516 Pages V  « < 443 444 445 446 447 > »
post Sep 7, 2014 - 11:59 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (PegGTS @ Sep 7, 2014 - 11:19 PM) *
I did peel it off right after spraying, but I did quite a few coats so maybe that's why it peeled up
Most likely. And plastidip dries pretty quick as well so after doing that many coats the base is probably mostly dry and stuck to the tape. You can also just run a razor blade along the edge of the tape as you pull up
post Sep 8, 2014 - 8:30 AM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
QUOTE (Noahwhite2014 @ Sep 7, 2014 - 11:59 PM) *
Thanks, I'll keep that in mind for next time
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Sep 10, 2014 - 12:10 AM
Partially replaced the clutch master fluid, and rolled 'er over 130000 miles. Here's to a few more...
post Sep 10, 2014 - 9:54 AM
1994Celica
Joined Aug 5, '09
From West Texas, USA
Today I bought a rare JDM clean box.
JDM Part King
post Sep 10, 2014 - 2:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
2001 Miata LS 5-speed
post Sep 10, 2014 - 5:53 PM
1994Celica
Joined Aug 5, '09
QUOTE (Box @ Sep 10, 2014 - 3:55 PM) *
But I got your maaad awesome jdm tight cousin.......yo.
JDM Part King
post Sep 10, 2014 - 6:11 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hmm, last I checked I was all European and Native American descent. redface.gif
post Sep 10, 2014 - 7:58 PM
travisxcore
Joined Mar 24, '11
From 704
Sooo I guess I'm finally just gonna end swapping the S54 into the '93. I just have no idea which shifter cables I should use. And I wonder if the mechanical speed sensor will even work. Oh well who needs a speedo anyways.
post Sep 12, 2014 - 5:58 PM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
Used the cigarette lighter for the first time and bam, it doesnt work
post Sep 12, 2014 - 6:03 PM
Box
Joined Feb 23, '12
From Warrior, AL
I think there's a separate fuse for it, but I'm not entirely sure.
post Sep 12, 2014 - 6:13 PM
MisterRay
Joined Jun 24, '12
From Birmingham
QUOTE (ClevelandGaint @ Sep 12, 2014 - 6:58 PM) *
Can't 100% remember but the cig n radio fuse is the same one so if your radio works it's not the blade fuse. You need to replace the actual cig lighter because the "fuse" on the back of it (the thin piece of wire made out of some fancy conductive crap that I don't know the name of) has blown. It will cost u about £3 And 5 minutes of your time to replace anyway.
"whoever said progress was a slow process... was probably talking about me"
post Sep 12, 2014 - 6:19 PM
1994Celica
Joined Aug 5, '09
I never use my cgi lighter. I want to convert it to a USB port.
JDM Part King
post Sep 12, 2014 - 6:43 PM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
QUOTE (1994Celica @ Sep 12, 2014 - 7:19 PM) *
Thats what i would like to do with mine
post Sep 12, 2014 - 7:03 PM
Box
Joined Feb 23, '12
From Warrior, AL
Cars don't even have cigarette lighters anymore, it's sad.
post Sep 12, 2014 - 7:14 PM
1994Celica
Joined Aug 5, '09
QUOTE (Box @ Sep 12, 2014 - 7:03 PM) *
But the have usb ports now! I'm okay with that since I don't smoke.
JDM Part King
post Sep 12, 2014 - 8:05 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
the lighter might just not be plugged in from the back.
Today I called FedEx and confirmed the motor drumbum sent me is here at the terminal and set up a delivery for Monday.
which is good because after $600 and 2 weeks later I was beginning to wonder.
saves me and my Ball-Ping hammer a trip to St Louis...
Bust a Deal; Face the Wheel.
post Sep 12, 2014 - 8:06 PM
Box
Joined Feb 23, '12
From Warrior, AL
I don't either, but what if I want to warm up a can of soup while driving? Now I can't.
post Sep 12, 2014 - 8:14 PM
1994Celica
Joined Aug 5, '09
QUOTE (Box @ Sep 12, 2014 - 9:06 PM) *
Problem solved...
http://www.amazon.com/RoadPro-12-Volt-Port...k/dp/B00030DLEE
JDM Part King
post Sep 12, 2014 - 8:33 PM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
QUOTE (1994Celica @ Sep 12, 2014 - 9:14 PM) *
Problem solved...
Ok that literally made my night and me $31 poorer. I need to figure out if its a fuse or if i need to splice something completely different in
post Sep 12, 2014 - 9:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just need one of those and a mini-fridge and we're good to go.
Lo-Fi Version Time is now: November 26th, 2024 - 8:14 PM
