516 Pages V  « < 91 92 93 94 95 > »
post May 18, 2011 - 8:33 PM
QUOTE (Culpable04 @ May 18, 2011 - 9:30 PM) *
sadly it is,
I was on the left lane on route 17, when a white SUV in hte middle lane, cut me off, I touched the brakes and the car hydroplaned and spun out, hit hte curb, took a bus stop shelter off and came to a stop, after I got the car home I inspected and seems like the chassis is pretty damaged, the rear hatch has gaps on both sides and closes crocked, so I'm assuming tomorrow the insurance guy will total it.
in any case, before anyone ask, no I wont part the car out, I will buy it back from the insurance company and try to find a clean shell to start over.
A car is a car, but we are all glad youre ok!
post May 18, 2011 - 9:10 PM
F*cking sheet that's something, Stevenson. Best of luck resolving it, what a shame though...
post May 19, 2011 - 2:51 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Got my flywheel back today from the machine shop... not a bad way to invest $50
From this:
To this:
More details here: Tranny Swap
post May 19, 2011 - 5:40 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Tried to install my fogs today, only to have one of the bolts that secure the brackets to the crash bar snap off.... mad.gif I threw a lot of sh!t around. So reluctantly I put everything back together, and now I need to find a way to extract that bolt.
June '12 COTM
'95 AT200
post May 19, 2011 - 5:50 PM
wow Stevenson, glad you're ok.
Looking forward to seeind v 2.0
post May 19, 2011 - 6:36 PM
97lestyousay
Joined Jul 7, '03
that sucks stevenson, glad you are ok.
JDM guy made me do it.
post May 19, 2011 - 6:48 PM
CrimsonSTX
Joined Jun 9, '07
From Miami, FL
Today I ordered new engine mounts, sparkplugs and thermostat. Will be changing all that out next week.
sadly it is,
Wow, glad you are ok man. Also glad you aren't parting out the car, keep the dream alive biggrin.gif
This post has been edited by CrimsonSTX: May 19, 2011 - 6:52 PM
post May 19, 2011 - 6:59 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Even though i dont know you, sucks to hear that your car got totaled...BUT, on a positive note, would be great to see your next build thread ^_^
Btw, today i continued to Spec out by engine build. Somehow im keeping the cost right under 10k...although i know ill end up spending an extra 2k on little things that come up, but meh, thats all part of planning right?
here is the list..if you want PM what you think is un-neccessary...or any tips/ideas...its just a rough list right now anyways...still a year out before i start on this...
2012 engine build
BOTTOM END
Moroso Drag Race Oil Pan Toyota MR2 MR-2 3SGTE 2.0L Turbo = 350
ARP Main Studs Toyota MR2 Celica 3SGE 3SGTE 2.0L = 100
ARP Headstuds Toyota MR2 Celica 3SGE 3SGTE 2.0L = 150
GENUINE TOYOTA CRANKSHAFT BEARING KIT = 30.00
GENUINE TOYOTA PISTON BEARINGS KIT = 78.00
CRANKSHAFT THRUST WASHER = 46.00
Cometic Complete Bottom End Gasket Kit 3SGE 3SGTE MR2 Celica = 63
Cometic Headgasket Toyota 3SGE 3SGTE MR2 Celica 2.0L = 100
252062 3SGTE 86.50mm (.020" 1.0mm overbore) = 785.00
Total = 1702.00
TOP END
Kelford 258/258 Turbo Cams 3SGE 3SGTE MR2 Celica Gen2/Gen3 = 550
Brian Crower Single Valvesprings Ti Retainers Toyota 3SGT 3SGTE = 217
Brian Crower Stainless Steel Valves Toyota 3SGT 3SGTE MR2 Celica = 287
Supertech Valve Seals Toyota 3SGE 3SGT 3SGTE MR2 Celica = 20
AEM Cam Gears = 132.00
ATSRACING phenolic intake spacer = 85
ST246/3SGTE cylinder head gasket kit (PN - 04112-74860) = TBD
GENUINE TOYOTA VALVE LIFTERS = 37.00
Total = 1291
TURBO
http://www.emspowered.com/storefront/index.php?main_
page=product_info&cPath=61_62_64_118&products_id=474
EMS Borgwarner Turbo kit above = 3770
FUELING
Gen III TFFR Polished w/ Delphi 96 lb/hr Inj. + Clips = 721.
3S-GTE Gen III w/ Injector O-rings = 20
SX 15404-9 EFI Regulator (AN-6)= 148
Standard Kit - Universal with mounting plate = 197
Aeromotive fuel pump = 180
Total = 1266
COOLING
Mishimoto aluminum radiator = 360.00
Dual electric fans = TBD
Swirl pot/header tank = TBD/??
silicone radiator hoses = TBD/??
Intercooler/turbo lagging = (budget of 200.00)
7 row engine oil cooler (siliconeintakes.com) = 50.00
22-480 - OIL COOLER THERMOSTAT (Canton Racing) = 210.00
Oil filter adapter (Canton Racing) = 100.00
Samco Xtraflex Air & Water Straight Silicone Hose = TBD
GENUNIE TOYOTA OIL PUMP = TBD
Total = 920 (+TBD AMOUNTS)
ENGINE WORK
cylinder cleaning and polishing
boring and honing
block cleaning
Total = To be determined
ENGINE MANAGMENT
Aem twin channel ignition = TBD
Megasquirt ECU = TBD
HKS EVC5 = TBD
Apexi power FC (http://www.tcsmotorsports.com/appofcenmasy.html) = 1000.00
Innovate/AEM a/f Gauge = TBD
Various gauges = TBD
TRANSMISSION
OS Giken STR Clutch Kit = 2000
J-speed clutch line = 100
Trd shortshifter kit = 300
Mfactory Front/center LSD = TBD
(\__/)
post May 21, 2011 - 11:27 AM
mak5603
Joined Oct 20, '08
Today my car got hit and run at work. Nothing like walking out and seeing a ****ed up gt4 bumper and hearing that your alarm was almost triggered..how motivating.
2014 Toyota Rav4 XLE
post May 21, 2011 - 6:56 PM
jtmlb3k
Joined Jun 11, '10
From Los Angeles
Finished my 4200 mile drive zig zagging across the country. Then I gave my car a much needed wash.
post May 21, 2011 - 7:12 PM
chacha
Joined Dec 29, '05
From So-Cal
QUOTE (mak5603 @ May 21, 2011 - 12:27 PM) *
hopefully you find out who that punk is at work....shouldn't be too hard to find a car with wreckage on it.
This post has been edited by chacha: May 21, 2011 - 7:12 PM
post May 21, 2011 - 7:35 PM
mak5603
Joined Oct 20, '08
QUOTE (chacha @ May 21, 2011 - 5:12 PM) *
Won't ever happen unfortunately. frown.gif I work right next to a nail salon and there's (no offense to anyone...) stupid girl drivers in and out all day. The damage on my car is just paint damage so I guess it could be worse. Now just more incentive to get every single ding taken out of the body and repaint it.
post May 22, 2011 - 2:35 AM
Rusty
Joined Nov 5, '07
From New Zealand
went for a spirited drive, pulled over popped my hood and touched my intake plenum... it was cold biggrin.gif biggrin.gif biggrin.gif biggrin.gif yay it works
post May 22, 2011 - 12:16 PM
3WayStunna
Joined Jun 25, '06
QUOTE (Rusty @ May 22, 2011 - 3:35 AM) *
If you dont mind me asking, but what works?
(\__/)
post May 22, 2011 - 3:02 PM
Neon90424
Joined Jan 19, '11
airconditioning into the engine ofcourse! XD
post May 22, 2011 - 3:18 PM
KAOS
Joined Apr 18, '06
QUOTE (Neon90424 @ May 22, 2011 - 2:02 PM) *
Wow. Details please!
post May 23, 2011 - 12:05 AM
travisxcore
Joined Mar 24, '11
From 704
Had to get my car towed today...was very upsetting.
*Warning long drawn out story*
I was talking to my girlfriend when I noticed I was going slow so I steped on the pedal and nothing happened so I was just rolling down the road trying to start my car and it would not turn over. I seriously thought my engine just straight up seized and locked up on me at first. Spent 2 hours and 40 bucks trying to figure out what the **** was wrong with it. First thought was my left fan stopped working again and it had overheated causing the engine to just abruptly stop (no hesitation, putter, or anything it just stopped). Then my bud that I had bought the car from said that he had a problem like that once and it was caused by a fuse. So he came by and after looking for 20 minutes he remembered which one it was. So we thought the 2 pink 30amp fuses were completely blown so I went to Walmart since it was late and had to buy 2 kits just to get the 2 fuses I needed which was expensive as ****. Placed them in and still nothing. But after ****ing with them a bit it cranked right up no problem but when closing the hood it shut off. So it was around then we realized that one of the hookups for the fuses most have been loose and after fiddling around and trying to start the car we found out which one it was. But still the car wasn't drivable as the fuse would move out of the "sweet" spot and shut off and I had to get it towed (Triple A which was only 6 bucks so that wasn't bad at all). So tomorrow I'm gonna talk to the guy that replaced the bumper on the car when it was my friends and still if he has that Celica so I can take his fuse relay box.
tl;dr My fuse box is ****ed and I got my car towed back to my house for 6 bucks.
This post has been edited by travisxcore: May 23, 2011 - 12:07 AM
post May 23, 2011 - 1:53 AM
Rusty
Joined Nov 5, '07
From New Zealand
QUOTE (3WayStunna @ May 23, 2011 - 5:16 AM) *
My cold airbox, details in my SS-II thread.
post May 23, 2011 - 6:27 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
installed megans in the rear and full slammed it.........couldnt get the jack out even with ramps. i was forced to raise it. went for a drive and the back slides out easily.
post May 23, 2011 - 6:50 AM
Neon90424
Joined Jan 19, '11
you had to get your car towed and that was upsetting? hows about a breaking the bar that holds the rear wheel straight 20 miles out of town and the car is 4wd so that meant when I floored it the car would go sideways! laugh.gif
had to wait 1 hour for the tow truck and take an hour and a half trip into town where my mechanic lives and then hitched a ride with my guard's brother's car an old ford falcon with only 6 bucks of gas to go 30 miles O_O! and it had no radio
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 17th, 2025 - 6:36 AM
