Today I.......................................... |
Feb 26, 2014 - 7:26 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Found a set of Rota Slips locally. Might get them as my cheap daily beater rims. Lol.
Feb 26, 2014 - 8:45 PM |
Enthusiast Joined Apr 21, '13 From YYC Currently Offline Reputation: 1 (100%) |
Today I took off my wheels and tried to figure out where my brake fluid was leaking from. I originally thought it was from my front right, as there was a small spill under my tire when I was leaving work, but found that it was my banjo bolt on the rear right which looked wet. I tried tightening it, but it kept on spinning, so we'll see over the next week or so whether it still leaks. Hopefully it's tightened enough right now to stop the leak, if not, then I hope all i have to do is replace the banjo bolt and not the entire caliper itself.
I also tightened up the e-brake while my rear wheels were off since I think it was a little loose, so now it stops after 3~5 clicks, max 7 clicks until I can't pull the handle anymore. |
Feb 26, 2014 - 9:29 PM |
Today I took off my wheels and tried to figure out where my brake fluid was leaking from. I originally thought it was from my front right, as there was a small spill under my tire when I was leaving work, but found that it was my banjo bolt on the rear right which looked wet. I tried tightening it, but it kept on spinning, so we'll see over the next week or so whether it still leaks. Hopefully it's tightened enough right now to stop the leak, if not, then I hope all i have to do is replace the banjo bolt and not the entire caliper itself. I also tightened up the e-brake while my rear wheels were off since I think it was a little loose, so now it stops after 3~5 clicks, max 7 clicks until I can't pull the handle anymore. lol finding a single rear replacement st205 caliper would be a pain in the bottom -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Feb 26, 2014 - 10:12 PM |
Enthusiast Joined Jan 27, '14 From Fort Wayne IN Currently Offline Reputation: 0 (50%) |
If it kept spinning, its prolly stripped. Luckily you serviced your ebrake so hopefully it still works when the bolt launches from the caliper leaving you with no brake pedal.
-------------------- 94 Teal GT-DD 223,915 miles SOLD
99 WHT GT- Race car! Or just AutoX Car getting rebuilt then susp and turbo! |
Feb 26, 2014 - 11:05 PM |
Feb 27, 2014 - 12:39 AM |
Enthusiast Joined Dec 9, '13 From Melbourne, Australia Currently Offline Reputation: 2 (100%) |
Today I opened my packages I got yesterday to find my custom halo projectors from Malhar and clear highs from Spider77! Very nice! I wanna see them fitted Also, I've done some pretty major progress today haha Changed my Air Freshner from 'New Car Scent' to ' Peachy Peach' Also featuring my mini star wars kinder collection This post has been edited by RoadRage: Feb 27, 2014 - 4:23 AM -------------------- |
Feb 27, 2014 - 6:12 AM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
Damn, $100 for full 7GC seat set, front and back. and he will include two door cards. -------------------- |
Feb 27, 2014 - 7:09 AM |
Changed my Air Freshner from 'New Car Scent' to ' Peachy Peach' My favorite air freshener is the window down function. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Feb 27, 2014 - 7:11 AM |
Changed my Air Freshner from 'New Car Scent' to ' Peachy Peach' My favorite air freshener is the window down function. So is mine, but its always nice to have a peachy smell in the background -------------------- |
Feb 27, 2014 - 9:08 AM |
i have found a newport new car smell that works for me.
Feb 27, 2014 - 10:18 AM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Today I took off my wheels and tried to figure out where my brake fluid was leaking from. I originally thought it was from my front right, as there was a small spill under my tire when I was leaving work, but found that it was my banjo bolt on the rear right which looked wet. I tried tightening it, but it kept on spinning, so we'll see over the next week or so whether it still leaks. Hopefully it's tightened enough right now to stop the leak, if not, then I hope all i have to do is replace the banjo bolt and not the entire caliper itself. I also tightened up the e-brake while my rear wheels were off since I think it was a little loose, so now it stops after 3~5 clicks, max 7 clicks until I can't pull the handle anymore. There is an adjustment up at the handle too if you want less clicks. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Feb 27, 2014 - 10:26 AM |
Enthusiast Joined Apr 15, '13 From Winnipeg, MB, Canada Currently Offline Reputation: 14 (100%) |
Today I opened my packages I got yesterday to find my custom halo projectors from Malhar and clear highs from Spider77! Very nice! I wanna see them fitted So do I unfortunately one of the projectors got damaged in shipping so I'm trying to sort that out. And it's way too cold anyways to get anything done on the car. -37℃ today And I tried to get at least the high beams in yesterday and ended up breaking all 6 bolts that bolt the bumper to the fender -------------------- 2007 Impreza 2.5i - Daily
1994 Camry - Sold 1994 Celica - Sold :( Click here to see my progress thread! |
Feb 27, 2014 - 10:36 AM |
That sucks...
Feb 27, 2014 - 10:53 AM |
That sucks... Tell me about it. Everything seems to be going wrong right now...so I'm gonna have to leave it for now until it warms up and I can actually get some work done. -------------------- 2007 Impreza 2.5i - Daily
Feb 27, 2014 - 11:02 AM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
That sucks... Tell me about it. Everything seems to be going wrong right now...so I'm gonna have to leave it for now until it warms up and I can actually get some work done. bolts don't like moving in -37C weather. -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Feb 27, 2014 - 11:09 AM |
That sucks... Tell me about it. Everything seems to be going wrong right now...so I'm gonna have to leave it for now until it warms up and I can actually get some work done. bolts don't like moving in -37C weather. Especially when they're rusted on -------------------- 2007 Impreza 2.5i - Daily
Feb 27, 2014 - 11:14 AM |
Mine were a bitch too, but wd40 to the rescue.
Feb 27, 2014 - 11:24 AM |
Mine were a bitch too, but wd40 to the rescue. No amount of wd40 was getting those bolts off -------------------- 2007 Impreza 2.5i - Daily
Feb 27, 2014 - 11:43 AM |
Good luck replacing the OEM bolts, as far as I remember it was a little bracket that hold them all. Get creative and change to new bolts.
Feb 27, 2014 - 1:23 PM |
Good luck replacing the OEM bolts, as far as I remember it was a little bracket that hold them all. Get creative and change to new bolts. Thanks, hopefully I can figure something out -------------------- 2007 Impreza 2.5i - Daily
Lo-Fi Version | Time is now: December 2nd, 2024 - 2:33 AM |
