> alarm help!, Keeps coming on.
post Apr 24, 2010 - 9:24 PM
moki2001
Joined Mar 30, '10
From Dolores Colorado
New to me 1996 Celica convertible. Battery went dead, and now the alarm goes off every time I open the doors. Any ideas? I have never had an alarm on a car. There is no obvious shut off on the key.
post Apr 25, 2010 - 1:11 AM
howie_vang
Joined Jul 11, '08
From Cali
if you don't have an alarm for the car then the best thing to do now is to locate the kill switch in your car. it is mostly located near where the clutch is at right in the left corner. there should be a small button you can find it by using your fingers to locate it. then turn ur key not all the way and press he button. mess wid it. see if it works.
post Apr 25, 2010 - 8:15 AM
moki2001
Joined Mar 30, '10
I found a tiny toggle on the plastic panel next to the clutch. I will try this after the rest of the family wakes up. Thanks
Update. Yes, that certainly worked! Since we don't even lock our doors here in Dolores Colorado I don't know much about alarms. Thanks!
This post has been edited by moki2001: Apr 25, 2010 - 9:53 AM
Lo-Fi Version Time is now: December 1st, 2024 - 4:06 PM
