> rebuilt Cylinder head now wont start, what next
post May 29, 2010 - 1:48 PM
csscza
Joined Apr 28, '10
From Ft Worth
just like it says I got a reman cylinder head and changed all gaskets put everything back together and now wont start. So anybody have an idea as to what I address next? This is my sons car and I really want to get it going. Thanx in advance.
Could it be timing? camshaft position? Im pretty sure I got all the timing marks lined up. Distributor position? The search begins.
post May 29, 2010 - 2:48 PM
D-Man
Joined Jan 18, '08
From Houston
94-95 or 96-99?
is it cranking? (or trying to atleast) or nothing from key-turn.
and if it is cranking, do you have any funny smells?
This post has been edited by D-Man: May 29, 2010 - 2:49 PM
Damn D-Man - most impressive.
post May 29, 2010 - 4:01 PM
csscza
Joined Apr 28, '10
From Ft Worth
yeah just checked for spark and it seems to be getting some spark. cranks fine. get alot of gas smell, but Im worried about cranking it to much but it seems to be turning over smoothly. AAAAHGHHHHHH
post May 29, 2010 - 4:09 PM
D-Man
Joined Jan 18, '08
From Houston
are your camshafts placed on in the proper position? in proper alignment to cylindrical positioning?
The spark that you're getting~ (if you're putting a metalic object in the SP wire or looking at a SP) is it firing at even intervals? Or is it just sparking like crazy. (souled be spark-wait-spark-wait-spark-wait) ect.
But first i wanna know about these camshafts. If you didn't put the timing belt on with the camshafts back in perfect rotation with your crank shaft. NOTHING is going to work right.
post May 29, 2010 - 4:14 PM
csscza
Joined Apr 28, '10
From Ft Worth
well I thought I did. I used the timing marks, not the other ones, and used the tdc on crank. Doulbe checked it too. do you think I should pull cover off and redo cranks>?
just checked spark and it was sparking at a good intreval and checked firing order and am now wondering if it might be fuel related. From being totally cleaned out maybe . Hell I dont know
This post has been edited by csscza: May 29, 2010 - 4:58 PM
post May 29, 2010 - 4:41 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
Another question, does it sputter or pop occasionally, did you properly clock the distributor to tdc when you re-installed it? It's not as simple as dropping the distributor back in, you have to make sure its on the right gear tooth and the rotor points in the right direction.
post May 29, 2010 - 4:59 PM
csscza
Joined Apr 28, '10
From Ft Worth
yep I put it TDC and checked for piston 1 in cap. oh yeah thanx for answering. You guys ROCK!
This post has been edited by csscza: May 29, 2010 - 5:00 PM
post May 29, 2010 - 5:08 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
Ok that's good, maybe if you are unsure of the timing marks you could remove top cover, turn it to TDC then take a picture of the cam sprocket and post it for confirmation. It seems like if you have spark and fuel, then it would have to be a valve or ignition timing issue causing this.
Also, I would check compression all cylinders should be above 170. This would tell you if the valve timing is off. To get a basic feel for it if you dont have a compression gauge try turning it over with a wrench at the crankshaft pulley and see if you feel the the cylinders building pressure.
This post has been edited by Jamchell: May 29, 2010 - 5:14 PM
post May 29, 2010 - 5:15 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE (Jamchell @ May 29, 2010 - 5:08 PM) *
x2!
again; is this a 94-95 or a 96-99? The two ignition systems are infact different.
post May 29, 2010 - 5:21 PM
csscza
Joined Apr 28, '10
From Ft Worth
95 I dont think its getting fuel. damn I hate to have to pull the intake to get at the rail again.
post May 29, 2010 - 5:28 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
Quick test for that is to spray a bit of starting fluid in the TB and see if it starts up for a second. If so then move on to checking the fuel system, don't completely rule out coincidental problems like a bad fuel pump things go wrong at the oddest of times I've found.
post May 29, 2010 - 5:33 PM
D-Man
Joined Jan 18, '08
From Houston
didn't you say you smelled fuel? so it's going somewhere.
Pull one injector then.
or here's an easy method (not the pro's way of doing it though.)
Pop your backseat out. (2 snaps; just pull it hard) Turn your key but not all the way. Did you hear the fuel pump buzzing?
NO=Fuelpump out
YES=next step
Locate your fuel filter (d/s by wheel well) and remove the line. let it leak, then replace. Start it a few times. Remove the line; Did it leak?
NO=Fuel Filter/fuel lines
YES=next step
you can unplug the SP wires, crank it a few times, then plug them back in, and crank some more. This will flood your engine with fuel and when you crank with the SP wires engaged then you'll burn the excess flooded fuel. It'll smell like fuel threw you're exhaust. (dont do it too much though, it's not good for the engine in excess) Did it smell like fuel?
NO=Rail/injectors
YES=N/P with fuel system.
QUOTE (Jamchell @ May 29, 2010 - 5:28 PM) *
BEST ADVICE EVER!!!!!
rofl. (it's only funny because, it's happened to us all. and it fcuking sucks!!)
post May 29, 2010 - 6:45 PM
csscza
Joined Apr 28, '10
From Ft Worth
well my son just advised me that the manual was wrong about the firing order . So now the car tries to start but just wont continously fire. acts like it wants to but just wont kick over. could that be timing/ cams off?
post May 29, 2010 - 7:07 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
Well a Celica will still run if the valve timing is off by 1 tooth you will just notice a severe loss of power, more than 1 tooth will net you the "try to start" symptom. Also did you mark the distributor housing, often times the housing will retain a "bolt head outline" which will help you re-align it if you forgot to mark it.
It definitely sounds like you have a timing issue now, I'm almost positive something didn't get aligned quite perfectly on the install,(left field... perhaps the distributor cap got damaged). You might have to backtrack and recheck everything ,maybe post a picture of your timing marks too. No worries, it happens to us all at some point.
post May 29, 2010 - 8:00 PM
csscza
Joined Apr 28, '10
From Ft Worth
I agree tomorrow I redo the timing belt and reset the cams. I think its the timing also. sounds like it wants to start but just wont. Thanx for the encouragement it helps. also just realised I forgot to put the heat sheild under the exhaust manifold. This isnt going very good.
anyone know a good toyota mechanic in Ft Worth?
D-Man
Joined Jan 18, '08
From Houston
is Kharma your son?
PM
I have a 95 celica Gt. I have a question for you and you seem to know your stuff. If the number 4 piston for the spark plug is connected to the number 1 spot on distributor and 3 to the 2 so forth would that cause the engine to crank but not turn over?
Thanks for your time.
because i've already advised him properly. Read the PM.
EDIT:
If so then work as a team on the board. Don't divide and conquer - lol. Get a post moving and run as many details as possible. From Both of you. that one little thing you dont think to mention may be the defining factor!!
AND when you include PM's then both of you get into it! Best way for multi-user-problem-solving. lol.
read PM.
Post Response.
Jamchell and others may have good info to throw down. PM this link to the big hitter's on this site. start with manny and jim and steven ect.
(examples listed= Pressure2 _JIM_ and STEVENLEE)
This post has been edited by D-Man: May 29, 2010 - 8:06 PM
post Jun 7, 2010 - 5:45 PM
Kharma
Joined May 20, '10
From DFW
Ok well me and csscza got the car started after a week or so break from working on it. The timing belt was off. When we were aligning the camshaft timing pulley we used the wrong hole. There was a circle and U and we didn't use the U. Anyways we realigned everything and it started today. Now there is some smoke that appears to be coming from where the TWC and exhaust pipe meet, but it doesn't smell like exhaust at all. The car also overheated a little, but it is probably just some air in the system and we are going to burp it tomorrow.
post Jun 15, 2010 - 7:45 AM
csscza
Joined Apr 28, '10
From Ft Worth
well i didnt realize that he was on also! Yeah we got it all running like a kitten! thanx for the help. I luv Celicas
post Jun 24, 2010 - 1:40 AM
chacha
Joined Dec 29, '05
From So-Cal
white smoke...head gasket i think. need to be replaced or on wrong.
post Jun 24, 2010 - 7:14 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (chacha @ Jun 24, 2010 - 1:40 AM) *
I just LOVE how people jump to that so fast. more like his exhaust system and converter are full of RAW FUEL from cranking with the timing off and its burning off now.
Lo-Fi Version Time is now: November 26th, 2024 - 11:37 PM
