first I bought these, st205 calipers, rotors, lines.
![]() then to make them bolt on, I shaved off a few mm from the mounting points ![]() ![]() remove old pads and hardware and give a quick paint job ![]() ![]() then got new pads, shim kit, pins, ect ![]() and installed in the calipers ![]() next step is 1. getting the 205 rotors trimmed from 315mm to 298mm 2. getting spacers, either 10mm or 15mm (I need to test/measure, then install them) 3. bolt on (I'm not sure if I'm gonna tap my hub or use nuts/bolts), bleed lines, drive I'll update as I get things done. This post has been edited by Batman722: Jul 21, 2011 - 10:03 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) ![]() |
Amazing info. How hard is that caliper trimming?
This post has been edited by malpaso: May 30, 2010 - 1:09 AM -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) ![]() |
awesome supra tt pads right ?
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) ![]() |
What lovely painting
Enthusiast ![]() Joined Mar 28, '10 From NY Currently Offline Reputation: 0 (0%) ![]() |
You interested in Drilled n slotted brembo rotors?
PM me if you are..off a 94 celica GT |
awesome supra tt pads right ? yes, supra TT pads, I'll post up all the part #s later. You interested in Drilled n slotted brembo rotors? PM me if you are..off a 94 celica GT no I don't want GT rotors for GT-Four brakes because they don't fit, I already have GT-Four rotors. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
dont trim them down
they'll fit perfectly at 315 mm ![]() -------------------- ![]() |
dont trim them down they'll fit perfectly at 315 mm ![]() they don't on my car. ordering spacers tonight and probably going to get the rotors trimmed Wednesday. -------------------- |
Enthusiast Joined Feb 21, '10 From Toronto Currently Offline Reputation: 1 (100%) ![]() |
...nice freakin parts you got there man
dont trim them down they'll fit perfectly at 315 mm ![]() they don't on my car. ordering spacers tonight and probably going to get the rotors trimmed Wednesday. they hit the ball joint sideways, the diameter has nothing to do with them clearing the balljoints. you have to play with the offset of the disc to push them away from them, but every car is different I guess, so I'm sure you'll make them work on yours. -------------------- ![]() |
the 205 rotors clear my balljoint just fine, at least 3-5 mm. The only prob I have is the caliper sits on top of the rotor and one caliper bolt goes in, the other didn't.
the 205 rotors clear my balljoint just fine, at least 3-5 mm. The only prob I have is the caliper sits on top of the rotor and one caliper bolt goes in, the other didn't. hmm, that's odd, I didn't run into that at all, and the 3-5 mm clearance on the balljoint is an issue, once the car is on the ground and you turn the wheel, the suspension will flex enough to allow contact. I'll take pictures of my hub / ST205 disc bolted together, I can't see why yours wouldn't, unless ST and GT hubs are slightly different after all. -------------------- ![]() |
![]() Enthusiast ![]() ![]() Joined Aug 28, '07 From france Currently Offline Reputation: 0 (0%) ![]() |
bump!
so were are those pictures? |
sorry been busy with other stuff on my plate, I'll see if I can get them tomorrow
![]() Enthusiast ![]() ![]() ![]() Joined Sep 24, '02 From North Carolina Currently Offline Reputation: 1 (100%) ![]() |
Looks awesome dude! Any updates?
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) ![]() |
where did you get your pads from mang?
-------------------- ST205 Crew represent
![]() Challenge Accepted |
the dealer.
I need to get off my butt and get this going... -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) ![]() |
thats pretty sweet dustin, they look cool!
-------------------- st205 powered ss3 coupe
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) ![]() |
Sweet, man. I'm got my calipers and rotors from Jim (thanks for the trade, big guy
![]() Enthusiast ![]() Joined Apr 16, '09 From Italy Currently Offline Reputation: 3 (100%) ![]() |
Reducing the diameter of rotors u'll reduce the braking torque...Why upgrade callipers only? The biggest part is given by the diameter...using the same pieces u'll have only a little advantage...
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:17 AM |
