3sgte clutch start wiring, need a help with wiring the clutch start on 3rd gen 3s |
Apr 24, 2010 - 11:54 AM |
Enthusiast Joined Aug 4, '06 From Toronto Currently Offline Reputation: 0 (0%) |
hey guys i have been reading the forums on how to do this , I know that on the 5s body harness "Ij1" plug needed to have the black wire removed and place in the st205 "IJ1" plug as it was seen on the 5s,
For the wiring i been looking for the diagrams that would show which wires need to be wiring in the new plug on the St205 "IJ1" , but having no luck . other forums are saying by the body plugs there is a black wire that spits in to 3 other black wires , and the new add wire for the 5s is need to be wired to them ? does that mean no cutting in needed ? or just tap in to wiring ? so i have traced the 3 black wires coming on the st205 harness and seen that one goes to the ecu plug, other in to the body relay plug and the other in to the white body plug on the st205 harness which wires are for the clutch start for the st205 ? Thanks |
Apr 24, 2010 - 1:29 PM |
move pin #18 (black wire) from the white plug to pin #17 on the dark grey plug.
Apr 24, 2010 - 8:11 PM |
Thanks Bro
Lo-Fi Version | Time is now: November 25th, 2024 - 7:48 AM |
