Today I.......................................... |
Jun 20, 2011 - 7:58 PM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
Installed some brembo blanks and oem Toyota pads in the rear today.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Jun 21, 2011 - 10:36 AM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Managed to work the endlink off without breaking it.
Removed the control arm. And got all of the control arm bushings out with a drill, torch and hammer. Now to wait for the Poly Urethane bushings to arrive. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 21, 2011 - 1:58 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Mother' Showtime quick detailer on the whole car, polished my Truck tip, tire shine on...................and taking the swagger van to work
Damn garage queen... This post has been edited by 808celica: Jun 21, 2011 - 2:00 PM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 21, 2011 - 5:59 PM |
Enthusiast Joined Aug 2, '10 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
I've only recently revisited 6GC.net but have done a number of things since being away:
Oil pump + gasket Waterpump + gasket Valve cover gasket Oil and fuel filter Timing belt Spark plugs and cables Throttle body cleaned Flush and change all fluids (MASSIVE difference!) Cut and polish - discovered I'm well overdue for a respray... Removed boot trim, centre console, CD player, lifted carpet and back seat to rip out all of the mega-dodgy wiring the previous owner installed (about half a kilo or more, WTF?) Removed power antenna and replaced with manual telescopic Diagnosed why the foglights don't work - removed them and their dodgy melted problem-causing wiring Diagnosed and fixed the radiator fan not coming on Attempted to diagnose a/c not working - seems to be compressor issue (maybe!?) err.. Registered in my new state Still lots to do, I've barely started. At least my major service is over and done with |
Jun 21, 2011 - 8:48 PM |
Enthusiast Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) |
10mm and 15mm spacers arrived today.
Jun 21, 2011 - 9:38 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Took off my front bumper (what a freaking nightmare of rusted bolts) to take out my lights in order to black them out and fix the leak issue with the driver side high beam. Trying to figure out if I want to boil them or not.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jun 23, 2011 - 6:32 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Found out that my thermostat is stuck open after replacing my radiator and upper/lower hoses
This post has been edited by HectortheRican: Jun 23, 2011 - 6:33 PM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Jun 24, 2011 - 3:47 AM |
Enthusiast Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
Got my kirk motor mount inserts today!..
And my sub and amp is installed.. And a car wash -------------------- 6gcHeroes:808hectortimmybatmandiegotigamak |
Jun 24, 2011 - 8:48 PM |
Enthusiast Joined Nov 27, '09 From New Zealand Currently Offline Reputation: 1 (100%) |
Purchased some lock nuts for the 18inch Konig Unknowns on my 94 GT4. Less than 2 weeks since I started parking it outside and someone stole a nut already.
This post has been edited by Quidam: Jun 24, 2011 - 8:48 PM |
Jun 26, 2011 - 7:27 PM |
wired in my gt4 fogs, finally.
+ bolted my intercooler pump relay box in its proper spot. This post has been edited by Fate: Jun 26, 2011 - 7:28 PM -------------------- |
Jun 26, 2011 - 8:07 PM |
Enthusiast Joined Jul 7, '06 From Los Alamos, NM Currently Offline Reputation: 1 (100%) |
Ran into oil pressure problems on the Z
But on the lighter side of things I installed 10.7b DP4. -------------------- 2015 Subaru WRX. World Rally Blue/Black
2001 Honda S2000. Spa Yellow/Black |
Jun 27, 2011 - 12:56 PM |
Enthusiast Joined Jan 30, '11 From Albany, NY Currently Offline Reputation: 4 (100%) |
cleeeeeeeaned the car, thinking of putting in a cold air feed to stock intake hole =p
-------------------- Power in Balance 90 ST coupe- Sold 95 ST hatch- Dead :’( 02 Impreza RS- DD |
Jun 27, 2011 - 2:19 PM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
Bought new brake pads, calipers and hardware, and an exhaust manifold gasket. After installation of this stuff; I will be having the trans., brake, and power steering fluids replaced.
Creeping up on 150,00 miles... This post has been edited by Keiri: Jun 27, 2011 - 3:39 PM -------------------- Has no more Celicas
Jun 27, 2011 - 5:21 PM |
Enthusiast Joined Mar 18, '11 From Southern Oregon Currently Offline Reputation: 0 (0%) |
Jun 27, 2011 - 6:49 PM |
took my hub off after my wheel bearing has been clicking for a while now... (no play surprisingly)
getting the wheel bearing, seals, and snap ring all replaced tomorrow morning! This post has been edited by mkernz22: Jun 27, 2011 - 6:50 PM |
Jun 28, 2011 - 10:12 AM |
wanted to beat the **** out of someone for setting off an M80 a few feet from my car around 2am
Jun 28, 2011 - 10:51 AM |
Installed my new Vincent fuel door and painted the cap super white II to match my car. Also epoxy painted my new Koni struts to prevent rust.
Jun 28, 2011 - 1:29 PM |
Enthusiast Joined Oct 16, '09 From Norway Currently Offline Reputation: 0 (0%) |
Started my 3SGE swap !
Jun 28, 2011 - 6:23 PM |
Enthusiast Joined Feb 26, '11 From beaufort,SC Currently Offline Reputation: 0 (0%) |
found a job, now i can order some parts.next friday..unemployment checks suck for car mods..........
Jun 28, 2011 - 7:32 PM |
Did this today:
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:53 PM |
