Dash lights problem, :( |
Apr 18, 2010 - 9:19 PM |
Enthusiast Joined Aug 5, '09 From Oakley, CA Currently Offline Reputation: 15 (100%) |
Well, after taking my car to the drags, my car has a weird problem. My dash lights don't work. That includes even the AC lights.
I checked the 7.5A Panel fuse and it was popped, so I replaced it and turned on my lights and it popped again. Before I go tear apart my car, has anyone ever had this problem? I hope there's an easy fix.. -------------------- 1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver |
Apr 19, 2010 - 12:25 AM |
Enthusiast Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
I had the same issue.... any new electrical additions? My issue was that one of the wires from my aftermarket stereo got loose and was grounding out(radio still worked so I was scratching my head for a while). Fixed the wire, fixed the fuse and it worked. Check all the electronics and make sure all the connections are contacting correctly and nothing is grounding out.
Apr 19, 2010 - 1:46 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
your celica is bitchin' at you for beating it at the track
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Apr 19, 2010 - 2:24 AM |
Enthusiast Joined Jan 21, '09 From Hawaii Currently Offline Reputation: 0 (0%) |
Concur with Dabazied; your electrical ...if it's a headlamp, I'd still start at the lens. Check for cracks / breaks / moisture where the bulb contacts the socket... but other culprits, as D said, an amp for a speaker box? accessories? home mods added?
Look forward to hear what the problem ends up being...post pics when you find the short/ground |
Apr 28, 2010 - 1:10 PM |
Enthusiast Joined Apr 11, '10 From Las Vegas Currently Offline Reputation: 0 (0%) |
I have the same problem, my radio and all interior lights work except for my dash. replaced the fuse and it went out the nexy day. Dont know?
Jun 10, 2010 - 10:20 PM |
Enthusiast Joined Nov 15, '09 From Lima-Peru Currently Offline Reputation: 1 (100%) |
hey guys I have a similar problem, my dash and AC do not go on! where is the 7.5A fuse?
Lo-Fi Version | Time is now: January 16th, 2025 - 12:18 AM |
