> Wiring diagram fro remote starter install, wiring diagram please
post Nov 14, 2003 - 4:30 PM
81726st
Joined Jun 4, '03
From chitown
The car is an auto 96 st hatch. It has an alarm with keyless entry. There is an open 3rd channel output from the alarm that I can use for a remote start. Can someone please give the color coding or wiring diagram and location for the following:
Constant 12V
Accessory
Starter/Crank
Ignition #1
Ignition #2(if there is #2)
Break input
Thanks.
post Nov 15, 2003 - 3:45 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
When i installed my autostart, they told me to go to a website that tells u what wires are what . What kind of autostart did u get? I think mine was a bulldog or some crap... For the brake light, i looked in my tails for what wire was going to the brake, then found that wire in plastic thing under the door, hooked up a voltometer or whatever the hell its called, and hit the brakes, got 12v, so all gravy... Maybe that helps? If you want i can try to find the site...
-Ryan
AIM : FAQdaWorld
post Nov 16, 2003 - 2:01 AM
FAQdaWorld
Joined May 24, '03
Wham
BAM
thank you mam.........
BTW... dont ever go to bulldog.com....
yuck!!!!!!!!!!
www.bulldogsecurity.com is GOOD
Thats the diagram you need for it...
AIM : FAQdaWorld
post Nov 16, 2003 - 2:27 AM
In addition, the brake wire can be found in the driver's kick panel. I could tell you which wire it is exactly and take a photo, but I don't have my car.
post Nov 16, 2003 - 11:48 PM
DoodieHead
Joined Mar 31, '03
From Bowling Green, KY
there are two wires on the brake harness above the brake pedal, use voltmeter/test light to see which on has +12v when depressed. Also these are all the wire colors for my car:
Constant 12V-i dont have this one written down, my remote start gave me 8ga wire to connect to battery
Accessory-gray
Starter/Crank-blk/white
Ignition #1-blue/red
Ignition #2(if there is #2)-blk/orange
Lo-Fi Version Time is now: February 22nd, 2025 - 3:16 PM
