Fogs, Not Working, I think I know what it is...would like confirmation. |
May 10, 2010 - 2:54 PM |
Enthusiast Joined Aug 11, '09 From Buffalo, NY Currently Offline Reputation: 15 (100%) |
So I got my multifunctional switch today, got everything all set up, and I turned my car on, turned the switch...and nothing.
I hear no clicking as if a relay is going off, like the headlights do - I assume I'm missing the relay I thought I had. Just need confirmation before I go blow $25 on a relay...don't have time to pull my dash apart atm. -------------------- |
May 10, 2010 - 3:50 PM |
Enthusiast Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
do you have the relay under the dash in the left corner? its the big blue one i think.. heres a write up on how to http://www.6gc.net/forums/index.php?showtopic=38656
This post has been edited by zfjohnson07: May 10, 2010 - 3:55 PM |
May 11, 2010 - 2:13 PM |
do you have the relay under the dash in the left corner? its the big blue one i think.. heres a write up on how to http://www.6gc.net/forums/index.php?showtopic=38656 I thought I did. Didn't have time to pull my dash apart when I posted, I had to go to work, so I had hoped someone would be able to tell if I did or not. And that's the howto I followed. Nonetheless, I'm fairly sure that's the issue since there's no clicking when I turn the switch for the fogs. I ordered a relay today. -------------------- |
May 11, 2010 - 2:57 PM |
yeah i have a 97 st with the wires for fogs i tried plugging my neons into it and nothing happened so just to make sure i ran my neon wires into my parking lights and they worked.. so as you can tell i realized that my car also lacked the relay for fogs.. whre did you order one from?
May 12, 2010 - 1:46 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
it's really simple:
blown fuse dead relay disconnected wire/plug somewhere broken switch (I can not imagine how this should happen but it is possibility) You said you do not hear clicking sound so it's somewhere before relay. First check fuse, than remove relay and switch them on. Find if you have power in relay socket. If you have it's relay. If you do not check wires and try to test switch... This post has been edited by malpaso: May 12, 2010 - 1:47 AM -------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
May 12, 2010 - 2:01 PM |
Checked the fuse and it was fine, switch isn't broken, I tested it with a multimeter...both wires for my fogs are plugged in, so it's gotta be the relay. Thanks Malpaso!
May 13, 2010 - 1:33 PM |
Enthusiast Joined Aug 23, '09 From Ohio Currently Offline Reputation: 0 (0%) |
Checked the fuse and it was fine, switch isn't broken, I tested it with a multimeter...both wires for my fogs are plugged in, so it's gotta be the relay. Thanks Malpaso! Is there anywhere else you can order a relay from because my local Toyota dealer did not have them? |
May 13, 2010 - 1:48 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
you dont have to use a relay and the fancy on off thing on the arm, you can trick the car into turning them on, you put 2 wires into the relay, one a ground, and connect all 3 to a toggle swich, thats how i did mine
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
May 13, 2010 - 3:49 PM |
^That was the second choice option in Malpaso's thread, I prefer an oem look however so I went the distance...dealership had the thing marked up about 100% though, ended up paying just under $50 after tax. The relay, I meant.
@CelicaST96: They should be able to order it for you if you give them the part number. @Zfjohnson: Sorry I ignored you last time I posted, I ordered them from my local Toyota dealer. -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 1:13 AM |
