May 20, 2010 - 4:25 AM
Enthusiast ![]() Joined Mar 22, '10 From Philippines Currently Offline Reputation: 0 (0%) |
Hi Guys,
i am just wondering what would be the best cold air intake pipe diameter for a 3rd gen 3sge with a throttle body of 65mm (2 and 5/8"). my current setup uses 3" diameter which i think is good at the higher rpm range but i feel that i'm losing some in the bottom to mid range. i wanted to use the same diameter as the throttle body but the only available pipe size in my location is 2.5" only. do you think that this would be very restrictive at higher rpms? my car is a daily driver and i use it on the track very seldom. but i run full throttle on the streets whenever possible. thanks. |
fgvillegas Cold Air Intake Pipe Diameter May 20, 2010 - 4:25 AM
trdproven fellow pinoy...not much difference between a 2.5... May 21, 2010 - 1:47 AM
fgvillegas thanks.
good to know that there are many pinoys h... May 21, 2010 - 6:40 AM
trdproven QUOTE (fgvillegas @ May 21, 2010 - 9... May 21, 2010 - 8:44 PM
playr158 i'd just go with pipe size the same as the thr... May 21, 2010 - 8:11 AM
d3ath2009 id say your best bet is to buy one off ebay.... th... May 21, 2010 - 8:39 AM
terbear4god4life i could swear i felt my buttdyno hp increase when ... May 21, 2010 - 9:06 PM
playr158 moar sound means Moaaaar powaar!!! May 21, 2010 - 9:20 PM
toyotatech mine is from 04 or 05 duramax diesel, one of the ... May 21, 2010 - 10:44 PM
terbear4god4life QUOTE (playr158 @ May 22, 2010 - 4:2... May 21, 2010 - 11:56 PM
CelicaST_CALI QUOTE (terbear4god4life @ May 21, 2010 ... May 23, 2010 - 12:22 AM
fgvillegas thanks for your replies!
i tend to agree with... May 24, 2010 - 3:58 AM
terbear4god4life QUOTE (CelicaST_CALI @ May 23, 2010 - 8... May 26, 2010 - 1:30 AM
playr158 try like .5hp May 26, 2010 - 9:44 AM
nics QUOTE (fgvillegas @ May 20, 2010 - 2... May 26, 2010 - 4:19 PM
fgvillegas QUOTE (nics @ May 26, 2010 - 4:19 PM... May 28, 2010 - 7:08 AM
nics QUOTE (fgvillegas @ May 28, 2010 - 5... May 28, 2010 - 11:50 AM
fgvillegas QUOTE (nics @ May 28, 2010 - 11:50 A... May 31, 2010 - 11:23 PM
trdproven length of the pipe, the different filter brands an... May 27, 2010 - 4:03 PM
fgvillegas QUOTE (trdproven @ May 27, 2010 - 4... May 28, 2010 - 7:11 AM
trdproven Ive tried many different setups the type of filter... May 28, 2010 - 8:15 AM![]() ![]() |
| Lo-Fi Version | Time is now: December 14th, 2025 - 12:17 PM |
