516 Pages V  « < 214 215 216 217 218 > »
post Jan 14, 2013 - 2:23 AM
Box
Joined Feb 23, '12
From Warrior, AL
You use lukewarm warm. Warm enough to melt it slowly and not cause rapid expansion of the glass.
Also today, seeing as I'm probably stuck with the Celica trying to think what to do with it. Exhaust for example, I tire of not being able to hear the car. At the same time I don't want to drive a bumblebee either.
This post has been edited by Box: Jan 14, 2013 - 2:24 AM
2001 Miata LS 5-speed
post Jan 14, 2013 - 3:02 AM
yagamius
Joined Feb 18, '09
From Costa Rica
the Car got overheated because of the radiator rubber cap got stock (sh***ty cap don't ask) and all the water go off the reservoir, also notice the hose from the water pump to the engine is about to explode, I'll change soon, need a trip to Toyota dealer.
1994 ST Celica --> no swap --> 7A rebuild
1974 Mustang --> Almost Restored
post Jan 14, 2013 - 9:08 AM
QUOTE (Box @ Jan 14, 2013 - 1:23 AM) *
sell it, get a honda
post Jan 14, 2013 - 3:00 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (njccmd2002 @ Jan 14, 2013 - 8:08 AM) *
post Jan 14, 2013 - 3:50 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Found out that My Celica is 200lbs lighter than my Fit!
エキサイティングカーレーシングチーム!
post Jan 14, 2013 - 4:04 PM
C-Lara
Joined Dec 24, '12
From Gaithersburg, MD
QUOTE (Tigawoods @ Jan 14, 2013 - 4:50 PM) *
09 scion xd - 5spd- bbs- coilovers- exhaust- intake
94- Celica Gt 5spd- Stock for now
post Jan 14, 2013 - 5:30 PM
Box
Joined Feb 23, '12
From Warrior, AL
Which is the "FIT" one now? *drum roll*
post Jan 15, 2013 - 3:58 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (yagamius @ Jan 14, 2013 - 4:02 AM) *
My radiator cap went out a few months back, but stuck shut rather than open. It cracked the top tank of my radiator when I parked the car and turned it off. I started to walk into the house and I heard a pop then sizzling noise. I turned around to see geisers of smoke pouring out of every crack on the front end of my celica.
Moral of the story replace the $10 cap when in doubt, otherwise you could be spending a hell of a lot more money
post Jan 15, 2013 - 8:37 PM
Bigblock
Joined Feb 14, '09
From Mid West
QUOTE (Special_Edy @ Jan 15, 2013 - 4:58 PM) *
My " simple " fan change became-- radiator, hoses & thermostat!!
I HATE RUST!!
post Jan 15, 2013 - 10:30 PM
doctavic
Joined Jun 5, '12
From NJ
got these in the mail today!
post Jan 15, 2013 - 10:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
Nice. Are those OEM or aftermarket?
post Jan 15, 2013 - 10:54 PM
doctavic
Joined Jun 5, '12
From NJ
aftermarket, from autovation. found them in an old 6gc post, and checked the autovation website and they still make them. found a discount code too.
http://www.autovationparts.com/store/toyotacelica.html
This post has been edited by doctavic: Jan 15, 2013 - 10:56 PM
post Jan 16, 2013 - 1:20 AM
yagamius
Joined Feb 18, '09
From Costa Rica
QUOTE (doctavic @ Jan 15, 2013 - 9:54 PM) *
Do they come with the Celica wording or is custom design ?
post Jan 16, 2013 - 1:23 AM
yagamius
Joined Feb 18, '09
From Costa Rica
QUOTE (Bigblock @ Jan 15, 2013 - 7:37 PM) *
I HATE RUST!!
tell me about it being there with the rust about 7 months, solve the problem with the rust and removed the thermostat since I'm in a tropical weather no need it, and since I'm waiting for my 20v blacktop I'll change the radiator for a better one.
for the moment just changing the cap and the hose
post Jan 16, 2013 - 7:31 AM
doctavic
Joined Jun 5, '12
From NJ
QUOTE (yagamius @ Jan 16, 2013 - 2:20 AM) *
They came with the wording, unexpected surprise. According to the old 6gc thread I found, they apparently had stopped with the wording, but it seems to be back.
post Jan 16, 2013 - 10:33 AM
Special_Edy
Joined Oct 29, '11
It should be noted that the radiator doesnt rust, it only collects rust from the engine.
Aluminum doesnt rust, only iron does, the block is made of iron and everything else is made of aluminum. If you are having a problem with rust, you are using too much water and not enough antifreeze in your coolant. You can backflush the radiator rather than replace it, except in extreme cases.
I also wouldnt recommend not using a thermostat. It's not designed specifically for the heater or for cold weather. The engine will suffer damage and poor performance under any atmospheric conditions if you dont have a thermostat installed.
post Jan 16, 2013 - 11:51 AM
Box
Joined Feb 23, '12
From Warrior, AL
Another thing most people overlook. Use DISTILLED water, not tap water. Tap water is full of minerals and all kinds of bad stuff that'll cause buildup and corrosion in your cooling system. It's only another dollar to get a gallon of distilled water and totally worth it.
post Jan 16, 2013 - 12:06 PM
storm26
Joined Mar 16, '12
I kinda like it biggrin.gif Sticker that indicates blowing and heat also come different, more "mint" tongue.gif
post Jan 16, 2013 - 12:15 PM
Bigblock
Joined Feb 14, '09
From Mid West
QUOTE (Special_Edy @ Jan 16, 2013 - 10:33 AM) *
Special_Edy
Every bolt was rust-welded to every nut!!
Agree on thermostat.
post Jan 16, 2013 - 12:49 PM
Special_Edy
Joined Oct 29, '11
QUOTE (Bigblock @ Jan 16, 2013 - 1:15 PM) *
Special_Edy
Oh, I thought you meant the inside of the radiator. Sometimes I clean my bolts off in a jar of gasoline, and then wipe a dab of oil on the threads before I reassemble to prevent this from happening.
Lo-Fi Version Time is now: November 30th, 2024 - 11:17 AM
