8 Pages V  « < 3 4 5 6 7 > »
> Evolving into a Celestial Dragon, a 3SGTE Swap (Pictures in Album)
post Nov 8, 2010 - 3:21 PM
Culpable04
Joined Apr 17, '06
From New Jersey
it all comes down to grounds ! check for lose grounds, disconnected or even crack ground wires.
post Nov 8, 2010 - 7:25 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (Culpable04 @ Nov 8, 2010 - 1:21 PM) *
Ill keep looking for grounds, not sure where I'll find them heh but Ill keep looking...
This post has been edited by Soulend: Nov 8, 2010 - 9:46 PM
post Nov 11, 2010 - 12:15 AM
honestly i dissambled my harness and inspected it all, to check for imperfections. and rewired some.
post Nov 11, 2010 - 9:38 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (njccmd2002 @ Nov 10, 2010 - 10:15 PM) *
I had Dr Tweak and his crew work on it for me...
anyway its running.... some how fixed the problem I'm not sure what did it...
now the horrors of vacuum lines :\
oh btw, I know Culp said he got his ST steering lines too work, but mine don't want to work... and i seriously dont want to pay for new ones... so I got the bolt on the pump for the connector loosened so I can move it. but no matter where I put it the line will not match up... any suggestions on how to get them to mate properly?
Kevin
This post has been edited by Soulend: Nov 11, 2010 - 11:43 PM
post Nov 12, 2010 - 8:24 AM
Culpable04
Joined Apr 17, '06
From New Jersey
I have to tighten my power steering belt, if I get to it this weekend I'll take pictures.
post Nov 12, 2010 - 8:37 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
i just did mine the other day. you can twist the metal connector around. i took the hose (that goes straight up to the pump) off first, then connected the bolt with washer.
it is tough, but it will bolt on.
post Nov 12, 2010 - 9:54 AM
kev, when you DO get it lined up, make sure you use new crush washers.
if not, you'll have to get it SUPER tight before it wont leak.
post Nov 12, 2010 - 11:18 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Just letting you know Kevin, I've been following this thread like a hawk since it started lol
June '12 COTM
'95 AT200
post Nov 12, 2010 - 2:38 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
heh thanks guys, I've given up for now, I hurt my hand and arm too much... plus i was getting majorly frustrated... eh i have class anyway, Ill try again later.
Kevin
post Nov 12, 2010 - 2:42 PM
HectortheRican
Joined Dec 26, '09
That swap needs to be Rick rolled by you. You will never give that swap up. You'll never let it down. You'll never run around and desert it.
June '12 COTM
'95 AT200
post Nov 12, 2010 - 8:29 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (HectortheRican @ Nov 12, 2010 - 12:42 PM) *
*Thumbs up!* made me lol.
so another update,
installed the new/old TVSV Manny sent me! Thanks a lot! biggrin.gif. umm finally got the steering pump figured out, however, Stevenson, if you could still take those pictures they maybe of use for me! most of the vac lines are hooked up. just steering and the IAC I believe. I think i might do something similar to what manny did and just put a small filter in for that.
here is a video:
http://www.youtube.com/watch?v=NmpNqAcbUw0
post Nov 12, 2010 - 8:30 PM
purplegt4
Joined Feb 7, '03
get a helper to twist the bolt while you're holding it in place.
post Nov 12, 2010 - 8:34 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (purplegt4 @ Nov 12, 2010 - 6:30 PM) *
my problem is, I'm not sure how to get it really tight haha
post Nov 13, 2010 - 5:17 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
wooot! she purrs beautifully now! Ill take a video after I go bowling with the Japanese Association (I'm a club officer) then Ill try and tighten up the steering and get filters mounted up and the inter-cooler figured out then the beast is done! well on my end anyway haha
Kevin
post Nov 13, 2010 - 6:26 PM
HectortheRican
Joined Dec 26, '09
AWESOME!
June '12 COTM
'95 AT200
post Nov 13, 2010 - 10:39 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
As promised a video for your enjoyment!
http://www.youtube.com/watch?v=hF5ps3pmb4o
Kevin
post Nov 13, 2010 - 10:41 PM
nice finally
post Nov 13, 2010 - 10:55 PM
HectortheRican
Joined Dec 26, '09
It sounds so damn THROATY
June '12 COTM
'95 AT200
post Nov 13, 2010 - 11:07 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (HectortheRican @ Nov 13, 2010 - 8:55 PM) *
that sir... is a 3" down pipe at work lol
post Nov 13, 2010 - 11:13 PM
HectortheRican
Joined Dec 26, '09
Is it just the downpipe or have you connected the exhaust?
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: November 26th, 2024 - 10:24 AM
