18 PM) *
thumbsup.gif Be safe
This post has been edited by chacha: Mar 20, 2011 - 9:23 PM
post Mar 20, 2011 - 11:16 PM
richee3
Joined Jun 29, '08
From Denver
Chacha, I've owned 2 hatches and both had a weak rear nozzle. I don't think it's anything wrong with your car but because the nozzle is above the window and it isn't like you're getting bugs smashed against the back window, there isn't any need for a lot of pressure. That's my guess, anyway.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 21, 2011 - 1:22 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
today i spent hours and hours washing, polishing, waxing, vacuuming, detailing my car in readieness for a magazine photoshoot tomorrow
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Mar 21, 2011 - 1:40 AM
TRDGT4
Joined Mar 3, '08
From New Zealand
QUOTE (Cuts_the_Pilot @ Mar 21, 2011 - 2:22 AM) *
_______________May COTM 2011_______________
post Mar 21, 2011 - 1:58 AM
S8S8
Joined May 9, '09
From Brisbane, Australia
Ordered a set of JDM tails and a new timing belt for the Beams.
post Mar 21, 2011 - 2:34 AM
chacha
Joined Dec 29, '05
From So-Cal
QUOTE (richee3 @ Mar 21, 2011 - 12:16 AM) *
it was just a small perk if the washer jet in the back worked just as well as the fronts do....i don't think there is much pressure the washer pump can provide.
post Mar 21, 2011 - 9:20 AM
Neon90424
Joined Jan 19, '11
How much should I pay for a 1994 WRC ST205 ?? guy said 9500$
post Mar 22, 2011 - 1:20 AM
Artega
Joined Apr 2, '07
From Calgary, Alberta
Switched out the fig 8 on both side of my car.
I'm surprised the figure 8 didn't fall out from the assembly with how much it's moving.
I definitely felt a lost of grip when I was driving her.
It's all better now.
post Mar 22, 2011 - 1:47 AM
MacgibaS2
Joined Dec 14, '08
From La La Land..
blew a rear tire on my vert due to low compression.. replacing in the morning.
Stay Conscious and Aware -
Do not decide who to trust, decide which ideas to trust.
post Mar 22, 2011 - 4:36 AM
zfjohnson07
Joined Apr 11, '09
replaced right cv axle, pain in the butt, uggh....
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 27th, 2024 - 2:15 PM
