> FS WRC MOTOR SET, Persoanlly removed from a half cut
post Apr 29, 2010 - 7:07 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
Over the past weekend an ST205 half cut I had ordered came in. It is a 1995 WRC ST205. I put the front end on Shannons car and I will be selling the complete motor set. I checked compression on Saturday and it was in great shape.
I will be personally removing this engine set from the half cut, so rest assured you will be receiving EVERYTHING required for the swap and some.
Parts included in the swap are
WRC engine
WRC transmission
uncut wiring harness
WRC ECU
map sensor
WRC turbo
WRC Blow off valve
WRC air box
WRC intake piping
WRC W2A IC
WRC front heat exchanger
WRC passenger side motor mount
WRC driver side motor mount with mounting tabs for the stock hard lines for the IC setup
WRC pump
etc.
Again, you will be receiving EVERYTHING required and some to install into your Celica. No need to run around sourcing missing parts.
Price with the factory W2A IC setup is 2400 with free shipping to your door
Price without the factory W2A IC setup is 2000 with free shipping to your door
Any questions, feel free to ask.
330whp 309ft/lbs @ 21 PSI
post Apr 29, 2010 - 8:40 PM
block
Joined Jul 27, '06
From Soda
damn, excellent price. wish i was ready to order one! GL bro.
post Apr 29, 2010 - 11:24 PM
Nartanian
Joined Mar 26, '09
From Minnesota
What were the compression #'s on all 4 cylinders?
"God created turbo lag to give V8's a chance"
post Apr 30, 2010 - 4:13 AM
joehernandez
Joined Aug 5, '06
From San Luis AZ
i hope is not my engine you are selling jim lol
Lo-Fi Version Time is now: February 24th, 2025 - 12:14 AM
