Today I.......................................... |
Oct 24, 2011 - 12:04 PM |
Enthusiast Joined Oct 7, '10 Currently Offline Reputation: 3 (100%) |
Jacksonville, not many Celis around here that I have seen.
Started installing my Vincent interior. Going to be a slow process between school work and girlfriend, things are gonna be tight. Anyone have any advice with the armrest cover from Vincent, I saw Malpaso's guide, but I figure there has to be an easier way than making holes and stretching strings across to get it to fit properly. Also, during that trip I noticed that my CC is not working properly 100% of the time, I have to set the speed many times before it will take. I am fairly positive that it isn't the stalk itself, as I just wired that up and all the resistances are doing what they are supposed to be doing, I suspect either the CC ecu, or the wiring (maybe the switch on the brakes, but I am not sure about that). This post has been edited by Arsaces: Oct 24, 2011 - 12:06 PM |
Enthusiast Joined May 15, '09 From yonkers, NY Currently Offline Reputation: 8 (100%) |
i did it with string but contact cement might work fine. but i have mine for like 2-3yrs with the string method.
-------------------- *Thing i want for my car(i wish i had money)*
-light blue tint (next step will do this right after i get my paint job) WTB Reasonably priced Projectors just Lows |
Oct 24, 2011 - 12:15 PM |
Thanks for the tip Spy, maybe I will try the string method then if yours has lasted all this time. I put the leather cover on one of my headrests, and I am pretty happy with the results, I can't wait to see the whole interior done.
Oct 24, 2011 - 1:03 PM |
if your going to do that i suggest nylon string and don't cut the holes near the edge there should be plenty of room in there just to be safe and pull it just tight (not TOO tight but enough) i used this its thin and strong
(random picture( -------------------- *Thing i want for my car(i wish i had money)*
Oct 24, 2011 - 5:01 PM |
Will do, thanks for the advice bud.
Oct 24, 2011 - 7:59 PM |
I've had mine using the string nearly as long as Vince has been selling the armrest cover, and I did a second one that way a couple of years ago. It's tried and true. Once you screw the armrest back together, that helps tighten it up and secure it.
Oct 26, 2011 - 1:19 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
... I made room:
Pick up the new engine on Saturday! Yay! This post has been edited by KAOS: Oct 26, 2011 - 1:20 PM -------------------- |
Oct 28, 2011 - 3:02 PM |
Received and installed my 4 gauge amplifier wiring kit, generally tidying up the install like I've always wanted to. Proper wiring, and also tying down the sub box so it doesn't slide around and end up in my neck when I'm braking.
This post has been edited by SwissFerdi: Oct 28, 2011 - 3:02 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Oct 28, 2011 - 4:19 PM |
Enthusiast Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
Went to my local sk8 park and tore up the mini ramp for a bit, lol
-------------------- From Japan to Texas my st202 follows me.
Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Oct 29, 2011 - 9:45 PM |
today i drifted .................
in the bad way and couldn't install my underbody panel all cuz of .... i don;t know about anywhere else but it snowing already in October and this much no bueno also im now on the hunt for 4 good winter tires i learned that today. -------------------- *Thing i want for my car(i wish i had money)*
Oct 30, 2011 - 2:50 AM |
yeah, I got hit with the snow all the way over in dartmouth, ma. finally turned over from rain around 1a.m.ish
Oct 30, 2011 - 1:56 PM |
Wow, that's pretty early for snow indeed. Lucky.
Washed and waxed the Celica this afternoon. This was the first time since she's been back from the body shop, so it's nice to see a clean and undamaged car again. The right fender still needs attention as the previous owner presumably rubbed the bottom edge, where it meets the bumper, against a curb. There are also two quarter-sized dents. Otherwise, the car is wonderful to look at. Tomorrow, center-cap hunting will occur. I figure I can find a few '06-'09 Corollas wrecked in a junkyard... I'm hoping to arrange a camera soon, so I can actually post worthwhile pictures instead of simply spewing stupid sentences all the time. This post has been edited by SwissFerdi: Oct 30, 2011 - 2:11 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Oct 31, 2011 - 2:28 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Wow, that's pretty early for snow indeed. Lucky. Washed and waxed the Celica this afternoon. This was the first time since she's been back from the body shop, so it's nice to see a clean and undamaged car again. The right fender still needs attention as the previous owner presumably rubbed the bottom edge, where it meets the bumper, against a curb. There are also two quarter-sized dents. Otherwise, the car is wonderful to look at. Tomorrow, center-cap hunting will occur. I figure I can find a few '06-'09 Corollas wrecked in a junkyard... I'm hoping to arrange a camera soon, so I can actually post worthwhile pictures instead of simply spewing stupid sentences all the time. Yup that's pretty early for snow.........already installed my winter tires and dropped the car more. Getting REALLY cold here too *sigh* -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Oct 31, 2011 - 6:03 PM |
I installed front toyota brake pad shims. aaahhh what a relieve. no more squeaky brakes!!
Nov 4, 2011 - 9:39 AM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
today i drifted ................. in the bad way and couldn't install my underbody panel all cuz of .... i don;t know about anywhere else but it snowing already in October and this much no bueno also im now on the hunt for 4 good winter tires i learned that today. Check out Hankook Winter IPike tires. I'm running a 195/55/15 on my factory gt wheels. Best traction I've ever had and they're studable. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Nov 4, 2011 - 7:49 PM |
how much those go for and where can i get them? im not looking too spend too much but i wan't good grip for snow like i said these are just going to be winter wheels so basically beaters
This post has been edited by spy00005: Nov 4, 2011 - 11:21 PM -------------------- *Thing i want for my car(i wish i had money)*
Nov 4, 2011 - 10:52 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
got my cashiers check for my next purchase...
Nov 5, 2011 - 12:46 AM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
continued soaking my valvetrain in simple green im preparation for machining
Nov 5, 2011 - 6:06 AM |
Enthusiast Joined May 31, '11 From Ljubljana, Slovenia Currently Offline Reputation: 0 (50%) |
I cleaned my car all over, on the outside and inside. Damn rims, they took me almost 20 minutes
Nov 5, 2011 - 8:31 AM |
got my cashiers check for my next purchase... WINRAR!!!! -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Lo-Fi Version | Time is now: November 26th, 2024 - 12:33 AM |
