3 Pages V  < 1 2 3 >
> Swedish 5s-gte stroker, Work in progress of a st205 with 5s-gte with borgwarner s254
post Jan 22, 2014 - 1:19 PM
mikaelhoglund
Joined Aug 7, '07
From Sweden
The engine is running alot biggrin.gif did a few 1/4mile runs last year, best was 11.61 found here on youtube: http://youtu.be/nO10T46E_Tw
Then in hit the dyno in august biggrin.gif 500whp and 600engine hp as a result. http://youtu.be/IJUq6jr9mbw
The best thing was the insane torque: 811nm@4300rpm in engine, almost 600ft/lbs
This winter i´m rebuilding to a new manifold and a bit bigger turbo borg warner custom s256 instead of the s254 from last year.
I have changed rods and new bearings in the hole engine.
New externa wastgate
New intercooler and piping
Also going to install rollcage and new seats. Fia aproved.
Changed my center diff to a hard one 340nm instead of 170stock.
Here are some pictures:
Engine in car again:
Oh i forgot. Hopefully new brake discs and then im rebuilding a set of broken TRD Coilovers with new konisport inserts and refurbish all.
Mikael /// Sweden
St205 Co owner in www.jc-performance.se
Pictures at: http://www.jc-performance.se/galleri.php?id=19
On vacation in US from 25aug-4sep in the tri state area
post Jan 22, 2014 - 4:46 PM
Ted95
Joined Mar 8, '09
From Westport, MA
Nice man! what year 5s block are you using, looks to be pre-98, its holding up okay for you? were you using a 3sge oil pan setup or a 3sgte oil pan, a previous post had me confused.
st205 powered ss3 coupe
post Jan 23, 2014 - 4:49 AM
mikaelhoglund
Joined Aug 7, '07
From Sweden
QUOTE (Ted95 @ Jan 22, 2014 - 5:46 PM) *
I'm using a camry 92 5s block and Gen3 3s oilsystem, it works great ;-)
Mikael /// Sweden
post Jan 23, 2014 - 3:14 PM
onnaj
Joined Sep 6, '12
From Holland
post Jan 23, 2014 - 3:42 PM
Neon90424
Joined Jan 19, '11
awesome work dude, I will def. visit you once my st205 is in sweden.
post Jan 25, 2014 - 12:36 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Very nice build mate! Did you finally take pictures of your external wastegate routing? I'd love to see it done biggrin.gif
How loud are the walbros together, is it that bad? I listened carefully in your dyno video but it's hard to tell when the engine is running.
Is it really annoying when running or do you only hear them at idle?
post Jan 28, 2014 - 10:55 AM
mikaelhoglund
Joined Aug 7, '07
From Sweden
QUOTE (dudeofchaos @ Jan 25, 2014 - 1:36 PM) *
After i hade this tread I installed a Walbro GST450 in my tank, i used the old pressure side from the tank as an return, and installed a 1/2" alupipe to the front with an8 the last bit.
Here are pictures of the done manifold.
But now i´m building a new manifold in stainless steel biggrin.gif and with a 46mm wastegate.
Mikael /// Sweden
post Jan 28, 2014 - 6:05 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (mikaelhoglund @ Jan 28, 2014 - 12:55 PM) *
Nice! Is it an OEM fit as it's an in-tank pump or are modifications needed?
But all this work to finally replace this for a SS manifold? A lot of efforts sent straight to trash haha kindasad.gif
This post has been edited by dudeofchaos: Jan 28, 2014 - 6:06 PM
post Jan 28, 2014 - 11:55 PM
Ted95
Joined Mar 8, '09
From Westport, MA
I hope I didn't miss this somewhere, but which throttle body are you using with the gen4 intake manifold?
Ted95
Joined Mar 8, '09
From Westport, MA
post Jan 29, 2014 - 2:19 AM
mikaelhoglund
Joined Aug 7, '07
From Sweden
QUOTE (Ted95 @ Jan 29, 2014 - 12:55 AM) *
Its the caldina stock gen3 throttlebody i think biggrin.gif or gen 4. But a friend of my uses a 2zz tsport engine throttle and it fits also nicely
Mikael /// Sweden
post Jan 29, 2014 - 11:56 PM
Ted95
Joined Mar 8, '09
From Westport, MA
If it is a gen3 tb, did you keep the IACV and cut a notch in the manifold or eliminate the IACV ?
post Jan 30, 2014 - 8:45 AM
I applaud the use of the anti-lag ports for the external wastegate that is very impressive!
post Jan 31, 2014 - 6:04 PM
mikaelhoglund
Joined Aug 7, '07
From Sweden
QUOTE (dudeofchaos @ Jan 28, 2014 - 7:05 PM) *
The pump fits good in the tank. I used a hoseclamp to tighten the pump in the oem place. But i needed bigger hoses for the pressure side, i did drill a new hole throgh to the tank and installed a 90degrees fitting and installed 1/2" alupipes all the way under the car. then used to old pressure pipes a return to the tank and shifted hoses on the top.
QUOTE (Ted95 @ Jan 30, 2014 - 12:56 AM) *
I use the gen3 manifold and use the Idle motor in it. but i do not have any water connected to it just controlling it with my Link ECU. hope this answers your question.
Mikael /// Sweden
post Feb 4, 2014 - 4:33 PM
mikaelhoglund
Joined Aug 7, '07
From Sweden
Pictures of todays work...
My engineloom is done for this winter, redone it a little bit.
Mikael /// Sweden
post Feb 11, 2014 - 2:10 PM
mikaelhoglund
Joined Aug 7, '07
From Sweden
I have tonight started the engine again after the rebuild.
this week i also orderd some nice parts from rt-performance in UK they are comming to sweden this weekend. smile.gif
I orderd the wide front fenders and trd sideskirts. i dont like my old varis once biggrin.gif
I also are going to order new 9,5" wide 18" wheels biggrin.gif just dont know what to get need help from u guys.
XXR 530, Klutch SL5 or SL14, Japan racing JR-10 are the once I´m thinking about.
I dont know if a koncave wheel is more siutable for the st205 then wheels with a nice polished lip.
Mikael /// Sweden
post Feb 17, 2014 - 1:22 PM
mikaelhoglund
Joined Aug 7, '07
From Sweden
Heres a picture of my newly rebuild trd coilovers with yellow koni inserts biggrin.gif Hopfully tring them soon, just need to add metall in the pipes, the new konis are a bit shorter then the stock trd shock inserts.
Mikael /// Sweden
post Feb 18, 2014 - 5:52 PM
mikaelhoglund
Joined Aug 7, '07
From Sweden
My new manifold starts to take shape
Swedish custom twin entry manifold ;-)
Mikael /// Sweden
post Feb 19, 2014 - 1:49 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
you messaged me about my beams head but you haven't replied.
post Feb 19, 2014 - 7:21 AM
QUOTE (mikaelhoglund @ Feb 11, 2014 - 2:10 PM) *
Out of those choices, it's definitely the JR-10. I'd still pick the RPF-1 though.
This post has been edited by SwissFerdi: Feb 19, 2014 - 7:23 AM
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: April 22nd, 2025 - 5:49 PM
