> black headlight housing?
post May 4, 2010 - 2:03 PM
reggaestylin
Joined Nov 8, '09
From Tampa, FL
does anyone know where i can get some black headlight housings? i've been searching for some time and i haven't gotten any luck
post May 4, 2010 - 2:20 PM
mak5603
Joined Oct 20, '08
custom
2014 Toyota Rav4 XLE
post May 5, 2010 - 1:33 AM
Espo
Joined Aug 11, '09
From Buffalo, NY
QUOTE (reggaestylin @ May 4, 2010 - 3:03 PM) *
We have zero aftermarket headlights for our cars. It's either USDM or JDM Projectors, or custom work.
post May 5, 2010 - 3:24 AM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
QUOTE (reggaestylin @ May 4, 2010 - 12:03 PM) *
take them apart, and spray them black yourself
it's pretty easy, i did it also for my projector housing
use a heat gun to soften up the glue and carefully pry it apart, take out the parts u want to paint, wet sand it with maybe 5-600 grit paper, spray on 3-4 coats, let it dry, buy some adhesive silicone and put it all back together
post May 23, 2010 - 11:43 PM
reggaestylin
Joined Nov 8, '09
From Tampa, FL
thanx for the help guys
post May 24, 2010 - 12:00 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
if you are going to spray, use vht nightshades, its translucent, it wil let light through and give you the smoke look you want.
post May 24, 2010 - 7:38 PM
D-Man
Joined Jan 18, '08
From Houston
Damn D-Man - most impressive.
post May 25, 2010 - 10:50 PM
reggaestylin
Joined Nov 8, '09
From Tampa, FL
im prob going to do what nammer was talking about n just painting the inside. im going to leave the lens alone. if i dont like it i'll just smoke out the lens afterwards
post May 26, 2010 - 1:14 PM
Prometheus
Joined Apr 5, '09
From B.C. Coquitlam
lets see some pictures!
Lo-Fi Version Time is now: November 26th, 2024 - 11:29 PM
