516 Pages V  « < 451 452 453 454 455 > »
post Nov 4, 2014 - 2:00 PM
Lamont
Joined Aug 18, '11
From Cochranville, PA.
QUOTE (Lamont @ Nov 2, 2014 - 5:17 PM) *
Today I finally got everything installed on my 1MZ FE swap, but sadly it doesn't start, it will only cranks. I have fuel at the rail, but I ran out of daylight and didn't get to check compression or spark. Well time to troubleshoot kindasad.gif kindasad.gif
My findings so far; There is no CEL, I have 0 spark on all 6 cylinders, there is fuel pressure at the rail, and my compression numbers are:
cyl1 - 200
cyl2 - 200
cyl3 - 200
cyl4 - 196
cyl5 - 198
cyl6 - 205
I'm guessing I could possibly have a dead igniter. Any thoughts? I won't be able to get to the junk yard until Friday to grab another igniter.
post Nov 4, 2014 - 3:34 PM
Box
Joined Feb 23, '12
From Warrior, AL
No spark... Cam or crank sensor perhaps?
2001 Miata LS 5-speed
post Nov 4, 2014 - 4:08 PM
Lamont
Joined Aug 18, '11
QUOTE (Box @ Nov 4, 2014 - 4:34 PM) *
Both are brand new. Not saying it isn't possible that one or both are bad. I think I threw out the old sensors so I'll have to grab some from the junk yard as well.
post Nov 4, 2014 - 4:56 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'd just double check they're connected properly and that the wiring hasn't been crushed or what have you. Should be able to test any components with a multi-meter to make sure they're bad before replacing.
post Nov 4, 2014 - 5:05 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
You'll need to get the engine started and warmed up to temperature before seeing if you have any codes or getting an accurate compression check. Does your CEL light up when you turn the key on?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 4, 2014 - 5:30 PM
Lamont
Joined Aug 18, '11
QUOTE (richee3 @ Nov 4, 2014 - 6:05 PM) *
No, with the key in the on position the only lights on the dash are the battery, oil, and seat belt. Once I turn it over the oil light goes out and only the battery and seat belt light remain on.
post Nov 4, 2014 - 5:36 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
Your ECU isn't getting any power if the light doesn't turn on with the key on.
1998 Celica GT-
BEAMS Swapped.
post Nov 4, 2014 - 5:40 PM
Lamont
Joined Aug 18, '11
QUOTE (richee3 @ Nov 4, 2014 - 6:36 PM) *
Would this be caused by a fuse or relay?
post Nov 4, 2014 - 6:34 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'd check the fuses.
post Nov 5, 2014 - 12:24 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
yes if you are not getting a CEL in the on position then the ECU is not getting power. If its a harness issue ill be happy to take responsibility. First we need to figure out why you dont have power. This could be a fuse, or relay, or something on your car. This could also be because the grounds are not making good connections. there are 2 grounds in the harness, one gets bolted to the back of your block and the other get bolted to the side on the ACIS housing.
if those are both good look at the drawing and confirm that you have power going to the ECU. For all you know its the ECU itself.
also if you made a dedicated thread I would have seen this sooner. Sorry about the CAM sensor breaking off, That could have happened as you were installing the harness. I ohm checked every trace so it was all good when i sent it out.
Start a dedicated thread so I can keep track of what troubleshooting has been done. Im not going through several different posts in this thread to keep up. Im not gonna leave you hanging. we will figure this out.
This post has been edited by Smaay: Nov 5, 2014 - 12:27 AM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 5, 2014 - 2:46 AM
DST94
Joined May 11, '09
From California
+1 to the amazing Smaay. Check out that customer service. I'd let him do my swap if I didn't have major trust issues with people and my Celica :3
post Nov 8, 2014 - 4:59 PM
mkernz22
Joined May 10, '10
From MA
This happened, check my thread for more info.
post Nov 8, 2014 - 7:24 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Nov 8, 2014 - 7:50 PM
Lamont
Joined Aug 18, '11
Today this:
1st startup 1MZ-FE v6 swap
post Nov 8, 2014 - 9:42 PM
HaysoosKreesto
Joined Nov 4, '09
From Sacramento, California
QUOTE (Lamont @ Nov 8, 2014 - 7:50 PM) *
I loved the way it sounded wow
post Nov 12, 2014 - 6:24 PM
the harness i got for the 2gr swap, does not have what i need, and wasted 170 bucks..
all i got is a bunch of wires..
post Nov 12, 2014 - 6:31 PM
Malek
Joined Jan 26, '09
From Los Angeles
Plowed through 4-5in of fresh snow this morning..
awd ftw
post Nov 15, 2014 - 12:48 PM
CelicaDICE
Joined Nov 13, '14
From MIA
Bought a pair of these for a $150. http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/f...z/$_57.JPG
Rare JDM Dealer Option Parking(Proximitiy) Senor for sale
http://www.6gc.net/forums/index.php?showtopic=97051
post Nov 15, 2014 - 10:29 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
^nice!
Today I washed my car has put on my new plates. My car was terribly dirty. I would clean it more often but plastidip is a small pain to keep clean.
JDM Part King
post Nov 18, 2014 - 10:04 AM
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 23rd, 2024 - 10:08 AM
