Today I.......................................... |
Nov 12, 2013 - 11:58 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Finally bought the euro front lip I wanted. Been looking for it for ages haha.
Project starting to get in place ^^ |
Nov 13, 2013 - 1:44 AM |
Enthusiast Joined Sep 23, '12 From Australia Currently Offline Reputation: 4 (100%) |
Is the fuel gauge still functioning properly? Fuel Needle is functioning 100% fine... The Fuel light is still illuminated though... -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Nov 13, 2013 - 1:51 AM |
The ECU has absolutely no effect on the fuel gauge. You'll need to remove your fuel pump (easily done) and check the float out to make sure it isn't sticking and inspect the wiring to make sure it isn't cracked or broken anywhere.
Nov 13, 2013 - 2:05 AM |
The ECU has absolutely no effect on the fuel gauge. You'll need to remove your fuel pump (easily done) and check the float out to make sure it isn't sticking and inspect the wiring to make sure it isn't cracked or broken anywhere. But if the float is stuck, wouldn't the fuel gauge also be stuck? -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Nov 13, 2013 - 2:44 AM |
Theoretically, yes. That's why I'm thinking it may be a wiring issue. Might even be an issue inside the gauge cluster. It's probably illegal to have a full tank of fuel and have the low fuel light on simultaneously in Australia.
Nov 13, 2013 - 7:06 AM |
Theoretically, yes. That's why I'm thinking it may be a wiring issue. Might even be an issue inside the gauge cluster. It's probably illegal to have a full tank of fuel and have the low fuel light on simultaneously in Australia. I will try taking the bulb out and resitting it... I haven't messed with any of the wires that connect to fuel related things... So I am lost to how this happened... It's probably illegal here for me to be talking about my car on the internet anyway... Time to put my Tinfoil hat on! -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Nov 13, 2013 - 2:10 PM |
Been making a hard discission about my celica as of lately
Gonna have some big update coming up next month I think -------------------- 95 gt coupe, v6 swap weekend toy
Nov 13, 2013 - 2:13 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Put the poop wheels on for the poop winter with the poop salt and poop cold.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Nov 13, 2013 - 2:18 PM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
Put the poop wheels on for the poop winter with the poop salt and poop cold. Still delaying that move. She looks nicer with with my OZ compared to steelies -_- -------------------- |
Nov 13, 2013 - 4:48 PM |
The ECU has absolutely no effect on the fuel gauge. You'll need to remove your fuel pump (easily done) and check the float out to make sure it isn't sticking and inspect the wiring to make sure it isn't cracked or broken anywhere. But if the float is stuck, wouldn't the fuel gauge also be stuck? I'm just going to say you should go about it the American way. Ignore it. -------------------- 2001 Miata LS 5-speed
Nov 13, 2013 - 5:51 PM |
Speaking of ignoring things, my brother broke my driver window today. So I'm going to ignore it and just not have a window.
Nov 13, 2013 - 6:04 PM |
Enthusiast Joined Apr 15, '13 From Winnipeg, MB, Canada Currently Offline Reputation: 14 (100%) |
Speaking of ignoring things, my brother broke my driver window today. So I'm going to ignore it and just not have a window. Windowd are overrated anways. -------------------- 2007 Impreza 2.5i - Daily
1994 Camry - Sold 1994 Celica - Sold :( Click here to see my progress thread! |
Nov 13, 2013 - 7:08 PM |
Indeed, they're like invisible and stuff. Never know the difference anyway.
This post has been edited by Box: Nov 13, 2013 - 7:08 PM -------------------- 2001 Miata LS 5-speed
Nov 13, 2013 - 7:25 PM |
Nov 13, 2013 - 7:35 PM |
Taking care of it tomorrow or the weekend at the latest. Somehow he made the window drop into the door, luckily the glass is ok and have it blocked for now. Just have to fix whatever broke...
Nov 13, 2013 - 7:54 PM |
The ECU has absolutely no effect on the fuel gauge. You'll need to remove your fuel pump (easily done) and check the float out to make sure it isn't sticking and inspect the wiring to make sure it isn't cracked or broken anywhere. But if the float is stuck, wouldn't the fuel gauge also be stuck? I'm just going to say you should go about it the American way. Ignore it. I was using the good 'ol 'merican way... Then today, I drove to tafe with my fuel light on... And my needle looming over the "e", and the light was on. Got out of Tafe 2 hours later, and to my surprise, the fuel light went out... So my reaction went something like this: "What the f**k, so my fuel light now tells me when I have fuel and not when I need it..." On the way home it went on and off as usual as I rose and descended, so now I am not sure if the fuel light has reversed its function or not >.< -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Nov 13, 2013 - 8:25 PM |
Hmm, maybe something is plugged in backwards somewhere.
Nov 14, 2013 - 12:24 AM |
Hmm, maybe something is plugged in backwards somewhere. I haven't disconnected anything to do with the fuel or gauge -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Nov 14, 2013 - 2:24 AM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
I have a bad fuel level problem aswell...gonna re wire it and i guess maybe sand the floater to make it smoother since it enjoys sticking
Nov 14, 2013 - 2:42 AM |
Hmm, maybe something is plugged in backwards somewhere. I haven't disconnected anything to do with the fuel or gauge Did you not do the LED kit? Hmm... Odd that all of a sudden would be having such a problem. -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: November 22nd, 2024 - 11:28 PM |
