Today I.......................................... |
Jun 4, 2010 - 6:09 PM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
currently getting the car smogged after fiddling with miscellaneous items =P
-------------------- Pandelica 2.0 in progress. |
Jun 5, 2010 - 9:59 AM |
Enthusiast Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
last night I attempted to change out my wheel studs for longer ones. The fronts were quite easy as the hub has one spot with a notch in behind it, it was just a matter of filing down the splines a bit in order to get them seated.....the back however was a nightmare.
After stripping two puller bolts and cracking the hub part of the disc (right beside the threaded hole) I had to disassemble the handbrake assembly through the tiny access hole before I could get it off. Then of course there is only enough clearance behind the studs to punch them out and put same length ones back in....not 15mm longer. After a while of cursing I finally figured out I would have to cut about 2 threads off each stud and round the edge just a bit. Then wedge it between the hub and the hole and twist the wheel with a big prybar, then tap the stud sideways with a hammer and it would finally pop in. I had tho chase the threads on the first couple but after that I got the hang of it. Then reassembly of the handbrake mechanism is a whole 'nother job in itself (it felt very simple after what I just went through) I haven't even taken the wheel off the other side yet....I guess I will have to face it this morning -------------------- ST205 Crew represent
Challenge Accepted |
Jun 5, 2010 - 12:08 PM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
Getting fuel filter, dizzy cap, and rotor in the car.
Probably ordering front wheel bearings and seals, water pump, and thermostat...maybe even oxygen sensors. Gotta love summer maintenance! -------------------- Has no more Celicas
Jun 6, 2010 - 8:32 PM |
Purchased front wheel bearings, front wheel seals, thermostat and gasket, water pump and gasket, and Denso oxygen sensors, and NGK Iridium IX spark plugs.
Put the spare tire cover back in the trunk after half a year. -------------------- Has no more Celicas
Jun 7, 2010 - 12:57 AM |
Enthusiast Joined Jun 2, '10 From Davenport, Florida Currently Offline Reputation: 0 (0%) |
i washed my baby... but i do that everyday (black looks horrible dirty) i also bought 6.5 component speakers and matching adapters for the doors after they arrive will have just 2 more blown speakers to change lol.
Jun 7, 2010 - 2:56 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
bought some h3 8000k hids for my fogs and got some new front turns
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Jun 7, 2010 - 2:57 PM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
waiting for the brown man to get here...
Jun 7, 2010 - 5:42 PM |
Purchased front wheel bearings, front wheel seals, thermostat and gasket, water pump and gasket, and Denso oxygen sensors, and NGK Iridium IX spark plugs. Put the spare tire cover back in the trunk after half a year. Maintenance FTW! -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jun 7, 2010 - 7:49 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
well its not "today" should've posted last night......
a mountain jumped at me -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 7, 2010 - 8:12 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
well its not "today" should've posted last night...... a mountain jumped at me please dont tell me the mountain om nom nom'd your celica. today i got a balance and rotate! -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Jun 7, 2010 - 8:13 PM |
today i... walked by my swap, and had to go change my pants.
Jun 7, 2010 - 8:27 PM |
Today i finally got my wheels on but i broke a stud and too late to replace it will do tomorrow first thing
Jun 7, 2010 - 8:29 PM |
well its not "today" should've posted last night...... a mountain jumped at me Oh, no Jon... How bad is it? -------------------- Has no more Celicas
Jun 7, 2010 - 11:54 PM |
I see you got your car lifted. Sorry to hear about your car, Jon, whatever may be wrong with it. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jun 8, 2010 - 1:42 PM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
Today i (well yesterday, its still morning) drove two and a half hours to pick up a white passenger side fender to replace my crappy one. Then i brought that to my co workers shop along with my GT4 Front Bumper, Hood, Front and Rear Splitters and painted em Picking the stuff up tonight, installation tomorrow. Also recieved the final parts to finish maintenance on my Alltrac. was a good day.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Jun 8, 2010 - 3:48 PM |
installed and wired the WRC heat x sprayers
Jun 9, 2010 - 1:57 PM |
Today I am putting a down payment on a 3rd gen 3sgte from _Jim_ Goin on vacation soon, so getting the motor when i get back. Also throwing my GT4 Front end on today.
This post has been edited by mak5603: Jun 9, 2010 - 4:15 PM -------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
Jun 9, 2010 - 6:45 PM |
currently doing my radiator flush, gonna wait for it to get good and clean then replace my thermostat with an oem one and some toyota red antifreeze, along with sone prestone rust preventer
Jun 10, 2010 - 6:42 AM |
Enthusiast Joined Jan 12, '09 From Poland,Europe Currently Offline Reputation: 0 (0%) |
Did my interior from carbon sticker - on both door(around window buttons), around radio panel and shifter. (sorry for my english)
This post has been edited by Sebby: Jun 10, 2010 - 6:43 AM -------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 3:26 AM |
