Today I.......................................... |
Oct 27, 2012 - 12:08 AM |
Didn't touch anything on timing. Have tried leaving the battery unplugged and nothing. Will try the ECU reset procedure under the information section of the site tomorrow. It's as if the ECU is telling the IACV to stay open for whatever reason. All else fails I can directly wire a relay and potentiometer between the IACV and the battery, then I can set the idle speed manually.
Oct 27, 2012 - 9:33 AM |
Enthusiast Joined Feb 8, '10 From North Carolina Currently Offline Reputation: 0 (0%) |
Olhm the iac. Tap on it a little see if it drops
Oct 27, 2012 - 12:09 PM |
I tested the ohms and it was in spec. It opens and closes as it should when connected to a battery. About to do a hard ECU reset and take it from there.
Oct 27, 2012 - 12:17 PM |
Barring any mechanical change, that should at least reset your idle.
'93 MX-5 LE |
Oct 27, 2012 - 1:31 PM |
Well, good results I suppose. After doing the ECU reset it dropped to around 1,000. Gave it throttle and it dropped to 775. Radiator fans had kicked on and the idle floated around 850-900 bouncing up and down after the fans turned off. Gave it throttle again and it dropped back down to 775 where it stayed for the next 10 minutes. Turned it off, guess we'll see next time I drive. I noticed when the idle was up I could hear a whistling from the area of the IACV. Which doesn't make sense. I had taken it apart and cleaned it, and used a new gasket. Tests out through ohm rating and connecting it to a battery and opens and closes as it should. So who knows.
Oct 27, 2012 - 2:30 PM |
Well, good results I suppose. After doing the ECU reset it dropped to around 1,000. Gave it throttle and it dropped to 775. Radiator fans had kicked on and the idle floated around 850-900 bouncing up and down after the fans turned off. Gave it throttle again and it dropped back down to 775 where it stayed for the next 10 minutes. Turned it off, guess we'll see next time I drive. I noticed when the idle was up I could hear a whistling from the area of the IACV. Which doesn't make sense. I had taken it apart and cleaned it, and used a new gasket. Tests out through ohm rating and connecting it to a battery and opens and closes as it should. So who knows. Heres a video I made on the idle adjustment screw. https://www.youtube.com/watch?v=C7a0ejq5be8...be_gdata_player |
Oct 27, 2012 - 6:51 PM |
Enthusiast Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
decided im going to buy another celica tomorrow lol
Oct 27, 2012 - 7:20 PM |
Today I granny shifted instead of double clutching like I should. I'm lucky that hundred shot of NOS didn't blow the welds on the intake manifold.
Oct 27, 2012 - 7:23 PM |
Enthusiast Joined Apr 22, '12 From Central NY Currently Offline Reputation: 5 (100%) |
^We need "Like" buttons
-------------------- 99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo 2010 Acura RDX Turbo w/ Technology Package 68 Impala SS Convertable |
Oct 27, 2012 - 10:26 PM |
fixed a dying 01 3.0 v6 sebring.
was a long 16 hour journey, but it works again. |
Oct 27, 2012 - 10:38 PM |
Today I granny shifted instead of double clutching like I should. I'm lucky that hundred shot of NOS didn't blow the welds on the intake manifold. Christ in hell that logic sucks once you know what you're talking about. Back then I was all "not teh maniford!1!!1" *floorboard falls*...fail. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Oct 28, 2012 - 11:47 AM |
Enthusiast Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) |
Prepped for Sandy...
Oct 28, 2012 - 12:37 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Today I tried double clutching like I should. A granny shifted past me.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Oct 28, 2012 - 2:08 PM |
fixed a dying 01 3.0 v6 sebring. was a long 16 hour journey, but it works again. 16 hours on an 01 Sebring!? Hmm ... 16 hours at a shop rate of $90 and hour plus parts .... that's more than the car's worth! -------------------- 99 Celica GT-S
Oct 28, 2012 - 2:29 PM |
Today I tried double-clutching like I should then f*ck I don't have a clutch yet.
This post has been edited by SwissFerdi: Oct 28, 2012 - 2:29 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Oct 29, 2012 - 6:42 AM |
fixed a dying 01 3.0 v6 sebring. was a long 16 hour journey, but it works again. 16 hours on an 01 Sebring!? Hmm ... 16 hours at a shop rate of $90 and hour plus parts .... that's more than the car's worth! Lol yea I guess technically. Hardest part was the valve cover gaskets were solid as a rock and required much work to remove. Then I forgot 1 screw on the rear valve cover, and had to remove the upper manifold again to take care of it. It was popping up spark wires out of the tube under the manifold causing misfires, and a sulfur smell from fuel not burning correctly. New spark wires, valve cover gaskets, spark tube gaskets, oil change, air filter, dizzy cap and that 3.0 V6 6G75 is burning wheels again. May be a crappy chrysler, but the engine is a pretty good mitisubishi engine.. All in all, 250 in parts, and one hell of learning exp. This post has been edited by rave2n: Oct 29, 2012 - 6:42 AM |
Oct 29, 2012 - 8:09 AM |
^ My mother had an '05 with the 2.7l. Barf.
'93 MX-5 LE |
Oct 29, 2012 - 8:53 AM |
...a pretty good mitisubishi engine.. There's an oxymoron if I've ever heard one ... and one hell of learning exp. I'll give you that one ... the learning experience is worth a lot actually. -------------------- 99 Celica GT-S
Oct 29, 2012 - 9:15 AM |
^ My mother had an '05 with the 2.7l. Barf. Yea the 2.7's I hear have tons of issues. ...a pretty good mitisubishi engine.. There's an oxymoron if I've ever heard one Lol yea I am aware of how Mitisubishi engines are known for failures, but this one after much research is actually one of the beefier ones. Often used for a TT setup, and can put out quite a bit of power. I believe it is used in the 3000GT VR-4 which you cannot deny is a beastly car. This engine took a beating for months with 3 out of 6 wires popped out, oil leaking all over the place..just a general haul of issues. Some time invested and it runs like a champ. I try to ignore the speculation, and just get it running right, but you have to give it props for being beat on so long and simple fixes running like new. None of my Toyota engines have repaired so simple =P This post has been edited by rave2n: Oct 29, 2012 - 9:16 AM |
Oct 29, 2012 - 8:40 PM |
I had a 3000GT, I don't like to talk about it.
Lo-Fi Version | Time is now: January 11th, 2025 - 5:49 AM |
