^Dead link.
So, apparently there was a Y87 package for V6 F-bodies that give it the V8 model's LSD, brakes, steering box, and dual exhaust. 200hp and 225 ft lb is fun enough in a 3,300 pound car I suppose. Meh, either that or the Z31. -------------------- 2001 Miata LS 5-speed
Well that's ironic, funny what you can find on the internet. Certain people 5 years ago badmouthing the Celica and now they have done engine swaps etc..
![]() Tried driving around with tires at 30 psi today, not really any softer of a ride so they'll be going back up to 40 psi. If anything I think the sidewall flex may have made it worse. -------------------- 2001 Miata LS 5-speed
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) ![]() |
They should be at the recommendation. 40 is too high.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) ![]() |
They should be at the recommendation. 40 is too high. +1 ![]() -------------------- ![]() SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) ![]() |
I usually run between 33 and 40PSI - feels great on the road.
-------------------- Has no more Celicas
Enthusiast ![]() ![]() Joined Oct 24, '09 From Appleton, Wisconsin 54915 Currently Offline Reputation: 7 (100%) ![]() |
Today i scored a set of MR ST series Coil-overs for $850 shipped to my door and they should be on their way shortly.
dropped my wife's 05 highlander off @ the dealership........$700 of rape to be encountered just to restore heat
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) ![]() |
Is there any danger to the engine running 100 octane fuel? 7a-fe
no. unless its leaded
if its leaded it'll destroy your CAT. but why waste the money on 100 octane when it won't do anything for you. Trust me....been there done that....useless |
They should be at the recommendation. 40 is too high. 29 on the door card, 30 is way too low though. The tires' max rating is at 55 psi, they're just flat at 30. I can push in on the sidewall with my hands and flex it in and out at 30. At 40 psi that still leaves over 35% of capacity for expansion, it'll be fine. I should add mine are the 14's, so I have a lot more sidewall than everyone else. If they were 15's maybe 30 psi would be be ok, 16's 30 psi would be about ideal. This post has been edited by Box: Oct 10, 2013 - 2:49 PM -------------------- 2001 Miata LS 5-speed
no. unless its leaded if its leaded it'll destroy your CAT. but why waste the money on 100 octane when it won't do anything for you. Trust me....been there done that....useless Indeed, all it means is that higher the octane rating the more compression it can withstand before detonating. If your car doesn't pre-detonate on regular fuel, there's no point in paying more for premium etc... The exception being cars that have knock sensors and call for premium, as they'll just retard the timing for regular fuel. Then there will be a loss of power and economy, and more often than not you save money just by running the premium that's called for. -------------------- 2001 Miata LS 5-speed
They should be at the recommendation. 40 is too high. 29 on the door card, 30 is way too low though. The tires' max rating is at 55 psi, they're just flat at 30. I can push in on the sidewall with my hands and flex it in and out at 30. At 40 psi that still leaves over 35% of capacity for expansion, it'll be fine. I should add mine are the 14's, so I have a lot more sidewall than everyone else. If they were 15's maybe 30 psi would be be ok, 16's 30 psi would be about ideal. door card is a bit generic....all tires have the PSI max and/or range printed on the sidewall.. I'd look there to ensure per your tire manufacture that you're in range. I normally fill 10-5psi shy of max depending on conditions. |
Everywhere you go says to go by the door card, but you can't tell me 30 psi on a 55 psi max tire is right either. Mine only have the max rating on them, doesn't give a range. 40 seemed like a happy medium between comfort and handling. I just know 30 is too low, car felt mushy and any ride softness gained isn't worth it.
Enthusiast ![]() ![]() Joined Jan 16, '12 From 860, ct Currently Offline Reputation: 0 (0%) ![]() |
My uncle lives on a large property. Slapped the mudders on this beast and yutzed it up after a day of drinking, wrenching, and bull****ting.
Poor extension cord.
![]() -------------------- 2001 Miata LS 5-speed
That's the world's thinnest garden hose then.
![]() Hey, I might be buying another Celica. Except this one the proper wheels move the car. ![]() -------------------- 2001 Miata LS 5-speed
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Sep 23, '12 From Australia Currently Offline Reputation: 4 (100%) ![]() |
I run mine at 34-5 PSI all around...
When I took the car in for wheel balance and alignment they over filled it to 50PSI.... I noticed as soon as I started driving and realised the ride had gone to s**t... got home and check and was astounded that they didn't even read the door or the tyre specs >.< Since, they are a tyre shop... -------------------- ![]() ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Haha, that IS an extension cord. Oops.
In any case, progress was made on the 1MZ today. If Ican get a harness, she could drive. |
Why you do everything yourself, only way to know for sure it was done right. That or if you happen to know personally the one doing the work, and can trust them then that's ok I suppose.
AHA I KNEW IT!!!!!!!! Yay almost driving. -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: February 21st, 2025 - 11:48 PM |
