Today I.......................................... |
Jun 20, 2013 - 10:42 AM |
Enthusiast Joined May 25, '13 From Charlotte, NC Currently Offline Reputation: 0 (0%) |
Jun 20, 2013 - 11:02 AM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
Looking good. Thanks! Want to bust out the buffer sometime next week to get it extra nice Definitely! I need to get a buffer myself as these human-powered waxes are tiring and time consuming. -------------------- Has no more Celicas
Jun 20, 2013 - 1:39 PM |
Took the wife up today to pick up her new to her 97 st lift back!!
-------------------- 95 gt coupe, v6 swap weekend toy
Jun 20, 2013 - 4:51 PM |
Enthusiast Joined May 29, '13 From New Zealand Currently Offline Reputation: 0 (0%) |
was curious... Sat in the driveway today and revved it to the limiter. sounds pretty good stock.
Jun 20, 2013 - 6:58 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Got bored and did...........
Now to mount it over my fireplace. |
Jun 20, 2013 - 8:29 PM |
So about a week ago, I...
A short time after that... Until she was roadworthy again, on the 18th. Bonus picture, a game from my youth. I'd like to thank everyone who made a contribution, whether in parts, assistance, advice, knowledge and guidance along the way. A lot of parts came from members here near and far. This post has been edited by SwissFerdi: Jun 20, 2013 - 8:36 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Jun 20, 2013 - 9:16 PM |
Enthusiast Joined Nov 29, '07 From Colorado Currently Offline Reputation: 4 (100%) |
Put on the cams, and the VVTi oil galley (with cleaned filter of course!), and the gears. Just need to bolt up the new water pump and it's good to time tomorrow, possibly mate it to the transmission, and get my Celica up on stands!
-------------------- 2019 M2, 2005 S2000, 1997 4Runne
Jun 21, 2013 - 2:25 AM |
Master cylinder is supposed to be today. I'm tired of driving my grandfather's Lexus ES300.
Jun 21, 2013 - 8:00 PM |
Timed the BEAMS. Put most everything back together. Tomorrow: Hook it up to the wire harness and transmission. Remove 5S-FE. Insert 3S-GE BEAMS.
(OK, a little ambitious, but it should be moving by Sunday I hope). -------------------- 2019 M2, 2005 S2000, 1997 4Runne
Jun 21, 2013 - 8:07 PM |
Enthusiast Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
Spent a total of $750 on my car in the last few days..
Jun 21, 2013 - 10:20 PM |
I HAVE BRAKES AGAIN!!!!!!!!!
Jun 21, 2013 - 10:28 PM |
Enthusiast Joined Sep 23, '12 From Australia Currently Offline Reputation: 4 (100%) |
Well, I have been back and forth to the Hospital all week and my car has started spluttering again (I think this is because dad bought E10 the other day, when I run on 95 or 98 she doesn't have any troubles)
I also think that she is running a little rich, as after a 20min drive the other day when I turned the car off there was a petrol smell from the exhaust... And she is chewing through the petrol atm as well... Any other ideas what this may be? This post has been edited by rentaspace: Jun 21, 2013 - 10:29 PM -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Jun 21, 2013 - 11:31 PM |
Just about any older car runs rich, Hell it seems new cars do as well after some thirty thousand miles. Could be leaking injectors, or FPR over-pressurizing the system. On some cars a faulty coolant temp sensor can cause problems, rather or not that's the case with our cars I don't know. Ehh air intake temp sensor sending false readings, but that'd throw a code if it were bad. Generally so would the coolant temp sensor. Try resetting the ECU first per the instructions here: http://www.6gc.net/howto/reset_your_air_fuel_ratio
This post has been edited by Box: Jun 21, 2013 - 11:32 PM -------------------- 2001 Miata LS 5-speed
Jun 22, 2013 - 5:30 AM |
I'd say its an O2 or IAT sensor on the way out. They can be slightly defective without throwing a check engin light.
Jun 22, 2013 - 6:34 AM |
Enthusiast Joined Nov 29, '12 From New Zealand Currently Offline Reputation: 0 (0%) |
Picked up mine from the body shop today Shineeeey
Tomorrow, oil change -------------------- |
Jun 22, 2013 - 6:45 AM |
Just about any older car runs rich, Hell it seems new cars do as well after some thirty thousand miles. Could be leaking injectors, or FPR over-pressurizing the system. On some cars a faulty coolant temp sensor can cause problems, rather or not that's the case with our cars I don't know. Ehh air intake temp sensor sending false readings, but that'd throw a code if it were bad. Generally so would the coolant temp sensor. Try resetting the ECU first per the instructions here: http://www.6gc.net/howto/reset_your_air_fuel_ratio I have already reset the ecu after I did the exhaust and then a few weeks ago too, I haven't got a code reader so it could be giving a code -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Jun 22, 2013 - 11:45 AM |
If it were giving a code your check engine light would be on.
Jun 23, 2013 - 12:45 AM |
If it were giving a code your check engine light would be on. Not even sure that I have a check engine light right now I haven't got some of my gauge lights back in yet... Was waiting until I got my Spree kit before dissembling again -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Jun 23, 2013 - 3:34 AM |
Enthusiast Joined May 11, '09 From California Currently Offline Reputation: 4 (100%) |
I made two threads!
Project Thread http://www.6gc.net/forums/index.php?showtopic=89938 Rack n Pinion http://www.6gc.net/forums/index.php?showtopic=89939 -------------------- |
Jun 23, 2013 - 12:43 PM |
You thread whore you.
Lo-Fi Version | Time is now: November 25th, 2024 - 11:46 PM |
