BEAMS turns but wont start |
May 9, 2010 - 6:13 PM |
Enthusiast Joined Oct 26, '09 From Florida Currently Offline Reputation: 2 (100%) |
i have read through everything turnip has done in his thread to try to figure out why my beams wont start. i just so happen to own a 94gt myself. i have tested spark, fuel pump, etc. but it seems like the fuel pump doesnt get a signal to pump gas in. i have also noticed that when i do get it to sputter the rpm gauge doesnt move. and also that my radio doesnt turn on anymore. any help/advice is very appreciated
May 9, 2010 - 11:52 PM |
start with pulling out the codes, then check wiring.
mine was a 97 batman was 95 i believe, both gt, but pull codes, its sometimes something easy -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
May 10, 2010 - 1:20 AM |
How do I pull the codes? And where would I look them up?
May 10, 2010 - 9:56 AM |
using the diagnostic box in the engine bay, put one end of a wire in pin tc and ground the other end. turn the key to the on position and the check engine light on the dash should blink out the code(s). the codes will be the same as any other usdm obd1 vehicle.
if you get no codes that means it is not anything electrical, i.e. a sensor or bad connection or no signal to something. in that case if you believe its something fuel related, check that the fuel pump is actually working. Listen for it or pull the feed line off the bracket on top of the tank and see if fuel spits out of it when you crank it. I had a problem with our beams when it just died on me while I was driving to work. The fuel pump did work, but the fuel trickled out, not enough pressure to start the car. I pulled out the pump and it was aftermarket so I replaced it with a used oem pump and started the car. -------------------- |
May 10, 2010 - 2:49 PM |
went to garage to test a couple of more things out, it looks like the coils are not sparking after i powered the fuel pump directly. the injectors seem to be working as well. something is stopping the signal from turning the fuel pump on and sparking the car. could my ecu be bad? i will try running engine codes next tomorrow. i was also thinking it could be the fuel pump relays might be messed up but i dont know where there located but im pretty sure its in the dash somewhere.
May 10, 2010 - 3:45 PM |
ok, my error was, under the intake there are a lot of grounds that are for the coils, i did not tight those, my car started after that, the other is if you do not bridge the 14 and 17 wires in the main plug.
pull the codes and see what. I hope is not the ecu. recheck all wiring. its always something simple -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
May 10, 2010 - 6:50 PM |
ok, my error was, under the intake there are a lot of grounds that are for the coils, i did not tight those, my car started after that, the other is if you do not bridge the 14 and 17 wires in the main plug. pull the codes and see what. I hope is not the ecu. recheck all wiring. its always something simple usually something simple did you move the clutch start switch wire to the correct plug and pin ? also, the stock rpm gauge won't work witht he beams, either use a beams dial or use a signal adapter. -------------------- |
May 10, 2010 - 9:18 PM |
Enthusiast Joined Aug 24, '09 Currently Offline Reputation: 1 (100%) |
ok, my error was, under the intake there are a lot of grounds that are for the coils, i did not tight those, my car started after that, the other is if you do not bridge the 14 and 17 wires in the main plug. pull the codes and see what. I hope is not the ecu. recheck all wiring. its always something simple usually something simple did you move the clutch start switch wire to the correct plug and pin ? also, the stock rpm gauge won't work witht he beams, either use a beams dial or use a signal adapter. I agree. I believe that was the exact symptoms I was having when i tried the key the first time. Thanks again Batman for the help. Should be starting a new thread shortly as I am about to start project #2. Picking up the donor chassis on Thursday. |
May 11, 2010 - 10:27 AM |
Yeah I moved the Clutch Start wire and I bridged 4 and 17 from the top of ea1. Is it suppose to be 14 and 17? Tried to check codes but don't get a check engine light, started checking the ecu for power and I finally got a check engine light but power to it was very low
May 13, 2010 - 1:03 PM |
tested a bunch of relays and they all seem good, i still cant figure out why im getting no power to fuel pump and coilpacks. is there any way to test if the coilpacks on the car are good?
May 13, 2010 - 2:19 PM |
did you modify the wiring harness in any other way that can compromise a short?
I remember in the mr2 forums that you can test resistance to see if they work. did you check all fuses, inside and outside, are you absolutely sure it was wires 14 and 17, at first i did not count them right. (and you probably did them right, but good to double check) Have you tried starting the car with starter fluid, do you have fresh gas, or is it stale. Check compression. (hopefully its ok) If the engine was ok, no high mileage, i would say wiring. Make sure not short. check over mr2 for coil testing. crank angle sensor? -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
May 14, 2010 - 12:03 PM |
i didnt even extend the harness. all fuses checked and look good. do you have a picture of what you bridged? have used starter fluid and it goes but since there is no spark or fuel getting in there it wont stay on. I am not very good with all this electrical stuff....
May 14, 2010 - 12:34 PM |
if it runs w/ starter fluid its getting spark...
May 14, 2010 - 11:49 PM |
Enthusiast Joined Aug 29, '02 From Kelowna, BC Currently Offline Reputation: 0 (0%) |
The bridge on EA1 is from pin 4 to pin 17. Mine would turn over and had spark, all the same symptoms you have described. After I tied the two pins together, the engine fired up first try.
Going on 5 years now and still purrs like a kitten.....er.... tiger. 6GC install link -------------------- 1994 GT-S (BEAMS) swap complete |
May 19, 2010 - 1:11 AM |
the motor is alive and running. just need to get a battery that fits the new terminals and finish the rest of the exhaust piping and i should be good to go! one problem i am looking into is my tach meter not working, i swapped in the JDM BEAMS one before i did the swap and it was working fine but now i get no readings at all.
May 19, 2010 - 1:17 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
so what was the cause, the battery?
May 19, 2010 - 9:27 AM |
yeaH, we demand to know!
videos or this thread is worthless, lol get new terminals from toyota, the mini terminal that comes with the beams suxks. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
May 19, 2010 - 8:34 PM |
Enthusiast Joined May 18, '10 From china Currently Offline Reputation: 0 (0%) |
黄河石柴油机配件厂是一家领先的制造商之一
发动机零部件,尤其是柴油喷射系统 如更换配件喷油嘴,柱塞,并 出油阀等,在南中国。 欲了解更多详情请访问我们的网站:www.yellowstonediesel.com www.dieselinjection.cn 黄河石柴油机配件厂始建于1997.Over多年来, 黄河石已发展壮大,获得了生产的声誉 高品质的产品和提供他们的时间。 105015-5860 105015-5860 105015-5940 0 433 171 134 0 433 171 137 0 433 171 146 5611065 H60S30A538 5611650 BDL110S6133 5611735 BDL110S6267 6801082 6801082 六百八万一千〇八十七六百八万一千○八十七 6801088 6801088 DN10PDN130 DN0PDN121 HL176S27D525P2 2418455518 2455-518 2418455714 2455-714 9401087506 9087-506 134151-4120 P121 134151-4920 P129 134151-6420 P143 喷嘴电装093400-7690 DN10PDN129 喷嘴电装093400-7700 DN10PDN130 喷嘴电装093400-8220 DN0PDN121 131110-9320 131110-9420 131160-0320 |
May 20, 2010 - 11:35 PM |
^^^translate? i will post videos after i get my tach meter working, my power steering is also leaking badly so thats another problem i have to take care of as well.
May 20, 2010 - 11:38 PM |
uhh just left over spam from yesterday...
Lo-Fi Version | Time is now: January 11th, 2025 - 7:42 PM |
