516 Pages V  « < 346 347 348 349 350 > »
post Jan 10, 2014 - 5:29 PM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
QUOTE (1994Celica @ Jan 10, 2014 - 2:07 PM) *
I have many small little things I did today, they'll be in my build thread. Here's one of them though. Today I put this in.
Neat! Where did you get that?
Today I got my Manzo header! I now have everything I need for my exhaust smile.gif
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Jan 10, 2014 - 5:38 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
It was on eBay it came from rpm garage I believe.
JDM Part King
post Jan 10, 2014 - 5:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
[quote name='SwissFerdi' date='Jan 8, 2014 - 6:21 AM' post='1035562']
I did further research and no MR2, nor mid-engine RWD car, is a snow car, so NA6 it is.
2001 Miata LS 5-speed
post Jan 10, 2014 - 11:50 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
Today I pulled the console and adjusted the E-brake so its fully engaged by 8 clicks. before It took about 12 clicks.
and while I had it apart I noticed that there is a little bitty 074 light bulb In the Ash Tray!
Neeto!
Bust a Deal; Face the Wheel.
post Jan 11, 2014 - 12:33 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (VavAlephVav @ Jan 11, 2014 - 12:50 AM) *
Neeto!
Replaced mine with a T5 LED and directed the light through the window on the ashtray!
This post has been edited by rentaspace: Jan 11, 2014 - 12:33 AM
post Jan 12, 2014 - 6:03 PM
Yesterday I chased an issue with the transmission not wanting to go into first. Topped off the transmission fluid, which only required a tenth of a quart. Flushed the brake fluid partially by removing most of the fluid from the master cylinder, putting in fresh fluid and cycling it, repeating the process a few times. The shifting has improved but it's still reluctant sometimes, so now I'm wondering if there's something amiss in the cables. The clutch master rod travel should be within spec.
Today I chased cones and other automotive indulgences.
This post has been edited by SwissFerdi: Jan 12, 2014 - 6:04 PM
post Jan 12, 2014 - 9:25 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
Today i finished my gauge cluster and it is really bright, almost think i put too many leds in.. and im still waiting for my individual leds to come in for the hvac. Also fixed the issue with the cig lighter being too dim and the key ring as well.
post Jan 13, 2014 - 4:43 AM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (cyberblader1130 @ Jan 13, 2014 - 4:25 AM) *
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Jan 13, 2014 - 10:11 AM
yagamius
Joined Feb 18, '09
From Costa Rica
this actually happened yesterday
now today I need to figure it out how to fix this
1994 ST Celica --> no swap --> 7A rebuild
1974 Mustang --> Almost Restored
post Jan 13, 2014 - 11:06 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (SwissFerdi @ Jan 12, 2014 - 7:03 PM) *
Ouch, sorry to hear that!
Are you at a complete stop? or close to it?
post Jan 13, 2014 - 11:58 AM
QUOTE (rave2n @ Jan 13, 2014 - 11:06 AM) *
Yes, and yes.
post Jan 13, 2014 - 12:29 PM
rave2n
Joined May 29, '09
QUOTE (SwissFerdi @ Jan 13, 2014 - 11:58 AM) *
Yes, and yes.
Hmm that is odd, I never had a problem unless I was trying to get it in first above 20mph. Which to this day I dunno if it is possible on 6th gen Celicas. I couldn't in the GT or ST, but any other car I drive, when I press the clutch down, it doesn't matter what gear or speed relation.
post Jan 13, 2014 - 2:37 PM
richee3
Joined Jun 29, '08
From Denver
Today I received a package in the mail:
Supposedly a set of OEM floor lights for a Celica. I can't find any information on them, although I remember a recent thread. They may be dealer option. Either way, I'm not going to use them since I already have white LED strips that are much brighter and much cheaper than these. I'll probably resell these.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 13, 2014 - 4:12 PM
rave2n
Joined May 29, '09
QUOTE (yagamius @ Jan 13, 2014 - 10:11 AM) *
Ouch that is horrible!
post Jan 13, 2014 - 4:24 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Time for a trunk popper.
post Jan 13, 2014 - 5:26 PM
cyberblader1130
Joined Oct 24, '09
QUOTE (The_enD @ Jan 13, 2014 - 5:43 AM) *
Not till im fully finished with all and then i will post a few photos assuming it doesn't show up as a blur. biggrin.gif Today i found a new issue. Turns out when im driving with my running/headlights off, my dash, hvac and cig lighter will flash when i press the brake pedal. kindasad.gif
post Jan 13, 2014 - 9:31 PM
b22ri22an
Joined Jun 2, '10
From Davenport, Florida
Bought a Prius and put the Celica up for sale in the buying/selling forum
post Jan 14, 2014 - 2:22 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
Changed the driver side parking brake cable and torqued the front hub down to spec. Found out that my pagan get side is also seized frown.gif I also figured out that the rust is so bad on the pass rear quarter where the sunroof drains, that's it's cracked and braking now. Def going to the body shop come spring.
post Jan 14, 2014 - 3:56 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (rave2n @ Jan 13, 2014 - 9:29 AM) *
Yes, and yes.
I was told it was a safety feature? My brothers 91 Integra does the same thing too. Can't go into first while rolling unless you're like at 10mph or lower.
post Jan 14, 2014 - 5:11 PM
QUOTE (ILoveMySilly97 @ Jan 14, 2014 - 3:56 PM) *
I would say it's a safety feature, but not applicable in my situation since it happens from a dead stop as well. Sometimes it just doesn't want to slide into first (from neutral), almost as if I'm not depressing the clutch. I'm flushing the clutch master fluid through a bit more today, hopefully that will do something. Tomorrow I'll check over the linkages, it almost seems like the top of the shifter rod sits more toward me than it used to. To me, that indicates that one of the cables is pushing to the right, even though a quick visual check through the shifter assembly doesn't look like anything out of the ordinary.
This post has been edited by SwissFerdi: Jan 14, 2014 - 5:13 PM
Lo-Fi Version Time is now: November 23rd, 2024 - 5:22 PM
