516 Pages V  « < 259 260 261 262 263 > »
post Jun 3, 2013 - 3:08 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
Today I... got let down for the first time :'(
I had pulled off the main drag to take a phone call and just left the car idling in neutral with the aircon on, after about 5-8 min I finished the call and pulled back on to the road, within about 15 seconds of pulling down I looked down and saw the temperature gauge skyrocketing... I pulled over immediately and switched off the engine. Popped the hood and heard the coolant in the engine boiling :S
After a quick bit of investigation I am fairly confidant I have an electrical fault with the cooling fans. I managed to drive home fine once it cooled off, it just didn't like sitting there with no airflow. When I switch the ignition back on (without turning over the engine) the fan spun once, then stopped and made a whirring noise, then nothing. This repeated itself again the next time.
I am about to go and investigate some more, then do some searching and maybe a new topic if required frown.gif
post Jun 3, 2013 - 3:34 AM
Rusty
Joined Nov 5, '07
From New Zealand
sorry to hear, would probably be worth having a check of the other cooling parts as well to be on the safe side
post Jun 3, 2013 - 5:05 AM
Box
Joined Feb 23, '12
From Warrior, AL
Sorry to hear about that. Hopefully nothing was damaged, and the cause is an easy fix.
2001 Miata LS 5-speed
post Jun 3, 2013 - 5:32 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (JoshuaM @ Jun 3, 2013 - 4:08 AM) *
Almost had this the other day, The car cranked but the engine would only splutter... Took me 5 - 10 times to try and get it started... The problem has seemed to have gone now, so maybe something discharged the battery the over the previous night or something. kindasad.gif
Anyway, Ill do that test mentioned on Facebook tomorrow and see what happens...
This post has been edited by rentaspace: Jun 3, 2013 - 5:33 AM
post Jun 3, 2013 - 5:54 AM
Box
Joined Feb 23, '12
From Warrior, AL
^Battery wouldn't cause that. Sounds almost as if the engine was flooded.
Also been looking around and I can't believe all the Japanese parts I can throw onto a SN95 Mustang. tongue.gif If I were to get a Mustang and load it up with Japanese suspension parts and wheels then both the domestic and tuner crowd would love me. laugh.gif
post Jun 3, 2013 - 5:58 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Jun 3, 2013 - 5:54 AM) *
I am thinking it was due to the weather; We had a 12C (53.6F) day, and rain with 60+km/h (37mph) winds... The chill factor was terrible kindasad.gif
Later that night it had died down and actually got warmer to around 15C (59F)
post Jun 3, 2013 - 6:34 AM
JoshuaM
Joined Mar 6, '12
Well I was wrong about the electrical thing; that whirring noise was just the ABS unit initialising... you just usually don't hear it with everything closed up.
Fans work fine, they just only run when the engine is physically ticking over, not when the car is in the 'On' position with the aircon on like all our other cars do.
The radiator has lost a lot (Can't see a fluid line at all when you look in from the top), so I need to steal a car in the morning and get some new coolant. I am planning to just fill it up and baby it around for a few days and keep an eagle eye on it... I doubt any more damage will be done if I keep an eye on the temp and don't let it get hot. I can't see any other problems that would cause it, other than a coolant leak somewhere (I'm not saying there isn't, just that I'm not going to find them with the car sitting here in the driveway tongue.gif).
And a 'stang with JDM suspension.... I'd love a muscle car that could turn corners too tongue.gif
post Jun 3, 2013 - 2:07 PM
Box
Joined Feb 23, '12
From Warrior, AL
There's something off with your car then, the fans should come on with the car in the ON position. With my car running with the fans kicked on I can turn the car off and into the ON position and the fans will stay on until it runs through its cycle. Also as soon as the A/C is turned on the fans turn on and stay on as long as the A/C is being used.
Indeed, there're a ton of aftermarket suspension components for the Mustang. Kind of leaning towards it over the 93-02 F-body since you can actually work on its engine, and the interior isn't a giant chunk of plastic... Why GM, why...? Anyhow, going to be on the lookout for one locally so I can see one in person and see if I'd like the car more than the Celica. That and to see if my knee can take the clutch, somehow I get the feeling that a cable driven clutch on a V8 won't be any fun.
post Jun 3, 2013 - 2:49 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Do after thinking about that black Celica for $1200, we turned it down. It's got way too much wrong with it.
We did find this one for $1500 though, and it already looks better. (Most importantly, all of the body is original, so it hasn't been in any accidents yet.)
http://buffalo.craigslist.org/cto/3787197087.html
It's got way less miles, looks better already from the pics. If a door and fender is the least of my worries on it, I'd be okay with it. Those are cheap at a junkyard. The black one needed almost everything new lol and the dash looked like it had been dislodged in the accident it was in. From the pics on this one, the dash/inside is perfect.
post Jun 3, 2013 - 3:00 PM
The_enD
Joined Apr 12, '13
From Bulgaria
That's looking better. The spoiler looks faded and there seem to be scratches around the front emblem. I also see some bird droppings or even worse, the after-match, the eaten away clear coat underneath.
The damage around the fenders seems to transfer to the bumper.
Interior looks good from the single pic provided.
Rims need to get fix.
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Jun 3, 2013 - 3:39 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Jun 3, 2013 - 5:33 PM
JoshuaM
Joined Mar 6, '12
That blurple one looks much better! $300 extra very well spent I would say tongue.gif
And....
XD XD XD
post Jun 3, 2013 - 5:39 PM
Box
Joined Feb 23, '12
From Warrior, AL
U HAZ BOX!!!!!!!
post Jun 3, 2013 - 6:33 PM
cheela
Joined Feb 2, '07
From Berlin, WI
I think box needs to post a picture of a box so we can say that box has a box! laugh.gif
This post has been edited by cheela: Jun 3, 2013 - 6:34 PM
post Jun 3, 2013 - 9:26 PM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Jun 3, 2013 - 3:07 PM) *
Maybe the Australian spec Celica's are different, I just tested mine and videoed it:
When my car was running, and the AC button pressed, the Fan's instantly come on (like on all cars), I then cut the engine and returned to the 'on' position, I had cold air coming from the vents and AC on, but no fan spinning...
*Facebook Video*
QUOTE (RabidTRD @ Jun 3, 2013 - 3:49 PM) *
They say 'Or best offer' so I would be talking them down a bit by mentioning the faded paint and damage...
Overall that is a very good project car and by my local prices, a lot cheaper than anything running here tongue.gif
This post has been edited by rentaspace: Jun 3, 2013 - 9:38 PM
post Jun 3, 2013 - 9:39 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (cheela @ Jun 3, 2013 - 6:33 PM) *
post Jun 3, 2013 - 10:06 PM
travisxcore
Joined Mar 24, '11
From 704
Guess what I did today?
post Jun 3, 2013 - 10:17 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Jun 3, 2013 - 10:24 PM
travisxcore
Joined Mar 24, '11
From 704
Haha well sort of. I took off my spoiler, I'm getting body work done on my rear end this week to get rid of that annoying gash that's been there forever. And get parts of my clear coat fixed that are peeling off... I kinda actually like it spoilerless.
post Jun 3, 2013 - 10:34 PM
rentaspace
Joined Sep 23, '12
From Australia
Today I got my OzCelica decals:
Front:
Rear:
I also put this on each side a few days ago, still deciding whether to keep them or not:
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 18th, 2025 - 6:14 AM
