516 Pages V  « < 476 477 478 479 480 > »
post Jun 5, 2015 - 10:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'm sure you'll do fine, plus there's the guides here and I'm sure people will help if any problems arise. If anything the hardest part of the swap will be doing the manual conversion.
2001 Miata LS 5-speed
post Jun 5, 2015 - 11:52 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
QUOTE (Box @ Jun 5, 2015 - 11:58 PM) *
Honestly that's the part I'm worried about the most. The Beams wiring seems straight forward but going from auto to manual seems like it'll be challenging,
JDM Part King
post Jun 6, 2015 - 12:00 AM
sircalebwhite
Joined Jan 12, '15
From Cambridge, Minnesota
QUOTE (1994Celica @ Jun 6, 2015 - 12:52 AM) *
The swap shouldn't be too bad because you have a 94. From what I read it shouldn't be too challenging! Gonna hopefully swap mine out this fall and im feeling confident about it!
post Jun 6, 2015 - 12:10 AM
sircalebwhite
Joined Jan 12, '15
Box, I replaced the valve cover gasket last month and have been frequently checking around it to make sure it isn't leaking and so far it hasn't leaked a drop! But I think you're right on the seals... On the pass. side I took the wheel off to get a look at it in there and holy s**t is it wet...
I'm not sure what it is but I just feel like something is a little bit off.. Literally... I have more pics too but the quality isn't the best... I'll post them in a different thread tho!
sircalebwhite
Joined Jan 12, '15
post Jun 6, 2015 - 4:37 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (1994Celica @ Jun 5, 2015 - 11:52 PM) *
I know Ferdi did a manual conversion here recently, but his was the ST. Though things like the pedal assembly and clutch master should be the same, so should the shifter assembly aside from the cable I believe. Then it's just a matter of getting the right trans mount, and more less doing a clutch job.
Caleb, I'd clean the area off with some degreaser if you haven't already then check again in a few days to see if you can't get a better idea as to where it's coming from.
This post has been edited by Box: Jun 6, 2015 - 4:38 AM
post Jun 6, 2015 - 11:56 AM
mkernz22
Joined May 10, '10
From MA
The manual swap isn't that hard at all. Since you had an auto, you need to wore the neutral safety switch to the clutch start switch. There should already be a plug in there for the cruise control kill switch on the clutch pedal. Just disengages the cruise when you shift.
Other than that, its fairly straight forward. Get a hole saw for the clutch pedal, easiest way to drill that out. The only tedious parts are getting the shifter cables hooked up, getting the manual brake pedal in (swap the pedal, not the whole assembly, its a lot easier), and getting the hard line for clutch in place. Oh, and bleeding the clutch.
Other than that, its not too bad. I've done it twice already
post Jun 11, 2015 - 10:15 PM
richee3
Joined Jun 29, '08
From Denver
Replaced the starter on my Celica today. Starts much nicer now. Back into DD duty for my last few weeks at my current job!
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 12, 2015 - 12:11 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
Alternator went out today, ...gee too bad I didn't already have one.
aside from that,
The neighbors are leaving notes on my car.
Sorry not for sale.
Bust a Deal; Face the Wheel.
post Jun 12, 2015 - 10:13 AM
sandusky1977
Joined Oct 3, '10
From Lansing, MI
Today I received this, so next week I'll be building!!!
Monkeywrench Racing
Order Number: 21XXX
Detailed Invoice: http://www.monkeywrenchracing.com/account_...?order_id=21XXX
Date Ordered: Thursday 11 June, 2015
The comments for your order are
United States Postal Service (Priority Mail) 9405511899562148XXXXX
Your order has been updated to the following status.
New status: Shipped
post Jun 12, 2015 - 11:56 PM
Honestly that's the part I'm worried about the most. The Beams wiring seems straight forward but going from auto to manual seems like it'll be challenging.
If you have the right tools in addition to time, then you'll be fine. A little MacGyvering here and there...it's all in the details. Make sure you have a clutch alignment tool, the axle seals, new flywheel/pressure plate bolts, things like that. The other two mentioned most of the swap difficulties and I'll add that getting the transmission and mount to cooperate with the crossmember is a royal PITA.
post Jun 15, 2015 - 3:08 PM
Jeebus
Joined Apr 21, '13
From YYC
I had a dream that I was driving my car despite its blown turbo and 3 cylinders working. "Whoaa, I can still drive this!"
Then I woke up and reality set in, seeing my current DD parked out front that my friend has kindly lent me for the time being, a Chevy Equinox. frown.gif
post Jun 15, 2015 - 5:14 PM
Box
Joined Feb 23, '12
From Warrior, AL
I feel your feels, turns out the trans in my Firebird was trash and now I'm having to borrow my brother's 2000 Durango.
post Jun 15, 2015 - 9:13 PM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
I also feel your pain, I'm rocking a 1994 Camry that I just bought while my car is MIA
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Jun 16, 2015 - 12:06 AM
Box
Joined Feb 23, '12
From Warrior, AL
You were all jacked to get that Camry, it's not the same for you. tongue.gif
post Jun 16, 2015 - 6:16 PM
sircalebwhite
Joined Jan 12, '15
Today I gave my baby a much needed washing. It cleans up so nice!! I also just recently got a job after being unemployed over the last 3 weeks and start on Thursday. Finally get more money to start fixing the car! Shopping list (in order) is timing case seal, timing belt, water pump, t-stat, oil pan gasket/resealing, custom exhaust or just replacement flex-pipe, front tires, rear struts, and after some time brakes all around. Gonna go at it all slowly as it's my dd and it's all not that bad. Aside from the oil leaks..
post Jun 16, 2015 - 8:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
Congrats on the job.
post Jun 17, 2015 - 6:27 PM
sircalebwhite
Joined Jan 12, '15
Thanks! I'll be starting as a Lube Tech at a local Ford dealership. Not a big fan of Ford but at least I have a job now!
post Jun 17, 2015 - 7:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
That and it's not fast food!
post Jun 17, 2015 - 10:07 PM
sircalebwhite
Joined Jan 12, '15
I will never work fast food. I'll go back to pushing carts at Wal-Mart before fast food!
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 23rd, 2024 - 11:33 AM
