> Shock went out??, I'm not sure..
post May 5, 2010 - 10:25 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Today, I noticed a popping sound from my right front shock. I'm assuming that it just died. True or false?
June '12 COTM
'95 AT200
- HectortheRican   Shock went out??   May 5, 2010 - 10:25 PM
- - 96stgreendemon   could be a number of things, strut, wheel bearings...   May 6, 2010 - 9:14 AM
|- - HectortheRican   QUOTE (96stgreendemon @ May 6, 2010 - 9...   May 6, 2010 - 2:39 PM
- - samir0189   you should probably just change your struts, strut...   May 6, 2010 - 2:44 PM
|- - HectortheRican   QUOTE (samir0189 @ May 6, 2010 - 2:4...   May 6, 2010 - 3:06 PM
- - 96stgreendemon   one word, coilovers   May 6, 2010 - 8:16 PM
|- - HectortheRican   QUOTE (96stgreendemon @ May 6, 2010 - 8...   May 7, 2010 - 12:30 AM
- - 4-eyed-freek   change your bushings b/c that happend to me and i ...   May 7, 2010 - 6:34 AM
- - HectortheRican   Okay question. If I can push down on the struts an...   May 7, 2010 - 7:35 AM
- - SwissFerdi   The one that stayed stiff isn't blown.   May 7, 2010 - 9:44 AM
|- - HectortheRican   QUOTE (SwissFerdi @ May 7, 2010 - 9...   May 7, 2010 - 9:49 AM
- - HectortheRican   I'm looking up the KYB GR2s and from what I...   May 7, 2010 - 9:54 AM
- - SwissFerdi   No, I have four full assemblies. Part numbers for...   May 7, 2010 - 9:59 AM
|- - HectortheRican   QUOTE (SwissFerdi @ May 7, 2010 - 9...   May 7, 2010 - 10:02 AM
- - SwissFerdi   I bought the rears from Amazon and the fronts from...   May 7, 2010 - 10:03 AM
|- - HectortheRican   QUOTE (SwissFerdi @ May 7, 2010 - 10...   May 7, 2010 - 10:56 AM
- - Galcobar   Are the front struts on the sixth-gen rebuildable?...   May 9, 2010 - 3:48 PM
|- - HectortheRican   QUOTE (Galcobar @ May 9, 2010 - 3:48...   May 9, 2010 - 6:37 PM
- - Spider77   If your riding on original gear, Id say time for a...   May 9, 2010 - 8:20 PM
|- - HectortheRican   QUOTE (Spider77 @ May 9, 2010 - 8:20...   May 10, 2010 - 12:15 AM
- - Spider77   re-buildable inserts.   May 10, 2010 - 4:19 AM
|- - HectortheRican   QUOTE (Spider77 @ May 10, 2010 - 4:1...   May 10, 2010 - 7:34 AM
- - SwissFerdi   Nothing, they're all the same as far as I know...   May 10, 2010 - 10:26 AM
|- - HectortheRican   QUOTE (SwissFerdi @ May 10, 2010 - 10...   May 10, 2010 - 10:35 AM
- - Spider77   Actually after a bit of looking, not much I think....   May 10, 2010 - 10:42 AM
- - AnaXyd   The rear struts is rebuildable as well, but you ne...   May 12, 2010 - 3:51 AM
|- - HectortheRican   QUOTE (AnaXyd @ May 12, 2010 - 3:51 ...   May 12, 2010 - 11:24 AM
- - Spider77   Well, Ive already did this, so if you have the too...   May 14, 2010 - 8:30 PM
|- - HectortheRican   QUOTE (Spider77 @ May 14, 2010 - 8:3...   May 14, 2010 - 11:53 PM
- - AnaXyd   You actually need a hacksaw and a drill. Thats it....   May 15, 2010 - 5:45 PM
|- - HectortheRican   QUOTE (AnaXyd @ May 15, 2010 - 5:45 ...   May 15, 2010 - 8:49 PM
|- - AnaXyd   QUOTE (HectortheRican @ May 15, 2010 - 8...   May 16, 2010 - 11:46 AM
|- - HectortheRican   QUOTE (AnaXyd @ May 16, 2010 - 11:46...   May 16, 2010 - 12:50 PM
- - Spider77   Ahhhh...was not all that aware that Koni's wer...   May 15, 2010 - 8:28 PM
- - azian_advanced   loosening that nut that holds the cartridge in was...   May 15, 2010 - 10:07 PM
- - Spider77   Wow, did not have to resort to that. A vice worke...   May 15, 2010 - 11:24 PM
- - azian_advanced   in case no one noticed, in those pics they use a h...   May 16, 2010 - 3:09 PM
- - AnaXyd   It is the same procedure on the McPherson struts. ...   May 16, 2010 - 3:50 PM
Lo-Fi Version Time is now: April 23rd, 2025 - 11:37 PM
