Liquid cooled Turbo Exhaust Manifold |
Apr 19, 2010 - 12:03 AM |
Enthusiast Joined Apr 22, '09 From MN Currently Offline Reputation: 0 (0%) |
As i was building my water cooled computer, it just dawned on me that no one has ever tried a water cooled exhaust manifold. I think this would drop the engine bay temp by a bunch numbers. And for those that use fiberglass wraps, this will the end of that.
I was thinking maybe welding small bases on each exhaust manifold pipe and have liquid running to the radiator much like a computer cooler. I would love to see this for our 5sfe and 3sgte if its already out there!! This post has been edited by xlee: Apr 19, 2010 - 12:06 AM |
Apr 19, 2010 - 12:13 AM |
Enthusiast Joined Aug 5, '09 From Oakley, CA Currently Offline Reputation: 15 (100%) |
Use oil... Doesn't heat up as quick
-------------------- 1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver |
Apr 19, 2010 - 5:57 AM |
Enthusiast Joined Feb 6, '08 From Latvia Currently Offline Reputation: 0 (0%) |
oil would be better. either way you would need a superior radiator. if the housing cracks, you would be risking an explosion of your diy box.. coolant expands and vaporizes at extreme rate!when pushing the turbo hard, the header/turbo would raise high above 100C and would smoke the coolant into gas instantly..
+1 for idea -1 for trying to acoomplish that -------------------- 1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ |
Apr 19, 2010 - 8:03 AM |
Enthusiast Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) |
Please do tell more about your PC build.
-------------------- "God created turbo lag to give V8's a chance"
Apr 19, 2010 - 1:09 PM |
Enthusiast Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) |
Isnt the idea with exhaust for it to be at a high temp because then the liquid flow rate out of the exhaust system is higher, giving a lower backpressure and cleaner exit from the system?
Apr 19, 2010 - 5:36 PM |
Apparently, Boats have this technology.
http://www.marineengine.com/boat-forum/sho...ad.php?t=289794 anyone in here a marine tech? My pc is a Intel I7-920 with water coolers of course. The rest of the other parts are typical gamer's specs. |
Apr 20, 2010 - 10:36 AM |
Nice, I went AMD 965. What video card?
Apr 20, 2010 - 4:59 PM |
As i was building my water cooled computer, it just dawned on me that no one has ever tried a water cooled exhaust manifold. I think this would drop the engine bay temp by a bunch numbers. And for those that use fiberglass wraps, this will the end of that. I was thinking maybe welding small bases on each exhaust manifold pipe and have liquid running to the radiator much like a computer cooler. I would love to see this for our 5sfe and 3sgte if its already out there!! you want to keep heat IN the exhaust manifold. heat and the rapid expansion of gasses is what spools the turbo. the "fiberglass wrap" is actually used to keep heat in the exhaust manifold, not help cool it. ceramic coating does the same thing. keeps heat in the exhaust manifold, which in turn lowers engine bay temps. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 20, 2010 - 6:03 PM |
Grimmspeed will ceramic coat anything, and I believe turbo manifolds that they coated showed temps somewhere around 60 degrees. They said they were able to get out after hard driving and grab the manifold with their bare hands.
Ceramic coating +1 -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 20, 2010 - 6:04 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
As i was building my water cooled computer, it just dawned on me that no one has ever tried a water cooled exhaust manifold. I think this would drop the engine bay temp by a bunch numbers. And for those that use fiberglass wraps, this will the end of that. I was thinking maybe welding small bases on each exhaust manifold pipe and have liquid running to the radiator much like a computer cooler. I would love to see this for our 5sfe and 3sgte if its already out there!! you want to keep heat IN the exhaust manifold. heat and the rapid expansion of gasses is what spools the turbo. the "fiberglass wrap" is actually used to keep heat in the exhaust manifold, not help cool it. ceramic coating does the same thing. keeps heat in the exhaust manifold, which in turn lowers engine bay temps. ^^ what he said -------------------- Breaking Axles...
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:51 PM |
